Thread Tools Search this Thread Rating: Thread Rating: 9 votes, 5.00 average. Display Modes
Old 02-02-2012, 08:40 AM   #41
330ciandr6
My Ride: .
Send a message via AIM to 330ciandr6 Send a message via Yahoo to 330ciandr6
You just need to see if you have the pins on the slip ring for the paddle shifters.
Have a oil or coolant leak? Click here!:http://forum.e46fanatics.com/showthr...732&highlight=
ABS/DSC/Brake/Airbag light on?? Click here!:http://forum.e46fanatics.com/showthr...648&highlight=
330ciandr6 is offline   Reply With Quote
Old 02-02-2012, 11:02 AM   #42
Nervous
My Ride: 01 330CI 6MT ZSP EU3
Originally Posted by thompels View Post
nice DIY,
i want to try in my n46,
i just asking the BMW service, they said i have to change my slip ring, but i check in web, my slip ring part number code is same with 330CI.
Your slip ring most likely doesn't have two pins for paddle shift (neither 330ci has them, at least my 2001 didn't). You need a slip ring from e46 M3 SMG, p/n 61318379091. However, as far as I remember some 61318379091 may have those pins and some may not, so you need to clarify this before purchasing.
Nervous is offline   Reply With Quote
Old 02-02-2012, 11:03 AM   #43
Nervous
BTW, DIY for harness is here: http://forum.e46fanatics.com/showthread.php?t=895897
Old 02-02-2012, 12:30 PM   #44
TrippinBimmer
My Ride: Just Fast!
http://forum.e46fanatics.com/showthread.php?t=895762
I also have the Paddles and Switches with the Screws...
Alpine White M3
MaximumPSI Stage4
993whp/651wtq SAE Corrected
Old 02-02-2012, 01:55 PM   #45
330ciandr6
My Ride: .
Actually, all brand new ones have them. Bmw quit making the ones that dont have them, they all superceded to a new part number that all have them (the 61318379091).
But none of the non smg cars came with the ones with the pins.
Old 03-07-2012, 11:47 PM   #46
thompels
My Ride: 318i e46
i just check it and mine already have 2-pin in slip ring.
and i also make the tutorial modification of SSG paddle shift to make it works.
just visit : www.modifikasimotors.com
thx
thompels is offline   Reply With Quote
Old 04-12-2012, 07:40 PM   #47
jizzzoe
My Ride: is no longer E46 :(
Send a message via Yahoo to jizzzoe
Subbed because I'm bouts to buy an SMG wheel with paddles for $200!
My Steel Gray '03 330Ci... I miss you, baby!
MODS: Purely aesthetic… Shadowlined, Smoked and LED'd out!
jizzzoe is offline   Reply With Quote
Old 04-13-2012, 05:32 PM   #48
330ciandr6
My Ride: .
It's fun!
Old 04-13-2012, 05:41 PM   #49
Nervous
The only negative side of this retrofit is a desire to have of real manual car that comes after some time.... That is why I am doing 6spd MT conversion right now.....
Old 04-13-2012, 05:53 PM   #50
330ciandr6
My Ride: .
Not having a manual didn't bother me at all. I prefer to keep both hands on the wheel at driving events anyway.
Old 02-24-2013, 12:02 AM   #51
c4lho888
My Ride: bmw 330i sedan
i have a 2003 330i m sports wheel with a round air bag do you know if mine have the pins thanks
c4lho888 is offline   Reply With Quote
Old 02-24-2013, 12:05 AM   #52
c4lho888
hi there i have a 2003 330i m sports with round air bag will mine have the pins in thanks
Old 02-24-2013, 12:26 AM   #53
patrickmurray2
My Ride: 2005 bmw 330i e46
Nice diy!
patrickmurray2 is offline   Reply With Quote
Old 02-24-2013, 02:58 AM   #54
studmuffin562
Account Under Review
My Ride: e46 325i 2001
Now I tapped the 2 wires from the paddle shifters into the upshift and downshift wires into the shifter. This is when I was testing which wire from the paddle shifters was upshift and which was down shift.
Now you can reconnect the battery. Turn the key on (don't start the car) and put the shifter in drive, then sport, and use the paddle shifters and make sure you have the plus on the upshift wire and minus on the downshift wire. If you have it correct, clean up tapping the wires and reinstall storage console and all shifter trim and you are done. I did this all for the fun factor and I love using it. I am not responsible for damage you do to your vehicle attempting this DIY.
In the future I may try and figure out a way to put the shifter in sport mode from the paddles without having to push the shifter over manually. If you have any questions feel free to ask or pm me. Oh and sorry, I suck at write ups.
Hey I have a ssg wheel with and m3 slip ring I bought all the wiring but idk what diagram I should go by if its ssg not smg I'm stuck I tried a couple diagrams and they didn't work when I would plug in the wiring sport mode would not show up. Please help
studmuffin562 is offline   Reply With Quote
Old 02-24-2013, 06:09 AM   #55
c4lho888
so I would only need the smg wheel and make up the wiring is that correct
Old 02-25-2013, 09:24 PM   #56
c4lho888
im about to buy the smg wheel do i ned the slip ring too as i have a 2003 sport with round airbag and my wheel has the one thick bar going down the middle plz help
Old 02-26-2013, 02:30 PM   #57
330ciandr6
My Ride: .
Seems to me like the wiring behind the clock spring would be the same between ssg and smg. Is your wiring at your shifter different? It shouldn't be.
Yes, you will probably need the clockspring as well.
Old 02-26-2013, 02:33 PM   #58
330ciandr6
My Ride: .
If your sport mode doesn't work when you have everything connected, you probably tapped into the wrong wire.
Old 02-27-2013, 07:13 PM   #59
c4lho888
so you didnt even need to make a wireing harness you just use the 2pins from the new clock spring and taped into the tipronic harness right ,coz in another write up somone has made a wire harness thats where i was confused after reading your write up this looks easy,that is if you only used the 2 wires from the clock spring and tapeds into the steptronic..... very clever
Old 03-07-2013, 03:42 PM   #60
330ciandr6
My Ride: .
Don't need to make a harness.
