Forced Induction Forum Sponsored by Active Autowerke
Discuss supercharging, turbocharging and even nitrous and water injection here. Sponsored by Active Autowerke |
#41 | |
If only preventative maintenance was free....then I'd have much better allocation of car funds for fun parts haha
![]() 2002 E46 M3 6MT | Jet Black . Black Nappa | My Build Thread Evolve Automotive CF Airbox & AlphaN . Supersprint V1 Stepped Headers & V1 SPipe . KW V2 . Volk Racing TE37 |
#42 | |
My Ride: 05'M3, 03 996TT
![]() Best ET 11.93 Best Trap 134 |
#43 | ||||||||||||
Thread Revival and Posts concerning Vanos:
So to summarize...things that are not so hot in the Vanos: - Exhaust Hub Breaking (Beisan Solution in the works) - Intake Cam Bolts Loosen up (Threadlocker with Z4M Cam bolts iirc) - Vanos Solenoid Pack (Beisan Solution available and Dr.Vanos...Beisan is rebuilt and Dr.Vanos is overpriced new OEM with same inherent design flaw) - Vanos Seals (Beisan Solution available) Sent an email to Raj@Beisan asking what he recommends for a full overhaul on the S54 vanos and I expect he'll be back to me today.
#44 |
My Ride: ZHP Custom Stage 3.5
^ let us know
..::|TrippinBimmer's Boost Build with Cool Parts|::.. 4**whp/3**tq SAE Corrected |
#45 | |
#46 | |
Chris.
![]() ![]() HorsepowerFreaks.com 12905 NE Airport Way Portland, OR 97230 (503) 256-5600 BMW Performance Parts Product questions or to purchase - sales@horsepowerfreaks.com |
#47 | |
#48 | ||
Its not much regret I have since a few of the really neat things are not available yet. I heard one tech(not mine) say he could get to the VANOS and have it half way stripped in two hours. I'd like to see that! Seems like bragging. In any event, the VANOS rebuild is one of those things that's really expensive to do but wise IMO. My tech did say that Besians electrical refit of the VANOS was not necessary on one with 50K miles on it. I am liking what Besian is doing. I read in a Besian blog somewhere something about what CW is talking about. I dont understand ALL of it, but I do believe it is important to consider. Quote:
I was all for buying the Besian Solenoid. THat was one thing that my tech thought was only necessary in a really HIGH mileage motor....over 100K. So i dunno. Thats what I was told.... other wise I agree with your. I might still put that solenoid.
![]() Last edited by Bdave; 01-13-2012 at 10:03 PM. |
#49 |
Just stumbled on this in the M3 section. Seems relevant to this thread.
http://forum.e46fanatics.com/showthread.php?t=893984 |
#50 |
My ticking was driving me nuts! So I ordered Dr Vanos today, the exhaust hub, and upgraded bolts. My car is at HPF, awaiting the new Vanos system.
HPF Stage 2.5 BMW M3 ![]() |
#51 | ||
Found this on youtube, is this what everyone with the ticking symptom sound like also? This is very similar to what mine sounds like when cold. Does anyone know whom the owner is and what the fix was? Last comment on youtube stated that they took to MaximumPSI so they could take a look.
![]() Best ET 11.93 Best Trap 134 Last edited by 02black330ci; 01-14-2012 at 01:08 AM. |
#52 | |
#53 | |
.... Whats the info with the upgraded hub, ie where to buy, etc...
#54 |
I hope you read a bit more into things before you (wasted ->IMO) all that coin...I know Mspired has had no issues with his Dr.Vanos upgrade but you seriously needed to call Raj at Beisan systems. Alot of history between the two companies and in a nut shell here is my take on it.
Dr.Vanos buys brand new OEM solenoid packs ( The same ones that fail in the first place) Also the Cryo treatment on the exhaust hub could infact have negative effects on the exhaust tabs as it increases the brittleness of the metal...most failures are > 60k Miles so you won't know until you get more miles on it. Dr.Vanos wants to make money...and he's doing that and isn't researching the primary reason or fix for the exhaust tabs like Raj is. Regardless you will want the updated crap from Raj when it comes out...and he doesn't care about the money...he's extremely passionate about BMW's engineering failure in regards to the vanos issues. Seriously you owe it to yourself to call him regardless...I have spent a considerable amount of time looking into this and this is just my opinion...there is absolutely no reason...none...to blindly spend on something that is cheaper and imo better. Edit: Don't take my word for it either...dig into all the threads on this on this forum, bfc and m3forum...there are tens of thousands of posts on this crap. Save the money for better upgrades. And the video sounds fine...exhaust has an offbeat rasp to it that might throw you off but thats not the vanos...the tiny rattle is the only thing...way worse noises in other vids on youtube...don't look for hpf vanos in a search...try S54 Vanos, BMW Vanos Rattle...its universal for most e46's and many other bmw's...the rattle isn't the issue so much as the extra play in the exhaust tabs...obviously vanos service on the bearings/seals should be done every 80k imo and inspection or rebuild of the solenoid packs at your comfort but the exhaust tabs are what actually break...it is a ticking time bomb.
#55 |
Mine only has 45k on it, sad, so sad! I'll give him a call and see what he recommends.
#56 |
I got it all from Drvanos.com. The hub is cryogenically upgraded (stronger than OEM), so the tabs won't break as easy I guess. The Vanos failure thread scared the crap out of me so I'm taking every measure I can to save the motor... that and my car is starting to sound like a diesel truck.
HPF Stage 2.5 BMW M3 ![]() Last edited by Rockyminator; 01-14-2012 at 01:42 AM. |
#57 |
Its probably nothing more than a 2-3% Exhaust Hub failure rate on the S54 so don't be afraid to drive the car for fear its going to blow...I mean once Raj releases this Hub Shim it will give me that added peace of mind. There are alot of posts on this topic because its a problem that can/will/has taken out many engines...heck some tabs are broken and we don't even know it! I dunno its a pita problem but def talk to Raj, he WILL give you the no bullsh!t explaination.
#58 | |
HPF Stage 2.5 BMW M3 ![]() Last edited by Rockyminator; 01-14-2012 at 02:22 AM. |
#59 |
There are two tabs on the rear of the exhaust hub...these tabs are what rattle around...over time these tabs can break...the shims increase the clearance and reduce the forces exerted on the tabs so that they will have a less tendancy to break as there will not be the larger distance for movement to occur.
Here's a pic of two hubs with broke exhaust tabs... ![]()
#60 |
My car sounds just like the one in the video. My car only has 35k on it. Does sound like a diesel for the first minute or so. Should I be worried?
