Old 02-05-2012, 09:16 PM   #1
thatmexican32
My Ride: 99 323i
south bend clutches
okay so i know im going to be told to do research but i did some and i couldnt find much.i want to know if anyone is using a south bend clutch and if so, how do you guys like it? what other clutches are any of you guys using that have lasted? my 323i's clutch is slipping bad now.
thatmexican32 is offline   Reply With Quote
Old 02-06-2012, 12:20 AM   #2
jacobs323i
My Ride: blown 323i
i have a stage 3 segmented kevlar from clutch masters with a lightweight flywheel with less then 6000 miles on it held power great and had like oem pedal feel. I upgraded to a m3 tranny so i have it for sale for cheap! pm me if ya want it.
jacobs323i is offline   Reply With Quote
Old 02-06-2012, 07:55 AM   #3
TxZHP04
My Ride: ESS TS2+ ZHP
A new OEM clutch should last you well over 100k miles. Unless you have a real need (ie, you have a heavily modified motor), a stock clutch and flywheel are your best bet.
Old 02-07-2012, 01:14 PM   #4
tinkwithanr
My Ride: '00 323i + '75 2002
Is that the same one you sold over the summer?
Sig
^^Mica_____________________________Fiona^^
tinkwithanr is offline   Reply With Quote
