Old 01-11-2011, 02:49 AM   #101
alpinadrachten
My Ride: e46 320
@ sillieidiot,
I will try to find that seal. Is there anyone with a photo from the seal?
For new bulbs I`m thinking about Osram Xenarc Cool Blue D2s Intense 5000K. They schould be very good.
I hate it there is so much imitation philips and that kind of stuff...
alpinadrachten is offline   Reply With Quote
Old 01-11-2011, 08:00 AM   #102
Rickna
My Ride: '02 330xi AT
Send a message via ICQ to Rickna Send a message via AIM to Rickna Send a message via MSN to Rickna Send a message via Yahoo to Rickna
#19 in the diagram.
237 years of democracy has died, and with thunderous applause
My_Mods_&_Stuff
Rickna is online now   Reply With Quote
Old 01-11-2011, 02:16 PM   #103
alpinadrachten
My Ride: e46 320
@ Rickna,
Ah That seal. I will check him. Thanks.
Old 03-09-2011, 07:18 AM   #104
jeffmr
My Ride: 2003 325xi
So is it possible to replace the ballast and test before doing the auto-leveling and taking out the ignitor? Also for cars that have headlight washers do you have to clamp off the hose that connects to the light or empty the washer container or is that part not attached to what is removed? Thanks.
jeffmr is offline   Reply With Quote
Old 03-09-2011, 02:47 PM   #105
sillieidiot
My Ride: '06 AW 330ci
yes, that is what i always suggest people to do. this DIY was just to show how to identify and take each component out as necessary
on my diy to take the headlights out, there are instructions for those that have headlight washers
Old 03-19-2011, 04:21 PM   #106
jeffmr
My Ride: 2003 325xi
Thanks I've tested the bulb and am now testing the ballast so far. A lot easier than I thought.
Old 04-03-2011, 01:19 PM   #107
suss1173
My Ride: E46 M3, JCW Mini, X3
Send a message via AIM to suss1173
Super DIY. Thank you for taking the time to put it together.
Any chance some is looking to sell a good ballast and ignightor for the passanger side at a reasonable $? I need the passanger side for "AL 1 307 329 074" lights.
suss1173@aol.com
suss1173 is offline   Reply With Quote
Old 04-07-2011, 03:05 AM   #108
sillieidiot
there are some for sale on the classifieds. the going rate for them is around 100
Old 04-07-2011, 08:53 AM   #109
suss1173
I got one for $100 Thanks.
Old 05-16-2011, 05:58 AM   #110
SilwerDK
My Ride: E46 - 323CI Cab
Hi,
Anybody know what BMW part number the ignition xenon have?
I have exactly the same ignition, and mine is defective.
AL 1 307 329 - But my BMW dealer canīt find this number.
See my Attach
SilwerDK is offline   Reply With Quote
Old 06-22-2011, 10:29 AM   #111
i dont know
My Ride: E30
Very nice write up. Is this a normal problem in the bixenon wiring harness? Do you think rewiring is possible?
After a little snipping and soldering the light is functional again. The condition of the dynamic HID lights might be something to check when looking at a car, because those aren't cheap to replace.
ID:	407189   Click image for larger version
i dont know is offline   Reply With Quote
Old 07-05-2011, 11:15 PM   #112
dizzledude
My Ride: 01 BMW 325i
Hey sillieidiot, I have a question regarding the adjusters. On the xenon headlights, the adjusters and screws are different due to the auto-leveling motors. How can I get the xenon assembly into the halogen housing and still be able to use the adjusters?
dizzledude is offline   Reply With Quote
Old 09-13-2011, 04:52 AM   #113
AnotherFanatic
Banned
My Ride: a car
AnotherFanatic is offline   Reply With Quote
Old 10-04-2011, 11:08 PM   #114
jlcool007
My Ride: E46 330ci Smoked Out
Originally Posted by alpinadrachten View Post
@ sillieidiot,
i know this is kind of late in the thread but
GET THE OSRAM CBI's!!!!! i just got them in and they are so bright! samae stock 35w ballast and people actually ask me at the gas station what i'm running! (i'm talking like 55+ year old guys with stock, non-modded bmw's and audi's). just goes to show how bright they are. I don't know how osram increased light output with the same 35w input, but they are certainly brighter! deer light up like tin foil on a black background.
a user actually did a test with the 85122's and the cbi's actually threw 55% MORE light than the 85122's! it was something like 2700 lumens vs 4400 (arbitrary measurement, but the relative difference is what makes the reading)
_FOR SALE_ (below)
***staggered style #68 330ci spt. pgk. wheels w/ PS2's***
***full set amber 2001 330ci lights***
***99-01 coupe smoked corners***
Jason Le Blanc's Facebook profile
jlcool007 is offline   Reply With Quote
Old 10-04-2011, 11:50 PM   #115
sillieidiot
normally you want to compare them with 85122+. the 85122 will lose lumens after break in because it color shifts. the 85122+ does not. but even then, the CBIs are brighter. the lumens is closer to 3400 btw
Old 10-22-2011, 10:54 AM   #116
FWSIV
My Ride: 1992 535, 1987 325iS
awesome write up
sillieidiot-
thanks for your help with which brand I had. I finally got the new ignitor and just replaced it with the help of this DIY. It took about 30 minutes start to finish. I found the hardest part was removing that final 'ball and socket' to release the inner reflector.
thanks again-
Chip
Chip
1992 535 5sp w/many mods
2003 330i
1987 325iS
2010 328i- 6sp
FWSIV is offline   Reply With Quote
Old 02-05-2012, 09:16 PM   #117
jlaroc1990
My Ride: 03 330i
thanks op for the write up. very helpful
jlaroc1990 is offline   Reply With Quote
center trim, remove ballast, remove igniter, take apart headlight, xenon
