Rating:
#61 |
I just ordered the one from ebay. I should have it sometime next week. Now I just need to get my old laptop up and running. I figure if I can code my car once it already paid for itself. If by the time I get it no one has reported back, I will. thank you ac_2007 for the link.
#62 |
I'm trying mine in about an hour with Windows 7 and the drivers from the link above.. I'll let everyone know how it goes... "fingers crossed"
#63 |
^ Remember to disable all network hardware while installing. Otherwise you'll have a nightmare like Pedi.
#64 |
This is just during the installation, correct? Once installed you can have the wifi on can't you?
NWS and Advertising Removed.
#65 | |
but couldn't get it to work with windows 7 64 bit ![]() I know there is a way to do it, I had installed the FTDI drivers from the same website for generic OBD cable before by making some changes in PId and all but just got impatient and loaded another virtual machine with xp in mac. Works. Disabled DRLs and read some codes. Will do more research see what I can do with it.
#66 |
Got mine to work with windows vista and 7.... That's the good news!!!! Now I have no clue how to program what I need!! LMAO.... Instructions would be nice...
#67 | ||
If you post up what you're trying to do, there's probably one of my screenshots up already. |
#68 |
Thanks!! Trying to "enable" lights to flash upon locking at the moment
#69 |
It gives you the option of lights, headlights and high beams I think...
#70 |
#71 |
windows 7 64 bit? what drivers did you use? or what changed did you make if you had to in the driver installations process.
#72 | |
#73 | |
But I got it to work in XP.
#74 |
#75 | |
May be I am running on virtual machine on mac that is the reason. I got it to work once before with the generic OBD II, will need to dig deep and make some changes on Pid and all. If I get it done I will post it so everyone else can use the steps. For now I am using it on XP
#76 |
scanner 1.4 from xcar360 not working
i tried to install it but dont know how to start. im using xp and I tried to connect the device through usb but it couldnt find any hardware. is there any step by step to install?
#77 |
The hardware gets its power from the car not the computer so make sure everything is connected and your key is at least in position 1. Follow the pdf provided on the CD.
#78 |
#79 | |
Ebay link for 20 pin adapter: http://www.ebay.com/itm/280745678014...84.m1439.l2649
#80 | |
I havent install anything yet. it says on the manual connect the scanner to usb port on the laptop it the new hardware wizard will pop out. but on my case nothing coming out.im still on part of installing the scanner on my aptop. i have windows xp no interenet connection.
| Tags |
| bmw scanner, diagnostic tool, error message, pa soft |
| Rate This Thread | |
