Bavarian Soundwerks' Mobile Electronics Forum
Have all your A/V and electronics questions answered here. Ipods, A/V, Radar Detectors Oh My! Sponsored by Bavarian Soundwerks |
Rating:
Display Modes |
#221 | |
Thanks for the explanation. Really appreciate it! To put it simply is this how I would wire it: Red (pos) from the camera led to the grey brown which is conjoined with the other grey brown(there are two grey browns in the pics). Then the black wire from the camera led to the conjoined brown/red and brown? Thanks again buddy
#222 |
I've picked one of these things up off Ebay in anticipation of the D99 coming out. It looks like the one in Darkoz's pic and came in a box with a picture of a Z4 on it. Is the light likely to be a white LED? Just wondering if I'm going to need to order up some LED's for the other side to stop it looking odd.
#223 | |
#224 | |
You have to figure out which is connected to black and red. I usually use a voltage meter. One of your friends should have one if you don't have one yourself. Black is ground (or reference line) and red is ~12V (or higher voltage line). |
#225 |
It was advertised to fit but wasn't even close.Took some work to fit this in.
![]() I eliminated the screws after I shot the pic. Very little protrusion is what I was after. ![]() The graduations are close to the actual distance. I know-the wires look terrible. It's been fixed since then.
#226 | |
#227 |
#228 |
does anyone have good picture of the light output of those leds? id like to have an even glow so i might have to mount the camera somewhere else
![]() daron |
#229 | |
Good luck. |
#230 |
mine on my vert
![]() uses original lock place |
#231 |
been reading this thread for the past 2 months, and finally felt confident enough to try it. install, wiring, etc went well, but ran into a problem.
when i put my car in reverse, the Dynavin (D99) switches to camera, but the screen is black, and there is a small camera icon in the top left of the screen. any ideas? instead of soldering wires (from camera power to reverse light), i used t-taps to splice. could this have any affect on this? also, i used 22-gauge hookup wire to extend the reverse wire (the green wire from behind the Dynavin) to the trunk. could that have any affect on this? just trying to do some detective work... thanks for any help! |
#232 |
Are you sure the Video RCA cable is connected?
02 Carbon Black M3 6MT
456whp/312wtq @ 8psi, No #'s yet at 9.5psi 4.10 / Headers / ESS VT2-550+ / Tuned by Evolve ![]() |
#233 |
yup, all plugged in...
#234 |
Oh wait, I remember reading on the D99 thread that you have to change it to use the camera as it's default on PDC I think.
#235 |
I'm not sure I know what you mean...?
#236 |
Actually now that I read it again, I don't think it's your issue but worth a shot...
Start reading from post #178 and on. http://forum.e46fanatics.com/showthread.php?t=895068
#237 |
Would it have anyting to do with PAL vs. NTSC?
#238 |
I don't think PAL vs NTSC matters, I remember reading a post about that.
How would I know if the camera is receiving enough power? |
#239 |
I know that my camera uses 12V. run the power lead and check it with a multimeter.
#240 |
Anybody sell these that replace the license plate light in the States?? Dont really want to wait almost a month to get one from HongKong?
| Tags |
| location, reverse camera, zhp |
