Old 12-12-2011, 10:29 AM   #1
e46allday
My Ride: 01 325ci
Loss power, tranny limp mode?
Ok was driving noticed red battery light on then a loss of power rpm went up but no power. So I pulled over next thing I noticed was that there was no gear selection on display only if I shifted to the steptronic the "S" would appear..during this whole time car still running but couldnt put it in reverse all it did was spike my rpm so I shut of car and tried restarting it but no go everything comes on fine but wont turn over... Checked my fuses #30 was out so I replaced it but still same symptom...i also hear like a humming coming from between motor and dash also when I turn on headlights...humming stays on for about 10-15 second after I remove key...any ideas or similar problems?
Sent from my DROIDX using Bimmer
e46allday is offline   Reply With Quote
Old 12-12-2011, 11:00 AM   #2
CSL323
My Ride: 330Ci
Very interesting... Never heard of such a thing really... When you said red battery light, I imagined alternator...
It could be a number of things... I'd imagine the non-turn over would be starter or maybe battery?
Maybe the battery can't power the vehicle's functions correctly, so the display isn't correctly working? I haven't got a clue in the world.
What have you tried?
CSL323 is offline   Reply With Quote
Old 12-12-2011, 01:50 PM   #3
CSL323
My Ride: 330Ci
Also — have you seen this at all?
Old 12-14-2011, 03:18 PM   #4
bigmsd
My Ride: 330ci and 325ci
what is that cog light? i have that light on my dash and no power in 1st or 2nd.
bigmsd is offline   Reply With Quote
Old 12-14-2011, 06:06 PM   #5
CSL323
My Ride: 330Ci
It means transmission failure
Old 12-28-2011, 03:52 PM   #6
locomexicano
My Ride: E46 330ci
Send a message via MSN to locomexicano
Dude im having the same problem, what was the issue??? Please help out...
locomexicano is offline   Reply With Quote
