Thread Tools Search this Thread Rating: Thread Rating: 5 votes, 4.00 average. Display Modes
Old 01-20-2012, 03:16 PM   #21
Stiggles
Stiggles's Avatar
My Ride: Was built Fri 13th
Originally Posted by DougL3NC View Post
What does the term "Catalyzer Preparation" mean?
Looking at the DME's available for my 00 323, there is the standard flash (Euro 3 equivalent) and the ones marked EU2 are for lower power output or low compression motors.
The one is marked "Catalyzer Preparation=Yes". Is that the cat-less EU2 tune?
You don't want any flashes marked for low power/low compression.
I know my tune number, there are at least 3 that can be used on my 325. If you aren't sure, don't flash.
For a MS42 323, you may want to consider 12141430440
For vehicles with:
EU2 exhaust emissions standard (S168A) = Yes
Stiggles is offline   Reply With Quote
Old 01-20-2012, 04:53 PM   #22
DougL3NC
My Ride: 2000 323Ci
For vehicles with:
Thanks! I currently have cats, so I was going to flash it with:
#12 14 7 528 656
That's the DME# that I interpreted to be EU3 Standard. Figured I would flash EU3, ditch the SAP, and then wait for the cats to crap out. When the cats finally gave up the ghost I'd go with headers and flash EU2.
What say ye?
DougL3NC is offline   Reply With Quote
Old 01-20-2012, 05:39 PM   #23
cak323i
My Ride: ///M3 & 330i ZHP
Originally Posted by stevenluczynski View Post
Ill be making a full DIY thread once i figure everything out
sweet! I will be keeping an eye for your DIY
2004 TiAg ///M3
2003 Imola Red 330i ZHP
1999 Electric Red 323i - SOLD
cak323i is online now   Reply With Quote
Old 01-20-2012, 07:11 PM   #24
stevenluczynski
My Ride: Is Steel Blue<3
The thread doesn't die, I've been posting there recently. If you're not following the "Just updated my DME!!!" thread by newtoe46, you're missing out on a lot.
TerraPhantm and a few other members have contributed some very useful info.
My DIY on How to flash to EU2:
1) Purchase the cable/software combo posted at the top of this thread, from the Romanian seller.
2) Follow the included video tutorials and install all software packages. Ensure they work.
3) Visit http://bmwfans.info and click on your E46 model, choosing EUROPE as the country.
4) Click on "Engine electrical system" then "Control unit DME, programmed". Note the serial number of the appropriate tune you want.
5) Open up WinKFP and enter the last 7 digits of that serial number when "Enter ZUSB" prompt comes up.
- Ensure you disable UIF writing
- Ensure you select LOW BAUDRATE before flashing
6) The flash will begin, it will take around 20 mins for the first stage, and around 3 for the second stage.
- Ensure you have a battery charger hooked up to the car supplying a minimum of 10A power.
7) After confirmation message, remove the key from position 2 for a minute and close WinKFP. Start DIS and clear all your adaptation values.
8) Enjoy better idle, torque, and throttle response. Catless headers will no longer trigger a CEL, and the SAP can also be deleted.
- Ensure you only use 91+ octane gas from now on.
So have you actually used the Winkfp supplied from ebay?
I code cars-p'm me
stevenluczynski is online now   Reply With Quote
Old 01-20-2012, 07:11 PM   #25
stevenluczynski
And for everyone who is Deleting their SAP this is the part for it!
http://www.trademotion.com/parts/ind...&siteid=214672
I code cars-p'm me
Old 01-20-2012, 07:45 PM   #26
flashmeow
Banned User
My Ride: E30-E46-E90-E90M-F30
can anyone give me the DME version for MS42 (328) that can disable SAP and cats. thanks
Old 01-20-2012, 08:04 PM   #27
stevenluczynski
http://bmwfans[/img] ** SPAM LINK BLOCKED ** Report this post to the moderators [img]parts/catalog/E4...me_programmed/
I code cars-p'm me
Old 01-20-2012, 08:15 PM   #28
flashmeow
Banned User
thanks for the link. can you manually flash the different version on your GT1 (using progman or SSS) or do you need special software.
also...what does low compression engine mean? i keep seeing it on the notes on the url you provided
Old 01-21-2012, 03:33 AM   #29
Stiggles
Stiggles's Avatar
Yes Progman can also be used for the flash, and INPA to clear adaptations.
You'll probably want 12147513614 from that list for EU2.
Old 01-21-2012, 09:24 AM   #30
mystert
My Ride: 2003 330Ci
So why is everyone so hung up on deleting their SAP? Its not like it causes the engine to make less power, or really slows the car down. You wanna make the car faster, take the amps and sub boxed out of the trunk! I can see the benefits of the removing the cats and getting rid of the CEL but seriously, what do you gain by deleting the SAP?
In the process of unpacking my istap-v38 files to load into WinKFP and will try to load up the EU3 software. I was able to update the DME software a few years ago when Terra first figured out how to do it. Im looking forward to the improved throttle response..
MysterT Huntington Beach, CA
mystert is offline   Reply With Quote
Old 01-21-2012, 11:44 AM   #31
Bostonbeast
My Ride: 2000 328i
Thanks for making this thread! That pasoft thread was getting confusing.
Deleting the SAP is mainly for a quieter cold start idle.
Bostonbeast is offline   Reply With Quote
Old 01-21-2012, 12:56 PM   #32
mystert
My Ride: 2003 330Ci
Had a few difficulties but got it to work right, somehow lost connection to my DME first, couldnt read it in INPA, DIS, or SSS as well. Followed Terras instructions to get it working again, and got the EU3 flash completed. Seems to want to rev higher now?
If you notice on the BMWFans.info sight, the 7545670 number is not only an EU3 flash but its also the EU4, at least for my car, 9/2002 build date. Wonder how that effects things
Also curious what the "saftey vehicle" flashes do
Old 01-21-2012, 01:28 PM   #33
stevenluczynski
It would be cool if the safety flashes made your lights flash like a track safety car
I code cars-p'm me
Old 01-21-2012, 10:52 PM   #34
forzam
My Ride: 04 325Ci
Did any of you guys get this cable and software to work? I can get INPA to load and I have the battery/ignition solid circles. I was also able to connect to the engine DME and read/clear some errors.
But when I try to connect to the IHKA module, I get the error IFH-0009: No Response From Control Unit. When I try to connect to the instrument cluster module, I get the error: IFH-0006: Command Not Accepted.
When I run GT1/DIS, I get "Diagnosis bus error" "communication between operating unit and diagnostic head is impaired. Error number 200.159."
forzam is offline   Reply With Quote
Old 01-21-2012, 11:09 PM   #35
eu teo
My Ride: 325xi
Great info
Thank you
Sent from my EVO 3D
eu teo is offline   Reply With Quote
Old 01-22-2012, 10:45 PM   #36
Stiggles
Stiggles's Avatar
Steven, I have installed all programs according to the video tutorials and they seem to be running fine. The problem now is that I can't communicate with the car using the OBDII to USB cable.
I have:
- Disabled my firewall and antivirus
- Set VMWare IP settings according to the videos
- Selected COM2 port for the cable, and set latency to 1ms, bitrate to 2048.
- Started IFHSvr32.exe (EDIABAS) and DiagHead.exe (Yellow-head emulator) programs before starting DIS.
These are the screens I get:
Also, when starting INPA with the cable connected to my car, IFHSvr32.exe running, and car key in pos 2, both "Battery" and "Ignition" show "OFF".
Obviously there is something wrong with the communication protocol and the programs cannot interface with my car for some reason. I disabled some of my Win7 (32-bit) services when setting up this laptop, using service tweaker. Any ideas what could be wrong?
Old 01-22-2012, 10:58 PM   #37
forzam
My Ride: 04 325Ci
check:
1. OBD.INI is in your System32 directory as well as /EDIABAS/BIN
2. You added /EDIABAS/BIN to your windows path
3. In the OBD.INI port=COMx (should match what you have in device manager)
4. EDIABAS.INI is correctly edited with diaghead and 192.168.68.1 and port 6801
5. In device settings - Ports - Communications Ports - check that "USE FIFO Buffers" is selected (Also, I believe this should be the same port that your cable is set to)
6. Run /EDIABAS/HARDWARE/OBD/OBDSETUP.EXE and be sure everything is OK
Be sure you can get INPA to run before you tackle GT1/DIS.
Old 01-22-2012, 11:44 PM   #38
TitaniumCranium
/// Limitless
TitaniumCranium's Avatar
My Ride: 2002 BMW 330Ci
I don't believe you need diaghead.exe to make this work.
Load IFH server first then load vmware and DIS, it should work without diaghead. You won't see the GT1 interface lit up at all, but it works as though the GT1 was remote through a network.
/// MODS
/// Auto => 6-Spd Manual Conversion | Apex EC-7 | Koni/Ground Control Coilovers | Vorshlag Camber Plates | Meyle HD LCA | PowerFlex bushings | GruppeM CAI | Shark Injector | 6000k HID's and Fogs | BMW European MTechII | BMW Performance Shifter | ACS Mirrors and Rear Spoiler ///
Old 01-23-2012, 12:05 AM   #39
Snik
Snik's Avatar
My Ride: IR M3 Vert.
So from my little searching.
EU2 is used for you guys that run ebay headers, or whatever without cats, and when you remove the SAP (air pump), correct?
what else is it good for?
and what does the EU3 and 4 do?
Also, if im sharked alreasy, this isnt for me is it, unless i do the above, (no cats) then just reshark?
Stuff for sale!!!!!
Do you ride a sportbike?
Old 01-23-2012, 12:16 AM   #40
spencers
My Ride: 2001 325Ci
Eu3/4 is a more strict version of eu2. Only allows SAP removal.
If I recall, shark does not work with EU.
spencers is online now   Reply With Quote
