E46 Convertible
Old 01-21-2012, 02:47 PM   #1
lrcreamer
My Ride: bmw330ci
replacement mesh for windscreen
where can i purchase replacment mesh for my bmw windscreen deflector
lrcreamer is offline   Reply With Quote
Old 01-30-2012, 09:06 PM   #2
SMUUUUUV
My Ride: 330 VERT-4.4 X5-S550
Not sure if you can buy that mesh separately.
SMUUUUUV is offline   Reply With Quote
Old 01-30-2012, 11:17 PM   #3
Deox
My Ride: '06 M3 Vert
i had an office chair that needed to be reupholstered so i bought a few yards of what appears to be the same mesh at the local office chair store. it might be worth trying if you cant find anything else. the material i bought was $18 a square yard, so its a relatively cheap fix if it works.
best of luck and tell us what you do / if you find something that works.
Deox is offline   Reply With Quote
Old 01-31-2012, 10:36 AM   #4
NorthJersey 3er
NorthJersey 3er's Avatar
My Ride: '03 M3 / '72 2002tii
Not a bad idea^ Don't know if the mesh makes THAT big of a difference. I guess I would assume it does, but hell its cheaper to try it than buying a new windscreen. If you do tackle the project take some diy pics.
Matt
co-founder of
euro techniks
NorthJersey 3er is offline   Reply With Quote
Old 01-31-2012, 05:03 PM   #5
E46DrEaMeR
My Ride: 2004 330ci
i made one for a previous car of mine and used a black moskito net from a camping shop......it did the job and it looked really cool, i was asked many a time where i got it
the second pic is the frame without the mesh
ID:	434901   Click image for larger version
Its a ragtop thing! you wouldn't understand
E46DrEaMeR is offline   Reply With Quote
Old 01-31-2012, 08:37 PM   #6
three30cic
My Ride: 330ci/m3
Send a message via ICQ to three30cic
How is the existing mesh held into the screen? If you get new mesh, do you have a plan on how to attach it?
three30cic is offline   Reply With Quote
Old 02-05-2012, 07:56 PM   #7
jfoj
My Ride: 330CiC, M5, X5, E93
E46DrEaMeR, gotta love the dishwasher sticker!!
Great ideas on changing the mesh.
I also think there are some ebay guys that repair the BMW rear window shades for the 5 & 7 series cars. Not sure if this is similar material and how much??
Old 02-06-2012, 04:03 PM   #8
E46DrEaMeR
My Ride: 2004 330ci
e46dreamer, gotta love the dishwasher sticker!
Old 12-08-2012, 08:42 PM   #9
fmzip
My Ride: '08 328xi / '01 530i
I am going to figure this out once and for all!
I have a 128i windscreen that I am going to dissect! Could be a costly project, wish me luck!
fmzip is offline   Reply With Quote
Old 12-13-2012, 02:41 PM   #10
fmzip
So I replaced the mesh!
Step one:
For ease of assembly take the two halves of the windscreen apart. It will make it much easier to handle while reinstalling the new mesh later on. If you can't figure this part out, skip this project all together Next, starting at one corner of the windscreen, pry out the rubber stripping carefully with a small screwdriver. It's a bit difficult to grab it with your fingers at first, but once you have it started it pulls right out!
Step two:
The fabric......I spent countless hours searching for fabric. The choices are endless once you have an idea of the keywords to look for. If you want to choose your own, you can get a sample pack here: http://www.seattlefabrics.com/mesh.html. Unfortunately it will cost you $20, $15 in shipping for $4 worth of fabric samples. Whatever you choose, make sure the mesh is not stretchable and UV resistant.
What I ended up using was a much smaller mesh. It cost me $8.81 from Amazon and is enough to do both top and bottom of the windscreen. It's No-See-Um netting by Equinox. The mesh has a slight sheen and is not flat in color like the factory one. I actually like it better.
http://www.amazon.com/Equinox-LIB146...squito+netting
Step three:
If you ever replaced a window screen at your house, this works the exact same way. You really can't screw this up. The only thing that can go wrong is ending up with wrinkles in your windscreen which can be fixed be redoing what you've just done as described below.....
With the help of a partner, lay the mesh over the windscreen. Don't worry about the wrinkles in the fabric, you will be able to pull it tight so they won't be noticed.
Start in one corner, directly across from you and your partner at the shortest sides of the windscreen. Have you partner hold the fabric tight over one end of the windscreen while you hold it tight on the opposite side. Work slowly, stretch and pull the fabric as you go to avoid creases and wrinkles, while beginning to push the rubber stripping back in little by little. These is definitely a 4 hand operation to make life easy, hence the inability to snap any pics!
Step 4:
Once the mesh is back in, take a sharp Exacto, and I mean sharp Exacto, and carefully trim the excess off. You will find it easier to trim if you provide tension on the excess fabric as the point of the Exacto is slicing through the fabric. I actually kept the very tip on the Exacto sliding on the windscreen frame just under the rubber stripping. Just be patient in the final step here, as one slip of the blade and you are starting all over!
I ended up just doing the top of the windscreen as described and was ecstatic with the end result!
From start to finish, I would say this is a good 1 hour project. A bit tedious but it is not hard. If I was to charge to do this, I would say it's a $100 bill per side for my time. I only throw that out there if someone really can't tackle this. It's something I'd rather not be doing but I'd be happy to help someone out
I will post some pics later today of the actual fabric as you can't see the the difference on the windscreen at a distance.
Here's a pic of the end result. The top piece has been replaced. It only looks lighter/clearer as it is not against the carpet like the bottom. I would say there is increased visibility with no reduction of windscreening. The holes on the no-see-um mesh are super small and it's very tough fabric, so tough you need a sharp Exacto to cut it....
Old 12-13-2012, 03:02 PM   #11
johnrando
My Ride: '06 330 CIC ZHP
Awesome job, great DIY!
John '06 330 Cic ZHP
Southern California
ZHP, Cold Weather Pkg., Leather, Jet Black/Black/Black Cube, NAV
AA Tune, Sprint Booster, BMW Perf. Intake, Magnaflow Exhaust, Dinan STEP S/W & TB, TMS Pulleys, H&R Touring Cup Kit
BMW Perf. Strut Brace, Orion V2 Angel Eyes, No-holes License Plate, SMG Paddle Shift Mod, Besian VANOS, Gold DISA, Fan delete
Old 12-13-2012, 03:10 PM   #12
fmzip
Thanks John,
Someone had to try it, glad I could pull it off. The factory windscreen is so over priced, can't see having to buy a new one because the mesh gets cut or faded.
A lot of time invested in online searching and local searching for fabric. Hope this helps someone else!
BTW, you cannot dye the existing mesh if yours is faded., tried that on the scrap piece. Fabric dye will not adhere to it......
Old 12-13-2012, 04:16 PM   #13
fmzip
Here's a close up and comparison of the materials
The finer one is purchased fabric
