Old 01-28-2012, 12:30 AM   #1
biMMer4.4i
My Ride: 2002 330i
2002 330i Headlight trouble
Bought the car a little over two weeks ago without a working xenon on the drivers side. Replaced the bulb (old one looked burned) but still didn't work. The following weekend the bulb was taken out again to look for loose connections. Still nothing. The car then sat for two days until I drove it today and the drivers side came on, and brighter worked too. It did look to be more of a yellow light than a xenon blue light though but still bright. The replacement bulb was identical to the original. Where am I going wrong? Any help is greatly appreciated.
Sent from my PC36100 using Bimmer
biMMer4.4i is offline   Reply With Quote
Old 01-28-2012, 01:06 AM   #2
Toofpik
My Ride: 2002 325ci
Does ur passenger light work fine? If so swap the bulbs and see what happens. Im no xenon expert but i did this when i had my old 330i and the passengers side was brighter and off color with both bulbs. A week later it just stopped working so i took it out and found out that water had got inside the balast and ruined it.
Toofpik is offline   Reply With Quote
Old 09-30-2012, 12:12 PM   #3
mpower009
My Ride: Tial Of Dragon
Hello Toofpik, I believe my Xenon headlights have the same issue as your situation. Here is my car symthom, only passenger side doesn't work. So I replaced to brand new bulb and still it doesn't work. Is this mean the balast is shot?
Thanks!
LET'S ROLL
mpower009 is offline   Reply With Quote
Old 09-30-2012, 12:21 PM   #4
98bimmer
My Ride: E90 330i, E36 328i
If its not the bulb its either the ballast or igniter, if its the igniter you have to take your lights apart to replace them. I believe for the ballast you don't need to but don't quote me on that! Switch those around and that will answer your questions!
98bimmer is offline   Reply With Quote
Old 01-04-2014, 06:41 PM   #5
gavi
My Ride: BMW 330Ci sport 6MT
HI I have the same problem, have you guy got it solved? what was it?
A BMW can't take you as far as a diploma.
Joyce Meyer
gavi is offline   Reply With Quote
