Go Back   E46Fanatics > Other BMW Models > General BMW Model Discussion
All non E46 BMW model questions in here. Look below for E36, E90 and F30 specific forum. For additional model specific forums check out bimmerfest.com!
Old 01-22-2012, 11:50 PM   #61
TrippinBimmer
My Ride: Just Fast!
Originally Posted by kaboo0m View Post
touche. but wouldn't be surprised if they just slapped an I head or exhaust on it since the head was similar to the m20b25 head in many ways but like you mentioned, the DME number would prove a lot
Sorry didn't meant to sound touché. Hehe
Well he really won't know for sure until he get the numbers on the block.
Mine is a SETA. Has all the 2.5l parts. Only different is Intake Mani, Cam, Double Valve Springs, AFM, DME and Bottom End. Top end is almost identical.
Alpine White M3
MaximumPSI Stage4
993whp/651wtq SAE Corrected
Old 01-23-2012, 01:28 AM   #62
My Ride: Lexus
Not sure why nobody's mentioned this yet, but this is not E46 related. Wrong section. E30 has no real weak spots, per se. Any "weak spots" are because it's a 25+ year old car. I sold my last E30 to a friend (89 325i) and it's got 260k original miles and is rock solid reliable.
Old 01-23-2012, 11:30 AM   #63
bimminge46
My Ride: 323Ci, 89 325i ETA
Where is the dme numbers? Ill post more pictures of the block and the wiring. Ill try and look for the numbers on the block. The car runs smooth and shifts good. Clutch is in good shape. When i let out the clutch when its in nuetral right when i start it the car will die. I have to let it out slow then give it gas then shell idle fine.
E30 in progress.
bimminge46 is offline   Reply With Quote
Old 01-23-2012, 11:32 AM   #64
TrippinBimmer
My Ride: Just Fast!
Glove box. There is a cover. So Remove it and u see a harness that plug onto this metal box. There will be a sticker on there probably saying bosch. Look for the lass 3 digits.
Alpine White M3
MaximumPSI Stage4
Old 01-23-2012, 01:38 PM   #65
bimminge46
Alright thanks. I will post the last 3 digits when I get home from work.
E30 in progress.
Old 01-23-2012, 06:50 PM   #66
bimminge46
Gents,
below is the picture of the dme sticker.
325i/is/iX
E30
M20/B25 (170hp)
87-91
0 261 200 173
Bosch Motronic M1.3
Where is the number on the block located? Is it below the exhaust manifold? How easy is it to get to?
E30 in progress.
Old 01-23-2012, 09:41 PM   #67
TrippinBimmer
My Ride: Just Fast!
Sounds like u have a 2.5l engine or a homebrew 2.7L but I doubt u have a stroker.
Alpine White M3
MaximumPSI Stage4
Old 01-23-2012, 10:00 PM   #68
bimminge46
Why is the speedo max redline 5k? Is this the wrong cluster?
E30 in progress.
Old 01-24-2012, 04:20 AM   #69
TrippinBimmer
My Ride: Just Fast!
Does everything work? Might swapped it out. What's does the badge on the trunk say? 325, 325i
Alpine White M3
MaximumPSI Stage4
Old 01-24-2012, 06:07 AM   #70
bimminge46
Everything works but the gears are broke in the cluster. (RPM works) Not sure why they would put a 5k rpm speedo. The car is debadged.
E30 in progress.
Old 08-03-2012, 02:09 AM   #71
bernzpeed
My Ride: 2001 325i
I sell a Dinan performance chip for this DME. You can upgrade the injectors from the 14# to 17# or maximum 19#. Pm me.
The i head has a casting no. With last 3 digits 885 located underneath the intake manifold.
Those hoses are not stock. Better change those out to original ones.
He might have swapped clusters before not knowing the difference.
Judging from the look if the intake manifold, it's a 325i engine.
Sent from my SPH-D710 using Bimmer App
bernzpeed is offline   Reply With Quote
Old 08-04-2012, 12:31 PM   #72
blacksport325
My Ride: 98 M3, 318is, CBR600
Those blue hoses look like a heater core hose from t-stat, and a vacuum hose from the intake manifold to CCV.
blacksport325 is offline   Reply With Quote
