Thread Tools Search this Thread Rating: Thread Rating: 11 votes, 4.36 average.
Old 01-10-2012, 01:46 AM   #81
Bostonbeast
My Ride: 2000 328i
Originally Posted by snobitall_ron View Post
I havent install anything yet. it says on the manual connect the scanner to usb port on the laptop it the new hardware wizard will pop out. but on my case nothing coming out.im still on part of installing the scanner on my aptop. i have windows xp no interenet connection.
Okay I know where you are in the installation process now. The only way the new hardware wizard will pop up is if the hardware has power. And like I said before, the scanner gets power when it is connected to the car NOT FROM THE LAPTOP. So if you have your adapter, hook that to the 20 pin port under the hood. Then hook up to your scanner which is connected to your computer. Turn your key so electronics come on (Position 1). You will then see the hardware wizard pop up and you can continue and complete your installation.
Hope that helps.
Bostonbeast is offline   Reply With Quote
Old 01-10-2012, 01:46 PM   #82
snobitall_ron
My Ride: 1999 323i (e46)
Thanks. I think i didnt really read and understood your reply erlier. I appreciate it. Have a Bimmer safe!!!
Hope that helps.
snobitall_ron is offline   Reply With Quote
Old 01-10-2012, 06:24 PM   #83
MeRon
My Ride: 325Ci
I tried installing this scanner software on Windows 7 32bit and it was a no go. Followed the instructions using the FTDI drivers exactly multiple times and everytime I tried to run the scanner software I got a blue screen. Said screw it and installed XP and everything installed and worked the first time. If you are having problems just install XP.
These are the things I coded:
-Brake light cold check disabled (LED tails giving me light out error when key on, definitely get this cable if you have this annoying error)
-All alarm functions including clown nose blink and parking lights blink
-Auto lock after 2 mins w/o door open
-Auto lock after 20km/h
-Convenient open and close
-Double flash hazards
-DRL delete
I'm sure there are more but can't remember at the moment, totally worth the $50 I spent. If anyone wants the ebay seller I bought mine off of just pm me. The cable that I got did not require any modifications (solder jumper) and came with all drivers and software.
MeRon is offline   Reply With Quote
Old 01-10-2012, 06:33 PM   #84
snobitall_ron
How did you do the clown nose blink? and I want also the hazard light when u lock and unlock the car. The auto lock 2 mins w/o open not working on mine even i turn it on. What is double flash hazard?
-DRL delete
Old 01-10-2012, 06:40 PM   #85
ccagle
My Ride: 02' 325i
Clown nose will blink once "visual" alarm is checked as will the hazard lights...
ccagle is offline   Reply With Quote
Old 01-10-2012, 11:03 PM   #86
MeRon
My Ride: 325Ci
This is the double flash:
It should be under "LCM". For the clown nose, you need to enable "DWA" (alarm) under the "ZKE" menu, then below that enable also "Arming - optical" and "Disarming - optical" Acknowledgement .
Old 01-10-2012, 11:29 PM   #87
ZHPOWER
My Ride: 2003 ZHP
-DRL delete
cool. who's the ebay seller you went through?
thnks
// ZHPOWER Personalized Plate / BBS RS-GTs / H&R Sport Cup Kit / B&B Triflo Exhasut / OEM Euro Clears / 40% Tint - 50% Front Windshield / Akebono Brake Pads / aFe Intake //
ZHPOWER is offline   Reply With Quote
Old 01-16-2012, 08:19 PM   #88
zooter2002
My Ride: 2002 330i
can you tell me if you can use this to re-flash the dme with eu2 software?
zooter2002 is offline   Reply With Quote
Old 01-17-2012, 01:10 PM   #89
hassmaschine
My Ride: '91 325ix
no...
hassmaschine is offline   Reply With Quote
Old 01-17-2012, 07:04 PM   #90
stevenluczynski
My Ride: Is Steel Blue<3
Originally Posted by ac_2007 View Post
Could also get this http://www.ebay.com/itm/BMW-USB-OBD-...9&cmd=ViewItem
Has INPA, DIS, NCS Expert, SSS/Progman. Pretty much every programming option for this car, including ECU flashing.
Just got mine today!
I code cars-p'm me
stevenluczynski is offline   Reply With Quote
Old 01-17-2012, 07:08 PM   #91
Stiggles
Stiggles's Avatar
My Ride: Was built Fri 13th
Got mine yesterday.
Stiggles is offline   Reply With Quote
Old 01-17-2012, 07:20 PM   #92
stevenluczynski
Got mine yesterday.
Have you tried it out yet? I'm just starting to unzip the files
I code cars-p'm me
Old 01-17-2012, 08:40 PM   #93
ElrichMeister
My Ride: 06 325Ci M56
lol i got mine today too! just so people know i got mine from xcar360, and picked hongkong post for shipping, and i got free shipping, didnt see that on here.
ElrichMeister is online now   Reply With Quote
Old 01-17-2012, 08:43 PM   #94
jeagolf
My Ride: 04 330Ci Vert
I have tried it, I have the same kit. I got mine last week or so.
I would like to do the ECU flashing but I think I am missing something because it is not jumping out at me. Or if it is jumping out at me it is the parts that are still in German.
jeagolf is offline   Reply With Quote
Old 01-17-2012, 09:07 PM   #95
ElrichMeister
well i couldnt get the drivers installed through windows 7, with the provided link on the thread. in my device manager it lists it as BMW Scanner 1.4, rather than USB Root Hub. So not sure whats going on there
edit: Just realized where i messed up lol, and now my battery is too low on my laptop. Just make sure you guys read the instructions very carefully lol
Old 01-17-2012, 09:47 PM   #96
wjjklj
My Ride: 2004 745i
I got this today and it works great. I am running on Vista. Follow post #41 instructions and you will be fine. I paid $32 which included shipping. Mine arrive 2 weeks after purchasing from China. I am still messing with it but was able to set up alarm functions like I wanted, auto locking doors at a certain speed, and one touch opening rear windows.
A couple of questions...when it scans identification showing all options and odometer why would it show everything twice with the odometer reading being different by 79 miles. Can I change this to read the same? Why can I only get one touch rear window opening and not closing even though I have this checked in coding? Great info here and a great item. Keep the information coming.
wjjklj is offline   Reply With Quote
Old 01-18-2012, 12:46 AM   #97
ElrichMeister
Yup followed them to a tee, im getting stuck after you change the USB Root Hub to USB Serial Convert A, i get Code 10, cannot start device.
Well i installed XP mode on my machine, and it runs and installs fine, only thing is that it can find the DME, its just greyed out.
it was reading SRS and LCM fine
Old 01-18-2012, 02:07 PM   #98
Stiggles
Stiggles's Avatar
I've just watched the videos so far. Honestly this kit was purchased with the intention of activating my OBC for the new turn-signal stalk I retrofitted. But PA Soft was able to do it
From what I've read on BimmerForums, we now have all the required hardware to do the flash. WinKFP may be required software though.
If you do figure this out, please feel free to send me a PM.
I assume you're talking about PA Soft. You may need to take the device apart and solder together pin 7 & 8.
http://forums.bimmerforums.com/forum....php?t=1726627
Old 01-18-2012, 06:46 PM   #99
wjjklj
My Ride: 2004 745i
Hey all,
I recently bought this scanner and it is definitely worth more than the $32 it cost me. So far I have been able to program many functions I wanted but I have several questions that I am hoping some of the experts will help me with...
1)why would my IKE odometer read 192,896km and the LCM odometer read 192,800km? Anyone know how to make these read the same? Should they read the same?
2) what should the pwm value be for led license plate lights? It is 20 now.
3) I get an error that comes back after clearing for the telephone. I don't have a telephone in the car. What do I change to clear this error?
4) I get 4 errors on AHL-adaptive directional headlights. One says Shadow- telegram speed invalid. Any idea what that means?
5) finally, how do I get double hazard flashers (euro style)? I don't see anything to do with hazard lights in LCM.
This scanner is a great find. Thanks to all who posted and for any answers to my questions.
Old 01-18-2012, 07:18 PM   #100
Stiggles
Stiggles's Avatar
1) My difference is usually only 1 or 2km. You may be able to change the mileage of the cluster to match the LCM depending on the type of chip the cluster uses.
3) Could be an engineering code that doesn't apply to your car. Also could be that the feature was activated without the hardware being in place.
4) Clear your shadow codes and try diagnosis only if they come back.
5) Not all algorithms have this option. Some M3 series owners have not been able to find this option.
Here is a screenshot of my setting:
bmw scanner, diagnostic tool, error message, pa soft
Rate This Thread
