E46 Xi Forum
Old 05-03-2011, 03:21 PM   #1
SharkmanBMW
My Ride: 03 330xi, 4th bimmer
Send a message via MSN to SharkmanBMW
Water leaking up through rear shock mount into trunk. Anyone else seen this?
When driving in rain, i have water around the RSMs that runs down to tge plastic trays.
I have Rogue Engineering rear shock mounts, they told me they have never seen that before.
I had similar leakage from the OEM mounts but figured the new Rogue ones would solve the problem.
As far as I know they are properly installed & paper gasket is there.
Any ideas?
H&R Sport, Bilstein E46 Sport (Front), Bilstein E36 M3 Sport (Rear), Rogue Engineering RSMs
SharkmanBMW is offline   Reply With Quote
Old 05-03-2011, 03:26 PM   #2
wdeerfield
wdeerfield's Avatar
My Ride: 2009 E90, 2011 F10
did you reuse the gasket or get a new one? i would just replace with a new one since its a quick 20minute change for the rear shocks.
2013 EB 335i xdrive | Msport | Coral | DHP | ZPP | ZCW | ZTP | 400M | Coded | MPerformance Bits | M3 Grills | Painted Reflectors | BMS Exhaust Tips | LED Turn Signals
2011 JB 535i xdrive | ZPP | ZSP | ZCW | 6FL | NAV | 331s Square | MPerformance Spoiler | M5 Grills | Painted Reflectors
wdeerfield is offline   Reply With Quote
Old 05-03-2011, 03:59 PM   #3
SharkmanBMW
Maybe I should put a few paper gaskets, any harm in 3 per side?
The paper gasket was reused but was only on the car for 3 weeks.
Old 05-03-2011, 04:48 PM   #4
vazquezjavi
My Ride: '01 Sienna Red 325i
Send a message via AIM to vazquezjavi Send a message via MSN to vazquezjavi Send a message via Yahoo to vazquezjavi
One gasket should be more than enough.
'99 Titanium Silver Metallic 740iL on BC coilovers with 19" asanti af116's and gray alcantara headliner
'07 Black Sapphire Metallic 335i with JB3 and aktiv autowerks charge pipe and BOV
vazquezjavi is offline   Reply With Quote
Old 05-03-2011, 06:03 PM   #5
SharkmanBMW
I will buy a few extra gaskets in case.
I think if I shine a light from underneath it may help expose the exact spot, but either way, I will remove the shocks, make sure the underside of the shock tower is clean, replace paper gaskets and cross my fingers!
Old 05-03-2011, 08:35 PM   #6
Kubica
My Ride: 2003 325xi
I would have a good look for any bends in the sheet metal. Replace gaskets and torque to spec with the car on the ground.
Old 05-03-2011, 09:43 PM   #7
SharkmanBMW
Thanks for the input everyone.
Kubica, when you say torque on the ground, my Rogue RSMs bolt from below, can't do it with wheel on. I will try to find a way to be sure the mounts are seated well...
I will also definitely check well for bent metal.
Any chance someone has pics of the rear shock mount area without shock? Just so I can compare to mine.
I have a few pics of my mounts wet, I will upload them when I get home in case someone can see an obvious mistake I missed
Old 05-04-2011, 09:55 AM   #8
xi_ter
My Ride: 2003 325xi
You can put some Form-a-Gasket on both sides of the paper gasket.
There is a lot of splashing in the rear tower.
Old 05-04-2011, 08:11 PM   #9
SharkmanBMW
I considered that but was worried I would have a hard time removing the paper next time I take it all apart. (It could be stuck in the underside of the shock tower?)
It would probably do the trick though.
Has anyone tried it?
Small update:
I drove 30 mins. in rain yesterday morning, water was all over the mounts after.
I drove 30 minutes in rain 5 hours later, there was NO leak!
The only difference between the two drives was the morning ride had 8 or so really fast left/right sweeping turns & offramps. Rain was about the same - heavy.
Today, 15 minute drive in light rain, only driver side wet a bit. I would love to watch the mounts work from the trunk while driving.
Anyone see something obvious in the pics?
Old 05-05-2011, 07:51 AM   #10
wdeerfield
wdeerfield's Avatar
Because they mount from the top, what do you have on the underside? just the two nuts to hold it to the tower? seems like the tower may be not flat and the RSM is not sitting flush. Mine mount from below so i have the paper gasket on the underside. Im assuming your gasket is on the top now?
Old 05-05-2011, 11:28 AM   #11
SharkmanBMW
No, gasket under, same as yours.
http://www.rogueengineering.com/rogue/S_BUSH/RSM.html
Old 05-05-2011, 12:25 PM   #12
wdeerfield
wdeerfield's Avatar
ah gotcha. unfortunately ive got nothing then. maybe go with a new gasket and clean the surfaces really well before installing.
Old 05-05-2011, 01:11 PM   #13
Kubica
My Ride: 2003 325xi
The more I think about this the more I think the RSMs need to be replaced.
I'd stick with OEM or meyle next time. The reinforcement plate looks like it could be used again if you can take out the bolts (or the bolts on the oem RSM).
Old 05-05-2011, 03:22 PM   #14
SharkmanBMW
I had leakage with the OEM mounts as well, before the Rogues RSMs
Only have about 1500 miles max and Rogues tells me they have never seen this before.
Quality of the parts is amazing, rebuildable with new bushings...
The reinforcement plate has the 2 bolts welded on so that is the only way it goes.
I have to have a good look up into the underside of the shock tower, probably has crap / rust stopping the RSM from seating flush.
Kind of scared what I might find (rust).
Old 02-16-2012, 11:22 PM   #15
stockgp
My Ride: 1999 323i
didyou ever get this worked out? my driver's side is doing the same thing
stockgp is offline   Reply With Quote
Old 02-17-2012, 02:24 AM   #16
SharkmanBMW
I thought it was fixed
Questions:
What kind of shocks and rear shock mounts do you have, and how old are they?
How much leaking do you get?
Are you sure it's the mount & not the trunk seal? (the dealer insisted that was the cause lol)
I had everything removed, cleaned & sanded from the underside to be sure it was smooth, there was a tiny bit of surface corrosion, nothing that would interfere. Then sprayed some primer & put some black gummy stuff as an added sealant along with the new paper gaskets.
It was good for awhile but the passenger side is leaking again.
At this point, I just sprayed some Anti-Rust stuff on it and give it a wipe & spray it again when required.
Next time I remove any of those parts I will put a new OEM mount, but at this point as long as my battery stays clean & dry it will have to do.
With the luck I have had my new rear M3 Bilsteins are probably leaking too !
The rear suspension issues NEVER end.
Old 02-17-2012, 09:55 AM   #17
SamDoe1
My Ride: 4cyl of fury
Questions:
I have Konis, OE shock mounts, OE gaskets, and no leaking whatsoever. Doubt it's the trunk seal, otherwise you'd see it on the floor instead of by the shock mounts.
Old 02-17-2012, 10:05 AM   #18
stockgp
My Ride: 1999 323i
I.have konis and just installed meyle hd mounts. I have no idea what kind of mounts came out. There are no identifying marks on thm.
The leaking isn't horrible, but its bad enough that you can see a trail of **** that.has run down the shock tower. Also, on occasion I will find water on the trunk carpet.
Old 03-10-2012, 09:56 PM   #19
stockgp
My Ride: 1999 323i
Well since there isn't much input on this subject on this forum, I found a fix myself.
Bought a sheet of 1/16" solid silicone and went to town.
Cut a gasket that fit the ram bolts, but was a bit smaller than the rubber bushing diameter so it would stretch, then I stalled as normal. I ran a test spray on the side that was leaki g, and enough of the silicone sanwiched between the bushing and the bushing hole that it sealed the.leak. a
As long as it stays that way, im a happy sob.
Old 03-11-2012, 12:33 PM   #20
stockgp
My Ride: 1999 323i
and just to give you an idea of what i mean:
