Old 02-08-2012, 11:28 PM   #1
cyberlando
My Ride: 2002 M3
Post S54 swap
finally getting down to the important questions.....
what mods to the wiring harness would be fully necessary for this swap to work.......if i got the harness in perfect condition with the ews and dme?? nothing damaged!
cuz all the swaps that i see on here there cutting the harness to connect it to another harness or something like that?
S54 engine DME EWS HARNESS= PLUG AND PLAY AS FAR AS WIRING GOES RIGHT?
Engine:
[] Euro Headers [] Euro Cats [] OEM Section 2 AR20[] B&B Exhaust [] AFE Stage 2
Interior:
[] Led Interior [] DICE Module [] Auxilary 3.5 jack [] 4 channel Amp with component speakers.....and more
Suspension/Handling:
[] KW V3 [] Eibach F&R Sways [] Vibratechnics Tranny mount [] UUC RTAB
[] Vibratechnics Motor Mount [] SSBL [] Turner Camber Plates
[] 90A Akg Subframe Bushings [] Akg Differential Bushings [] Subframe Renforcement
cyberlando is offline   Reply With Quote
Old 02-08-2012, 11:57 PM   #2
Solidjake
Zero. Leaks.
Solidjake's Avatar
My Ride: '02 330i 6MT
Have you read the first sticky at the top of this section? It should have the answer.
Old 02-09-2012, 12:01 AM   #3
cyberlando
My Ride: 2002 M3
Ppl stopped posting on that as much anymore just need. A quick hint in the right direction this place is for answers right?
Engine:
Interior:
Old 02-09-2012, 12:03 AM   #4
Solidjake
Zero. Leaks.
Solidjake's Avatar
Should be there. Only a handful of members did the swap so do exactly what they did.
Old 02-09-2012, 12:05 AM   #5
cyberlando
My Ride: 2002 M3
Ppl won't answer the question there so i tried again......why the cutting and modding of the s54 harness if you get it with the dme and ews
Old 02-09-2012, 12:11 AM   #6
mkodama
mkodama's Avatar
All the information can be found on this forum if you search. The only hard parts are the wiring harness modifications and the programming, which are closely kept secrets by the people that have done the swap because of how much research is required.
Old 02-09-2012, 12:12 AM   #7
radicalbrad707
My Ride: BMW
Solidjake is trying to tell you that if you read the whole post you will find the answer to your question in some detail. They explain what they splice into and why. Just read it.
radicalbrad707 is offline   Reply With Quote
Old 02-09-2012, 12:44 AM   #8
lab rat
My Ride: '02 330iT
It's easier to swap it into the coupe because you don't need to worry about the rear doors. Just use as much from the M3 as possible.
Because sleeper
dme tuning, s54 swap, wiring
