Thread Tools Search this Thread Rating: Thread Rating: 648 votes, 4.95 average. Display Modes
Old 12-19-2011, 09:41 AM   #61
330ciandr6
My Ride: .
Send a message via AIM to 330ciandr6 Send a message via Yahoo to 330ciandr6
Originally Posted by samson View Post
pics went down. update available? :p
Sorry haven't checked this thread in a while. I need a better host for the pictures.
Have a oil or coolant leak? Click here!:http://forum.e46fanatics.com/showthr...732&highlight=
ABS/DSC/Brake/Airbag light on?? Click here!:http://forum.e46fanatics.com/showthr...648&highlight=
330ciandr6 is offline   Reply With Quote
Old 12-22-2011, 10:45 AM   #62
Miko_10
My Ride: 330i 5 Spd
Anyone try this yet? Fluorescent Goo, might help ID a leak if you have one
http://www.motoiq.com/magazine_artic...scent-goo.aspx
FS(PM me if interested, MID Atlantic Area, 22307 zip)
- 2 M68 fronts w/ winter tires, local pick up preferred,
- OEM Pre face Sedan Clears.
Miko_10 is offline   Reply With Quote
Old 01-10-2012, 07:46 PM   #63
samson
My Ride: 05' 330i
Send a message via AIM to samson
any luck with replacing the down pics?
samson is offline   Reply With Quote
Old 01-11-2012, 06:07 AM   #64
330ciandr6
My Ride: .
If I have time today I'll try and rehost them.
Old 01-11-2012, 07:09 AM   #65
jasonbimmer
My Ride: 2001 BMW 330xi
for the PS reservoir hose clamps, get one 07-12-9-952-109 and one 07-12-9-952-107 cuz one hose is smaller.
2009 Mazda RX-8 R3
2013 Toyota FJ Cruiser
2008 YAMAHA YZF-R6
Old 01-22-2012, 02:08 PM   #66
yoshii
My Ride: 323i 2k
Great information for high mileage e46's thanks! OP
///UNDER CONSTRUCTION 323i///
18X9.5 Et33 V710
yoshii is offline   Reply With Quote
Old 02-15-2012, 02:44 PM   #67
My Ride: Lexus
How about vanos gasket, front crank seal, and front timing cover gasket. (all rare, i'm sure)
Then there's the seal that goes on the engine cover under the oil cap. that circular one. Although I think that may be more for aesthetics than leaks.
Looks like I need to do that vanos line. mines a bit caked with oil residue but not outright leaking. And I didn't do it on purpose, but i've reused the vanos line crush washers 3x and they haven't leaked one drop. still bone dry around those. I'll get around to replacing them but they're just a bit tricky to track down once you've forgotten to order them. I'll wait til I have to order more parts so I can include those little guys. local dealer wants $3.50 each for the washers when they're online for 25 cents a pop...
Old 02-15-2012, 11:33 PM   #68
CrazyOneToo
My Ride: 1999 328i 4dr
7. Rear main seal
Usually on higher mileage cars as well. It leaks between where the transmission mounts to the engine. This is not an e46 but is what it looks like when a rear main seal leaks.
Part number needed:
Rear main seal kit: 11-14-1-438-274
Just the seal: 11-14-2-249-533
I recommend doing the kit as it comes with the mounting plate and the gasket for the plate. Its always better to replace it while you are in there. Plus if you do just the seal you have to make sure you have it seated flush when you install it. If you buy the kit, it comes seated in the housing already.
On the Rear Main Seal.... is that pretty obvious? I have had my mechanic look twice now with a lift and he cant find where the oil leak is coming from. This is after he sprayed the underside clean and I drove it a few days. I only notice a drop or two when I park the car. It does not keep dripping if it sets for a few days at a time. I just had the Oil Separator and attached hoses changed hoping that an old hose may be the culprit but no.
1999 328i E46 with a M52TU - 2002 X5 E53 3.0i with a M54
ECSTuning.com/ - AutohausAZ.com/ - XOutPost.com/
CrazyOneToo is offline   Reply With Quote
Old 02-15-2012, 11:38 PM   #69
Darksideracer
My Ride: 325
Have you checked the ofhg or vcg?
Sent from my SGH-T959V using Bimmer App
Darksideracer is offline   Reply With Quote
Old 02-16-2012, 12:55 AM   #70
CrazyOneToo
I had the Valve Cover Gasket changed out about a year ago. Guess it could be leaking but I see nothing like in the picture. As for the Oil Filter Housing Gasket ....idk. Shows in the pics that's a hard one to see without removing the housing. Its strange...it seems to only drip when first parked after a drive. If it was dripping while driving I'm sure the oil level would go down noticeably but the level is fine.
Old 02-16-2012, 07:23 AM   #71
330ciandr6
My Ride: .
What area does the leak originate around?
Old 02-16-2012, 12:07 PM   #72
zaharias
My Ride: M3 E46 6MT 3/2005
Check your power steering fluid level also..
If it's the OFHG you will see oil behind the OFH under the intake manifold..
zaharias is offline   Reply With Quote
Old 02-16-2012, 12:45 PM   #73
CrazyOneToo
If your talking to me....I dont know. Thats the issue. From the bottom side we cant find where its running down from.
Old 02-16-2012, 01:00 PM   #74
CrazyOneToo
Yeah it was wet around the PS fluid holder and a little low last week. I bought a new o-ring gasket for the cap. No more seepage now. As I looked around last night its a little wet at what I believe is the oil to vanos hose. I took both the engine covers off last night and it was dry around the shelf above the exhaust and everywhere else except for this vanos hose ....without taking any more parts off. My mechanic checked the vanos unit Monday (errors and codes) when he was replacing the oil separator and hoses and it showed to be working right. This vanos hose may be a different story tho. I didnt have him replace it.
UPDATE ...added some pics of leak after removing airbox
Power steering cooling lines from side view...
Power steering cooling lines from top view...
VANOS to Oil Filter Housing hose...
Old 02-19-2012, 07:40 PM   #75
chris10492
My Ride: 14 Camaro 06 R1
This is amazing! I'm surprised this is not Sticky'd yet!
chris10492 is offline   Reply With Quote
Old 02-19-2012, 07:42 PM   #76
330ciandr6
My Ride: .
Old 02-19-2012, 07:58 PM   #77
shata
My Ride: 00 328i , 06 330i
Wow this is a amazing thread. Great job.
/// 2000 BMW 328I ///
shata is offline   Reply With Quote
Old 02-21-2012, 02:38 PM   #78
momofthree
My Ride: 2005 330i
Brilliant pics...thank you!
This weekend is oil and coolant leak day: oil seperator, hoses, clearing dipstick, oil filter housing gasket, vanos line, disa gasket, throttle body hoses boot, etc., water pump, thermostat gasket, thermostat, drive belt, power steering reservoir, air dist, coolant flush, oil change...and I THINK *fingers crossed* that's it.
Any truth to the transmission never needing to be flushed or have filter change? Mine is 2005 330i w/160K...
momofthree is offline   Reply With Quote
Old 02-21-2012, 02:49 PM   #79
momofthree
My Ride: 2005 330i
My new vanos line and washers just arrived.
http://www.ecstuning.com/Search/32411093596/ES258508/
Old 02-21-2012, 04:17 PM   #80
cjccww
My Ride: 2014 wrx, 2001 330i
wow sticky!
I have some pics i can add from my latest adventures
cjccww is offline   Reply With Quote
