Thread Tools Search this Thread Rating: Thread Rating: 8 votes, 5.00 average. Display Modes
Old 02-10-2012, 06:28 AM   #1
Cipri
My Ride: E46 M3 2002
S54 custom turbo setup
I have started to build my custom turbo setup:
Turbine: Turbonetics GT-K 650 0.68 A/R
Intercooler: Godspeed 30x4x12 I/O 3"
WG: Synapse Synchronic V-Band 50mm
BOV: Synapse Synchronic 50mm
Injectors: HPF 750cc
ECU: AEM v1 with HPF harness, bought from yelowssm
Custom exhaust manifold and intercooler piping (In 3" and 4" out)
Custom 4" downpipe and midpipe
Stock air box, should hold to 0.5-0.6 Bar
I'm waiting for the parts from HPF (injectors + ECU) to arrive and the car will go to the shop for the custom parts.
I hope at the end of March, beginning of April the car to be running the streets
Car was running 12.9 on 1/4mile, my target is low 12' or high 11' with FI.
Cipri is offline   Reply With Quote
Old 02-10-2012, 02:32 PM   #2
mike@maximumpsi
My Ride: 02M3T
I would recommend making a plenum. If you choose to use the stock airbox I have some recommendations for modifying it for boost.
02 M3 - Maximum PSI S2 turbo kit - 9.74@145.99, stock motor, stock ECU, first in the 9's
97 M3 - Maximum PSI turbocharged - 8.94@164.33, stock ECU, first in the 9's, first in the 8's
16 M3 - Maximum PSI full bolt ons - 10.27@137, quickest in the US
BMW SOB's turbo E30 - 8.72@158.39
Maximum PSI - Home of the quickest BMW's in the US
Click here for E46Fanatics 1/4 mile standings
Follow us on Facebook and Instagram!
mike@maximumpsi is offline   Reply With Quote
Old 02-10-2012, 04:23 PM   #3
Cipri
Mike can you give me some tips to reinforce the stock air box?
After I build the engine and boost up I will buy a HPF intake manifold.
Old 02-22-2012, 03:38 AM   #4
Cipri
All parts ordered have arrived, at the end of this month the body shop will start the fabrication fo the custom parts.
The car will always be runing on 100 Octane fuel, I have a few questions for turbo gurus on this forum:
1) What is the max boost for HPF stage 1?
2) Should I put water/methanol or not? Is the AEM kit ok? How much boost will this allow?
3) What clutch kit do you recommend?
4) Since Mike did not answer, do you have any tips to reinforce the stock airbox?
Old 02-22-2012, 03:46 AM   #5
faelar
Big Pimpin'
My Ride: M3
I've got a HPF methanol system for sale.. Would work with your harness and EMS.
Cool to see folks starting to do total custom builds. This scene is about to get exciting.
Billet PT6765, ProEFI, SAAD Racing, 805 WHP 692 WTQ
Originally Posted by Saad@SaadRacing View Post
Chad's car is being taken care of and I can tell you when it comes back he and his car will be your worst f***ing nightmare.
faelar is offline   Reply With Quote
Old 02-22-2012, 09:53 AM   #6
mike@maximumpsi
My Ride: 02M3T
I would make at least 4 tie bars that go horizontally and vertically inside the plenum. That will minimize the plenum from expanding and breaking at the seams.
Old 02-22-2012, 05:15 PM   #7
02PRUV
My Ride: E46 M3 Turbo
For a custom setup why bother buying an ECU from HPF? Your better of running a Vipec so you can control everything and program it yourself.
A 0.68A/R rear is too small for an S54. I ran an 0.82A/R on a GT35 and that was still too small. If you bring boost on too soon you will break ring lands with more than 10 psi in a short time period. If you look at all the HPF cars with stock engines boost comes on after 5000rpm. That's how they keep them living. Would feel lazy though.
Just buy a HPF plenum. They are well made, fit well and work. Don't even bother with trying to use the stock plenum.
Don't look at the power American cars make on US dynos. You won't make anything near what they make. Aim for around the 400rwhp and you will have it last a while with boost coming on early. If you want to run more boost make sure it only starts coming on boost after 5000rpm which to do you will need a big A/R rear maybe a 1.00A/R or bigger. Or go a bigger turbo around a 800hp rated turbo with a 0.96A/R rear. Then you will most likely see it living with 450+rwhp but it will be lazy coming on boost more like a supercharger.
Rides:
BMW E46 M3 Turbo 570rwhp @18psi (old setup)
BMW E46 M3 LSX 427ci 800hp N/A
Ultima GTR LSX 440ci 800hp N/A
VY SS Ute Turbo 1004.6rwhp @ 28psi E85
Ford Escort Mk2 2JZGTE 600rwhp @14 psi
04 Yamaha R1 154.3rwhp
ISUZU FZR550 tilt tray (GT35 Turbo)
02PRUV is offline   Reply With Quote
Old 02-22-2012, 06:02 PM   #8
M3PTGSC
My Ride: M3
There is HPF kits in Turkey,Sweden,Germany and UK now.They make same power on European dynos or even more than US cars here.
http://forum.e46fanatics.com/showthr...558&highlight=
He made 500 rwhp on stage 1,thats even more than HPF is claiming and he is in Europe? Maybe you meant dont look at anybody's dyno but only AUS one?
Sorry for OT
09 SL63 AMG Designo,pano and whole nine yards lol
07 S550 P2 4matic-gone
03-M3-6766 DBB..Tubular manifold...
97-M3-
95-M3 SC stage 2-Widebody...
08 Gix 1k 08 ZX10R
M3PTGSC is offline   Reply With Quote
Old 02-22-2012, 07:17 PM   #9
BDUB328I
My Ride: bmw 328i S54 sedan (
Sorry for OT
lol this is great^ pruv is always hating the US dyno
BDUB328I is offline   Reply With Quote
Old 02-22-2012, 08:01 PM   #10
Evil Twin Rob
My Ride: 2004 M3
Sorry for OT
That says 15 psi and 98 octane fuel? That's not a standard stage 1 tune.
HPF 2.5
Evil Twin Rob is offline   Reply With Quote
Old 02-23-2012, 06:53 AM   #11
02PRUV
Not only that US guys and Oz guys need to double check what dyno reading they are looking at from Europe or the UK. A lot of the dynos in these places are setup to spit out a calculated flywheel horsepower as the norm as well instead of just reading the rwhp. I've never understood that cause it's an average guess on driveline losses. Also you need to confirm the gear they are run it. Cause the one in that thread seems to be run in 5th not 4th. There is no way 4th does 250km/h
Rides:
Old 03-05-2012, 02:05 PM   #12
Cipri
I just hit the wall
How can I reposition the ABS? Where is it on RHD e46 models?
Old 03-05-2012, 02:18 PM   #13
MarcusLSB
My Ride: X5, CT200h, CLK63 BS
I just hit the wall
You did what?
Old 03-05-2012, 02:25 PM   #14
M3PTGSC
My Ride: M3
Originally Posted by MarcusLSB View Post
You did what?
I think he meant hes stuck with the ABS pump location problem
97-M3-
08 Gix 1k 08 ZX10R
Old 03-05-2012, 02:30 PM   #15
Cipri
Correct, I'm stuck.
How can I reposition the ABS pump?
Old 03-05-2012, 02:45 PM   #16
MarcusLSB
Correct, I'm stuck.
Its probably easier to relocate the ECU then it is the pump.. however I believe HPF was able to fit both the AEM and the ProEFI behind the ABS unit on the LHD's.. on the RHD is it positioned differently?
Old 03-05-2012, 02:49 PM   #17
Commanderwiggin
My Ride: 900rwhp Turbo M3
Pics are worth 1000 words...
900+RWHP, PT6870 w/ Custom FSR Turbo Kit, AEM Infinity, Lab22 Motor
Old 03-05-2012, 03:11 PM   #18
SweetBMW
My Ride: 318CIA
In Europe, fuel octane ratings are different than in the US. 98 here is the same as your 93 or premium or whatever.
Google : octane, ROZ and RON
SweetBMW is offline   Reply With Quote
Old 03-05-2012, 03:51 PM   #19
Cipri
I don't want to fit the AEM or ProEFI, I want to fit the 3.5" downpipe
Has anyone repositioned the ABS pump on an LHD M3?
Old 03-05-2012, 04:04 PM   #20
M3PTGSC
My Ride: M3
its doable but its a huge headache dealing with new lines and to extend wiring and everything else,with aftermarket brake lines there is always possibility of breaking and not sealing properly and just problems in a long run,you trying to run top mount or?
97-M3-
08 Gix 1k 08 ZX10R
