Thread Tools Search this Thread Rating: Thread Rating: 75 votes, 4.77 average. Display Modes
Old 12-22-2011, 05:47 PM   #121
mrbudman13
My Ride: 2004 325i
Anyone know what external torx size socket for the 2 bolts in the front under the black grill when removing the bumper? It would be appreciated.
mrbudman13 is offline   Reply With Quote
Old 12-22-2011, 06:15 PM   #122
mrbudman13
My Ride: 2004 325i
OK did some Google searching I think it might be an E10 torx socket. Here is a link I found for a front bumper removal procedure and you can see the bolts I am talking about.
http://bmw.tech.officelive.com/E46BumperRemoval.aspx
Old 12-22-2011, 08:27 PM   #123
Solidjake
Zero. Leaks.
Solidjake's Avatar
My Ride: '02 330i 6MT
The two bolts for the reinforcement bar? I used a 9mm socket.
Old 12-22-2011, 08:50 PM   #124
zander271
My Ride: 6spd ZHP/5sp XI
I'm doing my cooling system early next year when time permits...I might also do this.
Does the mechanical fan suck? Why do Auto's have 2 fans?
zander271 is online now   Reply With Quote
Old 12-24-2011, 02:58 PM   #125
delmarco
My Ride: 335xi Deep Sea Blue
Send a message via ICQ to delmarco Send a message via Yahoo to delmarco
no one really knows. some say because the auto tranny needs extra cooling but that has not been proven since auto trannys don't overheat after the swap with the one fan there.
delmarco is offline   Reply With Quote
Old 12-26-2011, 01:13 AM   #126
BeMyWhip
My Ride: 01 BMW 330ci
Got 85K on the ticker and wanna do the cooling system overhaul; also, my belt tensioners are squeeling like crazy. since Im already in there, I figure Ill do the underdrive pulleys and electric fan too. Gonna add up $$$.
Always Mod!!!
Founder: 330Ci The 3 litre coupe
BeMyWhip is offline   Reply With Quote
Old 01-09-2012, 08:54 AM   #127
Solidjake
Zero. Leaks.
Solidjake's Avatar
Here's two pics of one of the best mods you can do!!
Nice and clean front intake duct (adding some home made RPI scoops to them soon )
Old 01-22-2012, 09:43 PM   #128
zander271
Originally Posted by Nervous View Post
They are just clips, so just unscrew the screw as far as you can and just pull it out:
P/n:51-71-8-229-003
I ran into the same problem...all 4 of mine broke.
ZHP Mods: JB Lightweight fly wheel (10.5 pounds), Koni FSD ProKit, Supreme Power Drop Hats, Hotchkis front(30.2mm)/rear(25.4mm) sway bars, Sprint Booster, AFE Stage 1 Intake, Morimoto EvoX-R Headlights, Orion V4 Angel Eyes, Satin Black 18x9 ET42 APEX ARC-8 Wheel
330xi Mods:Front Koni Yellow Struts and Rob43 Rear 9 Way adjustable Rear Dampers,Custom Sport Springs,Supreme Power Drop Hats,ZHP 5 speed shift knob
Old 01-23-2012, 01:53 AM   #129
zander271
If the 4 plastic screws break, use 2 zip ties! Worked perfect!
Btw car sounds great and much easier to work on now.
Old 01-23-2012, 07:39 PM   #130
Solidjake
Zero. Leaks.
Solidjake's Avatar
I think one or two of mine broke but the duct is held in there good. Nice small trick. How do you like the swap?
Old 01-23-2012, 09:48 PM   #131
steve.325i
My Ride: 2003 325i
Interesting. I dont remember the four clips at all. I don't think the facelifted version has them.
steve.325i is offline   Reply With Quote
Old 01-24-2012, 10:35 AM   #132
Solidjake
Zero. Leaks.
Solidjake's Avatar
For the facelift we that those plastic screws that hold the center duct.
Old 01-24-2012, 03:11 PM   #133
zander271
First drive this morning. Seems much more quite outside the car and maybe a little on the inside. I also replaced the water pump pully(ESC metal one) and belts while I was in there.
Not sure of the added benefits outside of making your car much easier to work on and more quite. I've seen a few remark about better gas-mileage. I'll report back on that with some real #'s. I have recorded the milegae on this car since the first tank of gas I have put in it using the "Road trip App" on my iPhone.
Old 01-29-2012, 06:00 AM   #134
Handle46
My Ride: 2000 323ci
Hey guys, been going through hell trying to JUST get started with removing my mechanical fan in order to get to the real Problem - blown idler pulley, shredded main belt. Before I even get there, I'm stuck at stage 1, trying to get this fan nut off. After spending the day trying to get it off, I am seriously considering chucking the Mechanical fan the moment its off and converting to the solo electric fan. My only concern is, has anyone monitored Auto tranny temps, especially in the summer times, in places like LA? Is there a diagnosis option in the dash computer to monitor the temp?
Handle46 is offline   Reply With Quote
Old 01-29-2012, 11:52 AM   #135
tootall
My Ride: 2011 328iT 3 pedals
I haven't done this swap yet, but I believe that fan nut is reverse threaded, so you remove it by turning clockwise. Could that be your issue?
BMWCCA member since 1990
Upgrade your 328 with a 330 intake: http://forum.e90fanatics.com/showthread.php?t=1095889
tootall is offline   Reply With Quote
Old 01-29-2012, 04:55 PM   #136
Handle46
My Ride: 2000 323ci
tootall, Yeah I have been turning in that direction, the problem I have is I don't have the main belt on and I cannot put it on cause my idler pulley is broken, so I don't have tension coming from the belt to help loosen the nut, also I have tried using a screw driver between 2 waterpump screws but that just ended up bending my straight flat head into a L shape. Right now, my situation is broken waterpump pulley, broken idler pulley, no main belt, and in need of a serious prayer to get this nut off
Old 01-29-2012, 06:27 PM   #137
tootall
I think you have to have the right tools:
http://www.amazon.com/Clutch-Wrench-...=1ZILH916PYHNL
It's not impossible to do it without these, but I have not heard any complaints from those who did it with these tools.
Old 01-29-2012, 06:40 PM   #138
tootall
This thread has a video on how to remove the fan with a 32 mm wrench and a sledge hammer in post #9:
http://forum.e46fanatics.com/showthread.php?t=899656
Old 01-29-2012, 10:13 PM   #139
steve.325i
My Ride: 2003 325i
Yeah, I have seen other youtube vids on removing it w/o the proper wrenches. IMO (please nobody yell at me for his) if you are going to work on your car, you shoudl have the tools.
Quick note - the fan clutch removal tool is sort of universal. You can pick up one for a GMC Jimmy or Ford Explorer and you will be good. I was dumb and bought mine online from bimmerspecialists and paid a fortune to have it sent to Canada ... and when I got it, the packaging lists all these domestic trucks that it will work on.
re: summertime performance - some guys have posted in this thread - they say they are good. Again, this is the fan that is used with the manual tranny.
omg - thanks Jake. I ijst re-read your post and it just came to me. You are right !! allfour of those damn things broke. Definitely brittle from years of heat. I guess @ my age my memory needs to be jolted @ times
Old 02-02-2012, 01:17 PM   #140
WALKD U
My Ride: Just Fast!
Should add a Tranny TEMP Gauge to see where the temps at...
2005 AW/IR M3
MaximumPSI Stage4
993whp/651wtq SAE Corrected
2005 JB/BLK 330i ZHP
NA Bolt-ons
207whp/216wtq SAE Corrected
1996 BLU/BLK M3
NA Bolt-ons
235whp/225wtq SAE Corrected
1988 SETA 325I
NA Bolt-ons
165whp/160wtq SAE Corrected
aux, auxiliary, behr, bosch, bumper, clutch, damage, electric, engine, explode, fan, hood, manual, mechanical, mount, mounts, removal, swap
