Forced Induction Forum Sponsored by Active Autowerke
Discuss supercharging, turbocharging and even nitrous and water injection here. Sponsored by Active Autowerke |
#221 |
While buying an m3 is an option. It wl hurt me to sell my 323 any advice Jacob?
#222 |
#223 |
My Ride: 2000 323i, 91 nsx
jacob: dyno sheet?
N1 Concepts 2012 | AKMEE Engineering Est. 2004 | G.SPEED Racing Est. 1995
My Bizarre and Twisted Reality Blog is Back! ghettoracer.wordpress.com |
#224 | |
If it were me, I'd go this route. First I'd get the motor breathing as good as possible, cost without installation is about $2800 for items 1-5. 1) Head work: Porting Intake & Exhaust, Race Valve Job, Port Match Intake & Exhaust, Surface / only if needed. 2) Cams: 264/252 3) Header 4) CAI, Long Tube 5) Power Pulleys ************************************************************ ************************** 6) Direct Port Nitrous, 35-150 WHP. Your stock internals will handle these numbers when progressively sprayed. So you could easily make more than 300 WHP, & what's even better is the WTQ output of a system like this. I'd go as far as saying that this exact setup on your 2.5L 323 would walk a stock Vette. A DP nitrous system with all the safety devices would cost $1500-$2000. Good luck.
![]() Rob #43 ITS/ITR/STU, BMW 325I, STU LAP RECORD SUMMIT POINT WV 1:24:229 S.C.C.A. http://www.vimeo.com/8486878 (Dyno Video) ........add a sh!tload of cowbell. |
#225 | |
#226 |
My Ride: 2004 E60 530i 6speed
Do not forget to add a clutch!
![]() ![]() ![]() 530i E60 Custom Turbo/Nitrous (PSI_unknown) |
#227 |
Banned User
#228 | |
#229 |
#230 | |
Stage 3+
#231 |
How much is a twinscrew and where can i find it
#232 |
So im thinking of going with this guys..(http://www.esstuning.com/products/M5...28TS1%29-.html) give me your inputs they claim 280hp and 320tq
#233 |
#234 | |
#235 |
I think i should do a tranny swap before doing this. I still got a Slush box on mine. So what i might do is swap the tranny then just save up get the stage 2. I think it fits more what i want. And i should be done
#236 | ||
The Stage 1 is rated at 280 DIN, which is 276.2 Crank HP. The Stage 2 is rated at 310 DIN, which is 306 Crank HP. Though when you factor in ESS's drivetrain loss of 15% for the WHP calculations, things go downhill quick. Most would agree that a 17% or more drivetrain loss would be even more realistic on a rear wheel drive car. Then of course this is all being done on a Dynojet dyno, the highest HP producing dyno out there. http://forum.e46fanatics.com/showthr...465&highlight= 276.2 X 0.85 = 235 WHP, or at 17%....276.2 X 0.83 = 229 WHP 306 X 0.85 = 260 WHP, or at 17%....306 X 0.83 = 254 WHP Rob
#237 | |
My Ride: ZHP Custom Stage 3.5
jk but I'm planning to swap to a m 6speed soon.
..::|TrippinBimmer's Boost Build with Cool Parts|::.. 4**whp/3**tq SAE Corrected |
#238 |
Dyno sheet???!?!?!?!?!
#239 |
I got some experience with ESS twinscrew.
Stage 1 on M54B25 pulled 243whp on mustang dyno (would have been around 250 on Dynojet). That car was real fun to drive. Instant throttle response, flat torque curve. I still think it's better option than messing with NA (mostly gains in the high RPMs) and nitrous (damn, my tank is empty again!)
Because sleeper.
#240 |
