Sponsored by BAVSOUND
Thread Tools Search this Thread Rating: Thread Rating: 431 votes, 5.00 average. Display Modes
Old 01-20-2012, 05:55 PM   #61
reigate
My Ride: e46
Originally Posted by mistapony View Post
Yeah mine is a d99 universal unit, got it off of ebay
One of the experts needs to jump in here however I don't believe that a normally formatted micro SD card will permit an upgrade to be performed.
reigate is offline   Reply With Quote
Old 01-20-2012, 09:14 PM   #62
tasi333
My Ride: 330Ci Convertible
From the first post:
Either use the SD card that came with the Dynavin, or downloaded EaseUS, and format a 2 GB card as FAT (FAT16) with 64kb allocation.
So for the best results, try and find a 2GB card and use it only for upgrades.
Then just follow the instructions on the first post. Once you press the NAVI button to go to the android side, you should see a screen that shows it's running the upgrade process, the Dynavin logo shouldn't show up at all. It should take about 10 minutes to complete.
2002 330 Cic Topaz Blue
VMR 701; Front 19x8.5et35 225/35; Rear 19x9.5et45 245/30 | Spacers: 15mm front; 12mm rear | Megan Racing Coil Overs | Short shifter | eBay Strut Bar | Angel Eyes | LED Tails | Dynavin (Droid) | Vanos | DISA
*My Car Thread (Pics & Mod details):
http://forum.e46fanatics.com/showthread.php?t=873246
tasi333 is offline   Reply With Quote
Old 01-20-2012, 11:13 PM   #63
mistapony
My Ride: volvo v70r
I've given up the unit is gonna go back. All apps seem to fail downloading and I can't get the unit to install a new rom. The touch screen seems hard to scroll with also, I end up clicking a cell instead of scrolling. Very frustrating was really hoping this head unit was gonna rock.
mistapony is offline   Reply With Quote
Old 01-21-2012, 04:08 PM   #64
opey
My Ride: 04 M3 coupe
if u use ur fingernail (or a stylus) it scrolls fine. and if the SD card is formatted right, it will update
IR/IR 6 speed
opey is offline   Reply With Quote
Old 01-21-2012, 06:21 PM   #65
Darkoz
My Ride: E46 325Ci
It does Rock but you just don't know how to Roll
Darkoz is offline   Reply With Quote
Old 01-22-2012, 11:32 AM   #66
navman01
My Ride: 2004 318i E46
Originally Posted by mcondruz View Post
Hello
I have an issue with my Dynavin sd card. the card is not loading. I am sure it is correctly formatted and the device hardware is functioning (since the ROOM replacement is working when I update it with the latest Dynavin firmware).
However, after the system is loading I can see no card. I tried more cards, including the one which have the firmware. Nothing.
For more info I tried with those cards:
- one 2Gb card Fat 16 formatted
- one 2Gb card Fat 32 formatted
- one 8Gb card Fat 32 Formated
Partitions are Primary and Active on all of them. Still nothing.
It is also important to say that yesterday was working, I moved the IGo from the original card to the bigger one (8Gb), intalled it, tested it, etc..
Today, nothing. My Igo is saying he need the sd crd. I reloaded the firmware (wipe all the data with this ocasion and I loaded it from sd card which for purpose was working). When system is booting, still nothing.
Any idea?
The softwares on the market like reload the sd card specific softwares are also ineficient . Please help. I am almost sure it is a Android system issue.
+1
~ SD ~
Similar issue here, the stock SD card (2gb) was working, I downloaded MapDroyd Maps to the device and then even updated to 2.2 with it. Cant confirm that it happened after the update.
I go to download the Speech Synthesiser for Google Nav but kept getting a need more than (6 by memory)mb of storage.
Ive been able to get the SD to work for a few seconds when mounting, then formatting, then not getting a response from MayDroyd saying that I dont have an SD card which was good but it appeared to fail on me again. It doesnt appear to last long.
Also had a corrupt sd card notification, formatted but it still buggy. Anyone else having similar issues? Im about to try an old 1gb SD card and see how that goes.
SolutionUpdate=== Played around with the sd card and eventually got it formatted on the android d99 unit and its working now with all SD cards, just have to be careful when mounting, unmounting. For me I will only mount while in the android side, in the sd settings menu where I can see the mount sd button,
1. Insert sd card
2. Tap Mount sd card
For dismount I again only do so when in the sd card settings,
1.Tap unmount and wait a few seconds after confirmation of dismount.
Do not put the left side sd in the right side sd of the unit, the card gets a "requires format/damaged sd card" once its back in the left side (nav)
SD Card formatting
Originally Posted by jneumann View Post
Ok, quick update:
I got bored, so I started hacking at the Android side. It appears to be very similar to the TI OMAP35xx hardware used in the BeagleBoard. Android is not designed to run natively on this hardware, so it is emulated in qemu with something called Goldfish.
I managed to figure out how to extract the ubi.img file, edit the contents, and rebuild it to something flashable. (currently running my own "custom rom" right now)
I also have root. Working on the force close issue right now. It reared its ugly head ONE REBOOT after first boot, after installing Titanium Backup (root). I'm assuming it has to do with having so little memory to work with on these devices. (128mb I think?)
I plan to release a slightly tweaked version of Dynavin's last release, with out 3g (I don't use it, and I'm assuming most of us here don't, so it's a pointless kernel module to load) and with a bunch of the preloaded apps either removed or updated. It will also be rooted, or at very least root-ready.
Little start to the information -
How to format ANY SD card so the Android side will boot it and load the firmware off it
Must be FAT (otherwise known as FAT16), and set as active. This means no more than 4gb. (you can use larger, but you will have to reformat after to get the rest of your space back)
I used EaseUS Partition Manager to do this. It's free, and is less pissy than Window's disk management, and easier to use than DISKPART.
All you have to do is delete the partition on your SD card (helps to have a dedicated reader here, most phones probably won't work for this), create a new primary FAT(16) partition, and set it to active. Apply changes, wait for it to sync with the OS. Then just load the update files like normal.
From what I've heard, and what I have experienced over the last several hours, it is VERY hard to brick the Android side. (granted, all I've messed with is ubi.img)
Jeff just sent me the magical app that does all this, and I would recommend just doing it the way I just explained if you know anything about partitioning, or are willing to risk messing up an SD card. It is pretty hard to really mess one up though. 98% of the time you can reformat the SD card back to what it should be using a lower level partition manager like DISKPART or EaseUS. PM me if you really b0rk one, and I'll try to help.
Anyways, the reason I suggest using EaseUS is because I'm not a huge fan of using programs that I can't understand due to it all being in Chinese.
Regarding further development:
I would love to get AOSP Gingerbread working on this thing, but it may be out of my knowledge area, and given I only have time on weekends to work on this, I may never get around to it, much less release a working 2.3 ROM for the Dynavin. If anyone here knows anything about Android development and would like to help, PM me. I'll need it.
Other things I'd like to try to do is get some sort of Bluetooth adapter working so we can use Torque. This may also never happen though, since Torque is a HUGE CPU and RAM hog. My HTC Desire died a little while back, so now I have a low end Samsung Acclaim and Torque runs like sh1t on it. The Dynavin is even lower end hardware than the Acclaim, so Torque may be an impossibility for us.
Big Bold Disclaimer: If you don't easily, fully understand what I am talking about in this post, you are best off not doing or following any of it. I am not responsible for anything bad happening, such as bricked SD cards, Dynavins, things starting on fire or going bump in the night. You have been warned.
In other issues
~ USB ~
My 4GB USB seems to have been converted to FAT (64KB allocation size) and Ive been having everything from freezes/hangs to inability to error codes regarding not having sufficent privileges on my Windows 7 (Im an admin... which makes things interesting). Also it keeps saying it is write protected... I managed to put a few files on while plugged into the pc then all of a sudden it was write protected.
Trying to format to FAT 32 defaults and its just not letting me, or at least it does but it just takes way to long to do and appears to freeze
~ Voice Input ~
-Has anyone had an issues or has been able to get their microphone to function on the android side of the d99. (Voice input a destination, Shazam a song, or make a memo etc)
~ Bluetooth ~
Has anyone else gone into their android side setting tried to turn bluetooth on, only to get no change aka switched off still aka Turn bluetooth on message still displayed.
Also any app that requires bluetooth and it asks you to turn it on, when you go to do so, the unit freezes on me.
Has anyone figured out how to trick bluetooth streamed music(radio side) into working on android side. Jeff has mentioned a push NAV and then mode to get it to work
Originally Posted by jeffb325@DynavinSolutions View Post
For the streaming/nav conflict thing, its not perfect but there is a workaround, press the mode/source button first, then select nav. Somehow it tricks/confuses the controller and the audio continues to stream from bluetooth even though the video switches to the nav/android side. But sending any number of commands will cause it to switch off, so in that case you are best off just plugging into the ipod plug.
but this hasnt worked for me. However I randomly got it to work on android side once, and attempted to replicate what I think i did but no luck on doing it again
~ Erase and go to Factory default ~
Ive already tried doing this and have not been able to actually go back to factory default for android, my apps are still there.
"Solution" (Getting around it by reinstalling Android firmware)
~ Android side media ~
Originally Posted by mdh View Post
Anyone know of a way to get usb (music and video files) to work on the android side? I can get a hub to work with the supplied wifi radio but the media files will not show up in android.
I can plug in a thumb drive or even a hd to the android usb via a hub and i get a message "preparing udisk" but that is it. I can not locate the files anywhere...
If I pull the drive it will give me one of those messages to unmount udisk berfore removing.
Any ideas?
+1 again on this.
I'm assuming that if you own an android mobile you can somehow connect to and stream your media across it?? 0.o? Anyone?
~SD CARD SIZE~
Anyone have any idea what the max size possible for the d99 unit is?
Originally Posted by R75 View Post
I have a 32GB Class 10 Samsung SD card running successfully. I am told it should go to 64GB but that is beyond my needs, so havent tried that.
I'm currently using a Kingston 16gb SD card no problems.
~Apps requiring an internet or data connection fail to work / .COM .NET ERRORS?~
Originally Posted by navman01 View Post
AngryBirds, GarminMechanic, DigitalSpeedometer Free, MapDroyd (edit: this had no issue, completely offline app), Market at one stage was no going to net by memory, Navigation etc
Started have force closes, after using a friends phone, HTC Android to tether his 3g data connection to my unit.
All the force closes are "com" 99% of the time or "net"
to solve this issue with all internet or data required apps crashing, I reset data on pretty much all google apps, i think i was successful on settings storage reset.
Everythings working no problems now 2hrs in
SOLUTION:Update 9/feb/12: Clearing your settings storage cache/data will fix the issue, I have now used a mobile twice and each time after use attempting to connect to my wifi at home failed so cleared the cache/data fixed the problem, only side effect is that you lose the SHORTCUTS on your menu android side, but are still all there in the alphabetical listing.
~ FREE OFFLINE TURN BY TURN VOICE NAVIGATION ~
I mentioned MapDroyd before which is a great offline worldwide map, but I need that voice nav.
There is NavFree however you still need a data connection to search for addresses.
Does anyone know anything thats available? Ive been looking around but nothing truly offline and free Might buy Sygic, Im glad they offer a trial because Id hate to buy an app only to find it doesnt bloody work on my android d99.
However I have been able to get Google Maps Navigation to work "offline".
Parked in my garage I got the directions to my destination, and drove away. It worked fine, however I did not have the voice synth installed (my sd issue leading to download issues) so cant confirm if that would work.
Only downside is that when you go to close the app mid drive, it will cancel navigation and wont remember the route... bummer.
Lots of things to discuss, hoping to provide as much as I can as I learn about this unit and android.
Last edited by navman01; 02-09-2012 at 01:48 AM. Reason: More issues with the d99 unit... What the hell dynavin, terrible
navman01 is offline   Reply With Quote
Old 01-24-2012, 01:15 PM   #67
Danoff
My Ride: '04 330i ZSP
Originally Posted by tasi333 View Post
  1. TimeZoneFixer - the dynavin has the 2009h version of the database, this will copy over the 2011h version (https://market.android.com/details?i...m9uZWZpeGVyIl0.)
  2. ClockSync - setup to sync every 15 minutes; enable local database, and set it to sync on boot (https://market.android.com/details?i...Nsb2NrU3luYyJd)
GPS Configuration file (may help get a faster GPS fix)
  1. Copy the gps.conf file onto your sd card.
  2. Make sure you go in to settings and enable USB debugging, and allow non market apps.
  3. Make sure your date and time are correct (manually), then check the auto update setting.
  4. Download root explorer and copy over the gps.conf file to your /system/etc folder (https://market.android.com/details?i...RleHBsb3JlciJd)
  5. Get GPS Status and Toolbox (https://market.android.com/details?i...HNzdGF0dXMyIl0.)
    Startup GPS Status and toolbox, reset the AGPS data and download again. Change the settings to download as frequently as possible.
Originally Posted by Danoff View Post
Anyone tried this? Can anyone report on whether it works?
Bump.
Danoff is offline   Reply With Quote
Old 01-24-2012, 02:14 PM   #68
tasi333
Bump.
I don't think the GPS Config file made a difference, but it doesn't hurt to have it.
The TimeZoneFixer and ClockSync definitely help get things going faster as long as you have an Internet connection already.
Old 01-26-2012, 06:01 PM   #69
opey
can anyone do me a favor, and check their CPU speeds, with such as the AnTuTu CPU Master app. mine is ALWAYS at 500 mhz, no matter what i change the settings to. even when i set max at 250mhz, or max at 720 and min at 600, it always just stays at 500. im wondering if this could be related to my android music problems.
IR/IR 6 speed
Old 01-27-2012, 07:12 PM   #70
anchorman123
My Ride: BMW
Superscript keeps on freezing on me... anyone have any suggestions?
anchorman123 is offline   Reply With Quote
Old 01-30-2012, 10:41 AM   #71
wshgrntd
My Ride: 2007 335i m-sport
Since dynavin uses the stock harness is there anyway to hook dice up to it and use it for satellite radio?
wshgrntd is offline   Reply With Quote
Old 01-30-2012, 03:27 PM   #72
Fooljam
My Ride: 5
Guys,
Those with a rooted and non rooted D99 platforms, could you please try the iBus application for Android we are making just to see if it works on those using the Dynavin CAN bus adapter.
We have not touched this application in 2 months due to the lack of hardware availability, so I would appreciate if anyone could try this on.
Also, once installed, could you please run a LS command (Those with a terminal emulator or else) under the /dev folder and send me the output back.
Password to unrar: xl8U>1C<.tM267E
Many thanks in advance
Fooljam is offline   Reply With Quote
Old 01-30-2012, 05:56 PM   #73
m3evolution
My Ride: M3
Is it possible to get your app to work with Resler IBUS adapter? http://www.reslers.de/IBUS/index.html
I still have one these laying from when I had my CarPC installed. It worked great I was able to control the Windows PC from the steering wheel and other data on the IBUS line. Im pretty sure Android can read the IBUS data if plugged in via USB.
Let me know and ill try to test it.
Originally Posted by Fooljam View Post
Guys,
m3evolution is offline   Reply With Quote
Old 01-30-2012, 06:07 PM   #74
Fooljam
My Ride: 5
It does work with Resler's and anything else using the same chip
HTH
Old 01-31-2012, 05:11 AM   #75
R75
My Ride: Rover 75
+1
@navman
Lots of questions and problems in there but here goes on some of the issues:
SD card size
2 GB SD Boot Card
You have to remember that you must make the card "Active" just like a Harddisk partition before formatting. I use Easeus Partition Manager (free) for both - FAT16!
USB formatting
I am using an 8GB USB stick and have no issues. Never tried formatting (just quick format in Win7).
Android Voice
I may be wrong here, but I think it requires that you insert the external microphone in the back of the unit.
Bluetooth
You have to install an external bluetooth usb stick. I have a passive USB hub with a WiFi and a Bluetooth adapter. Both works (although WiFi is a bit flaky).
Bluetooth connects the service connector for use with Torque Pro.
An oddity is that Android will report "Paired but not connected" even if it is.
Google Maps (Voice)
If you start your journey while you have internet access you can disconnect and will get turn by turn direcetions all the way. I have google voice loaded and it works!!! Also off line.
.com and .net errors
In my oppinion the Android board in Dynavin has a very unreliable I/O. I have never experienced anything so flaky in my long life with IT (30+ years). Network connections bounce on and off, and many of the Android apps have issues with the communication (ie. Navigon). I don't think any other Android 2.2 unit in the market would survive with those stats.
I hope this is being addressed in the next update of the FW.
Rover 75 CDTi (BMW pretender)
R75 is offline   Reply With Quote
Old 01-31-2012, 06:42 AM   #76
Lassen90
My Ride: 1994 E220
@navman
SD card size
2 GB SD Boot Card
USB formatting
Android Voice
Bluetooth
Google Maps (Voice)
Hello. Can you specify what do mean by making the 2gb card active?
thanks
Lassen90 is offline   Reply With Quote
Old 01-31-2012, 07:08 AM   #77
listermint
My Ride: E46 M3 '02
thanks
i presume he means, formatting to the correct format, and maybe partitioning the card also.
listermint is offline   Reply With Quote
Old 01-31-2012, 08:04 AM   #78
R75
My Ride: Rover 75
thanks
Mark a partition as active
Marking a partition as active on a basic disk means that the computer will use the loader (an operating system tool) on that partition to start the operating system.
Old 01-31-2012, 08:12 AM   #79
Lassen90
My Ride: 1994 E220
Thanks I foundt out what you meant by it.
Old 01-31-2012, 12:36 PM   #80
jneumann
My Ride: 323i, 530i, Z4 3.0i
Send a message via AIM to jneumann
Woah, I've been kinda spacing out the last few weeks in relation to Dynavin stuff, does this mean that app + resler's v6 USB dongle = steering wheel controls mappable in android? (i.e. previous/next, home and back?)
E46 323i Sport/5 speed | 243k miles
E85 Z4 3.0i Sport/6 speed | 117k miles
E83 X3 3.0i M-Sport/6 speed | 130k miles
E39 530i M-Sport/5 speed | 237k miles
Member, Three Pedal Mafia | Long informative article on oil | BITOG German Castrol FAQ
jneumann is offline   Reply With Quote
