Old 01-28-2012, 01:26 PM   #221
DutchE46
My Ride: E46,V12 E30
Originally Posted by e popa View Post
sell it and get a m3
While buying an m3 is an option. It wl hurt me to sell my 323 any advice Jacob?
Uploaded with ImageShack.us
DutchE46 is offline   Reply With Quote
Old 01-28-2012, 03:11 PM   #222
jacobs323i
My Ride: blown 323i
ya your goals are easily hit in our cars, 300 rwhp is no problem on a twinscrew supercharger and a tiny shot of nitrous.
jacobs323i is offline   Reply With Quote
Old 01-28-2012, 04:09 PM   #223
ghettoracer
My Ride: 2000 323i, 91 nsx
jacob: dyno sheet?
N1 Concepts 2012 | AKMEE Engineering Est. 2004 | G.SPEED Racing Est. 1995
My Bizarre and Twisted Reality Blog is Back! ghettoracer.wordpress.com
ghettoracer is offline   Reply With Quote
Old 01-28-2012, 04:14 PM   #224
Rob43
Rob43's Avatar
My Ride: 03 331Ci 5spd R1200R
Agreed, but an expensive route of obtaining 300 WHP.
If it were me, I'd go this route.
First I'd get the motor breathing as good as possible, cost without installation is about $2800 for items 1-5.
1) Head work: Porting Intake & Exhaust, Race Valve Job, Port Match Intake & Exhaust, Surface / only if needed.
2) Cams: 264/252
3) Header
4) CAI, Long Tube
5) Power Pulleys
6) Direct Port Nitrous, 35-150 WHP. Your stock internals will handle these numbers when progressively sprayed. So you could easily make more than 300 WHP, & what's even better is the WTQ output of a system like this. I'd go as far as saying that this exact setup on your 2.5L 323 would walk a stock Vette.
A DP nitrous system with all the safety devices would cost $1500-$2000.
Good luck.
SUMMIT POINT WV 1:24:229 SCCA
Old 01-28-2012, 11:58 PM   #225
DutchE46
2) Cams: 264/252
3) Header
4) CAI, Long Tube
5) Power Pulleys
Good luck.
Rob thank you bro for the break down this is what I needed man!
Old 01-29-2012, 12:43 PM   #226
ritos530i
My Ride: 2004 E60 530i 6speed
Send a message via MSN to ritos530i Send a message via Yahoo to ritos530i
Do not forget to add a clutch!
530i E60 Custom Turbo/Nitrous (PSI_unknown)
ritos530i is offline   Reply With Quote
Old 01-29-2012, 03:02 PM   #227
SweTurbo
Big Pimpin'
My Ride: 323i -98
Originally Posted by bluejeansonfire View Post
word! is that how it's done in Sweden?
After a night of calculations on basepressure and stuff totaly unrelated to car engines , yes
Late response is late
Old 01-29-2012, 07:47 PM   #228
jacobs323i
My Ride: blown 323i
2) Cams: 264/252
3) Header
4) CAI, Long Tube
5) Power Pulleys
Good luck.
I respect your knowledge on the subject of our platforms, and yes what you are recommending is a good path but if he has a decent budget I would just go twinscrew and nitrous.
Old 01-29-2012, 07:50 PM   #229
jacobs323i
My Ride: blown 323i
Def. going to need a new clutch. If you pull the trigger on f/i pm me and I will hook you up with a smoking deal on a clutch master 6 puck seg kevlar stage 3 with less then 7,000 miles.
Old 01-30-2012, 12:12 AM   #230
ritos530i
HUH, I've had a clutch and lightweight flywheel for years and FI. LOL
Stage 3+
Old 01-30-2012, 01:10 AM   #231
DutchE46
How much is a twinscrew and where can i find it
Old 01-30-2012, 01:38 AM   #232
DutchE46
So im thinking of going with this guys..(http://www.esstuning.com/products/M5...28TS1%29-.html) give me your inputs they claim 280hp and 320tq
Old 01-30-2012, 12:06 PM   #233
jacobs323i
My Ride: blown 323i
Stage 3+
i think you misread I was quoting you but talking to Dutch, I know you are f/i and that would lead me to believe you all ready have a clutch lol.
Old 01-30-2012, 12:07 PM   #234
jacobs323i
My Ride: blown 323i
this was the exact unit I was telling you about. Like I stated earlier if you need a clutch upgrade I have a good one for ya cheap just let me know. You will be very happy with that twinscrew!
Old 01-30-2012, 02:59 PM   #235
DutchE46
I think i should do a tranny swap before doing this. I still got a Slush box on mine. So what i might do is swap the tranny then just save up get the stage 2. I think it fits more what i want. And i should be done
Old 01-30-2012, 06:48 PM   #236
Rob43
Rob43's Avatar
As I respect yours.
There is certainly nothing wrong with going this route, but lets take a good look at actual WHP output.
The Stage 1 is rated at 280 DIN, which is 276.2 Crank HP.
The Stage 2 is rated at 310 DIN, which is 306 Crank HP.
Though when you factor in ESS's drivetrain loss of 15% for the WHP calculations, things go downhill quick. Most would agree that a 17% or more drivetrain loss would be even more realistic on a rear wheel drive car.
Then of course this is all being done on a Dynojet dyno, the highest HP producing dyno out there.
http://forum.e46fanatics.com/showthr...465&highlight=
276.2 X 0.85 = 235 WHP, or at 17%....276.2 X 0.83 = 229 WHP
306 X 0.85 = 260 WHP, or at 17%....306 X 0.83 = 254 WHP
Rob
Old 01-30-2012, 06:53 PM   #237
TrippinBimmer
My Ride: Just Fast!
Just boosted as let it rip jk but I'm planning to swap to a m 6speed soon.
2005 AW/IR M3
MaximumPSI Stage4
993whp/651wtq SAE Corrected
2005 JB/BLK 330i ZHP
Stock
NAwhp/NAwtq SAE Corrected
1996 BLU/BLK M3
Stock
1988 SETA 325I
Stock
Old 02-29-2012, 03:13 PM   #238
BigDRick323
My Ride: 2000 323i
Dyno sheet???!?!?!?!?!
Old 02-29-2012, 03:22 PM   #239
lab rat
My Ride: '02 330iT
I got some experience with ESS twinscrew.
Stage 1 on M54B25 pulled 243whp on mustang dyno (would have been around 250 on Dynojet). That car was real fun to drive. Instant throttle response, flat torque curve.
I still think it's better option than messing with NA (mostly gains in the high RPMs) and nitrous (damn, my tank is empty again!)
Because sleeper
Old 03-01-2012, 12:17 PM   #240
jacobs323i
My Ride: blown 323i
My car exploded into a million pieces so a dyno sheet is no longer entering my mind!
