Rating:
Display Modes |
#1 | |
My original DIY guide was causing confusion with owners that had cars either in Europe or cars made before 9/99 and after 3/03. Their feedback led me to discover some new information regarding E46 power folding mirrors.
In shedding some new light on the issue, I managed to simplify and update the original power folding mirrors retrofit guide to include production build E46 cars from 1997 all the way to 2006 as well as European cars. However, there is still some mystery surrounding the memory bus ribbon mirrors after 3/03 that I discuss below. Let us begin.... For those of us that drive and parallel park in a big city or spend long weekends at the mall parked in those tight spaces between door dinging SUVs then this feature will come in handy if you got about $300 to $500 and a few hours of DIY time to spare. Otherwise, for free you can just fold in the mirrors with your hands. But who wants to do that when you can power fold your mirrors from the comfort of your driver's cockpit... ...or from the convenience of your key fob as you remote lock/unlock the car: PART ONE: BMW made at least four types of mirror control switches in as many as six colors for the E46 cars. On the top side the switches for the mirrors all look the same. However, what each switch really does can only truly be identified by the color of the bottom side of those switches (or also by the parts numbers). ![]() On the bottom side of the manual folding switch we have these three color types: -Turquiose bottom switches go with memory manual folding mirrors. -Black bottom switches work with non-memory manual folding mirrors. -Grey bottom switches are mainly found in European cars with non-memory manual folding mirrors. (Although not 100% confirmed these Grey switches may provide the tilt-reverse function on Euro cars with non-memory/non-powered seat) On the bottom side of the power folding switch we have these three color types: -Purple bottom switches will work on cars with memory power folding mirrors and memory power adjust seats. -Yellow bottom switches go with non-memory power folding mirrors on cars without memory and no power adjust seats. -White bottom switches go with non-memory power folding mirrors found on cars with memory power adjust seats. (This rare White switch is mainly found on pre 9/99 European cars that had this uncanny combination of memory power seats with non memory power folding mirrors) For the remainder of this DIY guide I will just refer to the switch as the color of the bottom side. So when I write the words "Yellow switch" it will be referring to a switch that has a yellow colored bottom. For early production year E46 and some European E46 cars you may come across a color bottom that is different from what I list here. There could be a multitude of reasons for that but for the most part 99% of E46 cars will have one of these 4 switch types in any of the 6 colors I've mentioned. PART TWO: BMW made two types of mirrors for the E46 cars: 1. Memory mirrors that operate in cars built after 09/1999 which have memory power adjust seats. ![]() 2. Non-Memory mirrors that operate in cars with no memory and no power adjust seats. Non-memory mirrors also come on ALL E46 cars made before 09/1999. ![]() PART THREE: The most important facet of the E46 mirrors that distinguish them apart is how they connect to the car. 1. Both Memory manual folding and power folding mirrors use identical 12 pin-connectors to receive memory, tilt and fold in/fold out commands from the car. ![]() ![]() These mirrors simply connect to the car via control modules also called memory modules. Both manual folding and power folding memory mirrors use the same control "memory" module that sits inside each door under each side mirror. These in-door control modules are what provide the mirrors with memory, tilt and power-fold commands. ![]() If your car already has power and memory seats then already it also has these control modules in the doors and you do not need to buy them or replace them when upgrading to power folding memory mirrors. ![]() Again I will reiterate when retrofitting memory power-fold mirrors onto a car with memory/power adjust seats you do not need to buy or replace these control modules. You also should not need to code the control memory modules to fold the mirrors. However, once installed the car will have to be coded to remote control fold the mirrors via the key fob under the convenience features. Cars that have an Intravee II running Version 6.02 installed can also be coded thru Intravee's i-Bus controller to have the mirrors "convenience" fold and unfold a bunch of ways. Said and done once installed these mirrors will immediately power fold and unfold right away with just the use of the power folding mirror switch. To update the switch you would need to only replace the turquoise manual folding mirror switch in your car with the purple power folding mirror switch. The switches both use the same connector and are direct plug and play. ![]() Once you have the power folding mirrors and the purple switch then the rest of the DIY is simple plug and play. This type of retrofit is more prevalent in the USA and Canada since more E46 cars in the USA came with memory and power seats. The DIY is also a simple plug and play project even for the eBay M3 Replica kits that work off the OEM purple power folding switch since the purple switch is all you would need to buy after you get the power folding mirrors. ![]() 2. In stark contrast, Non-Memory mirrors connect very differently to the car. Manual folding mirrors will connect to the car and the Black (or in some cars Gray) manual folding mirror switch using 6 pin connectors that have 5 or less wires leaving the mirror base. ![]() ![]() When you have Non-Memory mirrors that are power folding you will have 5 wires on the 6 pin connector at each mirror and a extra 2 pin connector with two wires leaving one of the mirrors. ![]() ![]() This 2 pin wire receives the fold in/fold out command from the Yellow or White power folding mirror switch via a non-memory power folding control module box that sits behind the glove box. ![]() This makes retrofitting Non-Memory mirrors onto a car with non-memory, manual adjust seats a bit more tricky because you need to buy the non memory power folding control module and install it behind the glove box in order to send the power fold commands to the Non-Memory mirrors from the power folding mirror switch. It is also unclear if this module would need coding to get the mirrors to fold right away from the switch. However, this type of mirror can be coded for the key fob remote "convenience" either using an aftermarket device or the OEM coding methods. ![]() ![]() A good thing is they are lots of aftermarket non memory power folding modules and parts that cater to the difficulties of installing non memory power folding mirrors in non-memory E46 cars. They are a few threads on them in the DIY section. More information on what kits to get can be found by using Google Search. You will also find this type of retrofit will be more prevalent in Europe and the parts of the world where more E46 cars did not come with memory or powered seats. ![]() 3. The E46 BMW Ribbon BUS Revolution of March 2003! ![]() In 3/2003 BMW extended the Memory BUS system to the mirrors which now used ribbon connectors. This created a new set of mirror part numbers for cars after 03/2003. ![]() The ribbon mirrors as they are called still used the same memory control modules as previously used in the 9/99 up to 3/03 cars that came with memory seats. So this retrofit would entail the same journey as before under the memory-power folding retrofit for cars 9/99 up to 3/03. Just get the mirrors and the switch and plug and play them. The only question is whether the car would need dealership coding to get the mirror switch and key fob to fold the mirrors. Furthermore it is another mystery as to what control module is used on the non memory manual adjust seat cars after 3/2003 for non memory power folding mirrors. The parts database does not show any specific control module that exists for non memory cars after 3/2003. ![]() The final and biggest mystery concerning the non memory mirrors is that the BMW P/Ns for non memory power fold mirrors stays the same from 09/1997 all the way to 2006. I'm not sure if that means BMW didn't update the P/Ns or the actual non-memory power folding mirror housing and wiring stays unchanged for non memory cars over the years. Meaning these cars do not use a ribbon BUS system in the mirrors. PART FOUR: Follow the letter guide below that most suits your current set up and needs before starting your DIY Project. Choose A if your car currently has manual adjust seats and no memory functions. Choose B if your car has electric seats and memory. Choose C if you want to retrofit power fold memory mirrors into your non-memory and/or manual-adjust seats. You can also Choose C if your E46 is a pre 09/1999 model and you want to attempt to add memory tilt power fold mirrors. If you have a USA spec LHD sedan or touring/wagon then simply use the P/Ns in the sections below to purchase your mirrors and parts. Memory power adjust seat cars already have the 2 control modules in the car so DO NOT buy them! I only listed it to show all the ingredients used to power fold the power folding mirrors. The prices listed below are the average suggested retail price of the parts as of 12/2011. I found the prices to be much cheaper at most of the forum's sponsor web stores (ECSTuning, GetBMWParts, Tischer and even Circle BMW and most online parts stores have much lower prices). If you have an M3, a Coupe, a Convertible or a Compact (ti) then use www.realoem.com to find your appropriate P/Ns for your car. The mirrors are listed under Vehicle Trim > Outside Mirrors. The switches are listed under Vehicle Electrical System > Switch > Various Switches, Cigar Lighter. The control modules are listed under Vehicle Electrical System > Control Units, Modules, Sensors, Relays > Body Control Units and Modules. If you have a European car that is RHD or LHD please refer to the www.realoem.com parts catalogue to find the P/Ns you need for your specific car. Sadly, I do not live in Europe anymore so I cannot tell you what will work on certain Euro E46 cars. USA mirrors have completely different part numbers than Euro LHD and RHD mirrors. Also the mirror pin connectors and wiring that receive the power fold and tilt functions are very specific to the orientation of the mirror relative to the driver's seat. So RHD mirrors and LHD mirrors are NOT INTERCHANGEABLE! This means a USA shopper cannot go on eBay.co.uk and buy European RHD power fold mirrors for his USA LHD car. With in Europe this distinction is also true for countries that have LHD cars and other countries that have RHD. A: YOU WANT TO INSTALL NON-MEMORY POWER FOLD MIRRORS: Car's production date is 03/2003 or later x1 Heated outside mirror, left P/N: 51168245129 $344.82 x1 Heated outside mirror, right P/N: 51168245132 $344.82 x1 Yellow Switch f mirror adjust./folding back function. P/N: 61318373732 $67.34 Car's production date is from 09/1999 up to 03/2003-6 PIN/2 PIN CONNECTORS x1 Heated outside mirror, left P/N: 51168245129 $344.82 x1 Heated outside mirror, right P/N: 51168245132 $344.82 x1 Yellow Switch f mirror adjust./folding back function. P/N: 61318373732 $67.34 x1Control Unit/module outside mirror fold-in function OBSOLETE-P/N: 61358376506 ** or Control Unit/module outside mirror fold-in function NEW-P/N: 61359177976 $83.78** Car's production date is from 09/1997 up to 09/1999 x1 heated outside mirror, left P/N: 51168245129 $344.82 x1 heated outside mirror, right P/N: 51168245132 $344.82 x1 European Switch f mirror adjust./folding back function. P/N: 61318373689 $67.34 or Yellow or White Switch f mirror adjust./folding back function. P/N: 61318373732 $67.34 x1 Control Unit/module outside mirror fold-in function OBSOLETE-P/N: 61358376506 ** or Control Unit/module outside mirror fold-in function NEW-P/N: 61359177976 $83.78** B: YOU WANT TO INSTALL MEMORY POWER FOLD MIRRORS: Car's production date is 03/2003 or later-RIBBON CONNECTORS x1 Heated outside mirror, memory bus, left P/N: 51167153087 $438.73 x1 Heated outside mirror, memory bus, right P/N: 51167153088 $438.73 x1 Purple Switch f mirror adjust./folding back function P/N: 61316901383 $67.34 -And you should already have in your car: x2 Control units, mirror memory P/N: 61356916054 $125.69 (x2) * Car's production date is from 09/1999 up to 03/2003 - 12 PIN CONNECTOR x1 Heated outside mirror with memory left P/N: 51167003437 $344.82 x1 Heated outside mirror with memory right P/N: 51167003440 $344.82 x1 Purple Switch f mirror adjust./folding back function P/N: 61316901383 $67.34 -And you should already have in your car: x2 Control units, mirror memory NEW-P/N: 61356916054 $125.69 (x2)* or Control units, mirror memory OBSOLETE-P/N 61356913364 (x2)* Car's production date is from 09/1997 up to 09/1999 No MEMORY Power Fold-In Mirrors are found in Parts Database! So during these years you can own a 3 series with non-memory/non-tilt power fold-in mirrors in a car that has memory-powered seats OR you can have a 3 series with non-memory/non-tilt power fold-in mirrors in a car that only has non-memory/manual-adjustment seats. *These Control units/Modules are already in your car and you do not need to buy them for the retrofit if your car seats are electric and have memory. Manual and Power Folding Memory mirrors use the same Control units/Modules. ** This Control Unit/Module for non-memory power folding mirrors sits behind the glove box and is not needed for 03/2003-on cars. This module will require purchase of a 12 pin connector harness: Socket housing 12 POL. P/N: 61138364664 $0.63 with pig tails and appropriate wiring for the retrofit project. C. YOU WANT TO INSTALL MEMORY TILT POWER FOLD MIRRORS ON A CAR THAT DID NOT COME WITH MEMORY SEATS: If your car production date is between 9/1997 up to 3/2003 then See Jared's brilliant thread on how to do that here: http://forum.e46fanatics.com/showthread.php?t=467677 D. ONCE YOU HAVE ALL YOUR PARTS THEN FOLLOW THIS WRITE UP: Written by Terry Kennedy on BFest.com way back in 9/2003 Quote:
Voila your E46 BMW now has a Premium Package 2 feature that comes on all current BMW models! Last edited by delmarco; 02-09-2012 at 01:05 AM. |
#2 |
Alot of great info thanks!
///UNDER CONSTRUCTION 323i///
18X9.5 Et33 V710 ![]() |
#3 |
Very comprehensive. Cheers
#4 |
Great post! Extremely Detailed!
![]() Roads? Where we're going we don't need Roads.. |
#5 |
Ok so I read all of your thread but there is still one thing that is confusing me. My car is a 2003 330ci which is made in march(03), it does have electric adjusted seats but it dosent have memory. Does this mean I have the memory controllers inside the doors or do I need to add them? Should I chose option A in this diy and if I chose option A does that mean everything is plug in play for me, meaning I just have to buy mirrors that have powerfold and the buttons to fold them?
#6 |
Ribbon mirrors are another beast altogether. Probably easier if you can find the folding mirrors (pretty rare from what i observed). Stock E46s in the US already have the connector for the folding motor - but obviously it's unused since there's no motor to plug it into. Or at least my zhp did - I never got around to testing it, but I believe the connector is live too.
So there's a couple ways you could go about it. You can try rigging another set of motors to the existing set of motors and using the unused connector. Or you can just find an 03/03+ folding motor (rare). On the module side, I don't think there's any wiring. It seems to communicate over a serial bus, and the module decides whether or not to fold based on what it is told by the GM5. Last edited by TerraPhantm; 02-22-2012 at 10:17 AM. |
#7 | |
So all I need is this: x1 Yellow Switch f mirror adjust./folding back function. P/N: 61318373732 $67.34 and two mirrors with autofold and ribbon conectors and everything should then be plug and play? Last edited by AquaRelliux; 02-23-2012 at 08:01 AM. |
#8 | |
I had a typo in there too... I meant to say that you could possibly rig a set of motors into the existing mirrors, code the car, and have functional folding mirrors for a somewhat lower price. |
#9 |
I don't get the part numbers from this post:
Car's production date is from 09/1999 up to 03/2003 - 12 PIN CONNECTOR x1 Heated outside mirror with memory left P/N: 51167003437 $344.82 x1 Heated outside mirror with memory right P/N: 51167003440 $344.82 x1 Purple Switch f mirror adjust./folding back function P/N: 61316901383 $67.34 -And you should already have in your car: x2 Control units, mirror memory NEW-P/N: 61356916054 $125.69 (x2)* or Control units, mirror memory OBSOLETE-P/N 61356913364 (x2)* So I would only need to purchase the above 3 items, but they are not M3 mirrors, correct? PS. my car was made in 06/02 Last edited by ruskisky; 04-29-2012 at 08:14 PM. Reason: added info |
#10 |
Delmarco, I am in the middle of retrofitting power autofold mirrors into my ZHP sedan. I'm just about done, except I haven't figured out how to code them yet... I've tried ISTA and a GT1 and can't find the right option...
Luckily, I have an Intravee--I just didn't realize that I could program the mirrors that way--I'll try that tomorrow. I'd prefer to figure out how to do it with the GT1 or ISTAP so that I could pass along this information to others who may not have an Intravee...
![]() 2004 330i ZHP (me) 2006 X3 (wife) 2004 325xi (sold) 2001 325i (passed on to DavidJay) MY DIY write-ups MY Garage (all the mods) |
#11 |
I just finished this retrofit in my 2004 BMW 330i ZHP sedan. I can confirm the following:
- You do indeed only need 3 parts for cars with ribbon connectors: both mirrors, and the switch. - You need to have the car coded to enable the mirrors. - The Intravee is unable to do the initial coding to enable the mirrors to fold. - The dealer is unable to code the car to have the mirrors work. This is because there is no "retrofit" available to add this option to the car. The dealer's tools, (GT1 and ISTA) are unable to make the changes. - To enable the mirrors to work, you need to: 1. Change the Vehicle Order (VO) of the car to include option 313 2. Code the General Module - This can only be done with special software that can change the VO. I used an Autologic to do this. Autologic is the software program that many BMW independent repair shops will use. The other tool is something called NCS Expert, which was a BMW factory tool that dealer’s did not have access to. I have not tested enabling the mirrors with NCS Expert, but it is capable of changing the VO, so it should be possible as well.
#12 |
So I just enabled an additional feature of these folding mirrors. Check this video out. You can fold / unfold the mirrors by holding the lock and unlock button respectively.
So cool. And super useful for me, since I have to park on the side of a busy road to pickup my daughter every day from school. BTW, for the newer than 03/03 cars this needs to be done with something like an Autologic or NCS Expert. To enable it via Autologic, under: CAR/KEY MEMORY >> CENTRAL BODY ELECTRONICS >> WINDOW REGULATORS enable: CONVENIENT CLOSING RC and CONVENIENT OPENING RC. This is actually the setting for the windows to roll up with the key remote. But if you have the 313 option code in the car to enable power windows, this setting will enable the windows to fold in by the key remote.
#13 |
Finally got around to doing this retrofit.
#14 |
I tried PM'ing delmarco, but his PM box is full so I'm just going to ask here since I'm slightly confused. I ordered the purple switch for my car, 03 325i prod date 12/02 with power/memory seats and mirrors, but do I still need to order the control modules? If I read correctly then I should be able to install the switch and be good to go. Can someone clarify for me please? TIA.
BMWCCA Member #461128
2003 Jet Black 325i ZPP, ZCW Mods: P46's with Orion V2's | Cosmos Racing Cold Air Intake | UUC Underdrive Pullies | H&R/Koni | Staggered Style 119's | Clear Corners/Sidemarkers/Tails | Bimmerbrakes Stoptech Slotted Brake Upgrade | BimmerBrakes Headers | Magnaflow Catback Exhaust Soon to Come: Shark Injector |
#15 |
#16 |
You need the mirrors themselves.
#17 |
My Ride: E46 Coupe
I was able to code the mirrors to open and close using the keyfob a couple months back by means of NCS Expert. Previous owner attached the folding mirrors and the switch but initially I wasn't sure if I needed additional parts for the folding (with the key).
One issue though, when the mirrors unfold the drivers side mirror clicks when it reaches the bottom for about 10 seconds. It looks like I'll have to replace that mirror.
![]() ________________________________________ BMW Coding, PM Me For Details 3 Series Owners Manuals http://www.bmwsections.com/docs/3series/ For Sale (Exterior Lights) |
#18 |
My Ride: BMW 2000 328I w/SP
I have questions I have a pair of E46 M3 Style Side Mirrors but, I got the wrong ones I needed the ones with the 12 pin connection and not the 6 pin because I have heated seats and memory seats.
Is there any adapter I can get to plug into the 6 pin to make it a 12 pin connection?
Bigwen©Productions
#19 |
Thanks for adding the info Terraphantm and SNA77! I been out of the country for a bit and busy with wedding stuff so forgive my absence!
#20 |
Great post from delmarco as always. On todo list.
![]() Part out - Beige/Tan Interior http://forum.e46fanatics.com/showthread.php?t=836111 Stock 330i/325i exhaust w/ Magnaflow Cats http://forum.e46fanatics.com/showthr...831&highlight= |
