Driveline, Engine & DME Tuning
Talk about driveline improvements, NA tuning and DME tuning your E46 BMW here. This includes diffs, intakes, exhausts, chips, software and OBD tuning. |
Rating:
Display Modes |
#221 | |
Damn, I gotta get new glasses in the morning. All that print looks fuzzy to me.
Honest 200 hp at the rear wheels is fine. Where are you going to go from here? What's the bobble at just above 4000 rpm? Quote:
#222 | |
Banned User
#223 |
Banned User
#224 |
#225 |
Banned User
yes and yes
#226 | |
Future for this car is: shark injector, intake, and duel air scoops. Beyond that, we will see. Xi knows his stuff, so we will see where I end up with his help. Sent from my PG86100 using Bimmer App |
#227 |
![]() 272/284 at 1 bar.
#228 |
#229 |
e30, m20B25 (stock with studs), 666 manifold adapter, GT3076R, and 15psi at that time. I made the mistake of assuming that a person who runs a shop and owns a dyno would know what they're doing. It probably could've made a little more power, and it could've lasted longer than the 300 miles it did.
That gasket is long-since replaced, and I'm closer to 10psi now. It's still a wild ride on the street. I DD it.
![]() Last edited by lcoleman; 02-06-2012 at 05:50 PM. |
#230 |
Car: '01 330xi m54B30 Mods: ebay headers, custom dual exhaust, evosport pullies, dinan TB, shark injector, K&N Fipk - 57 and FDM Peak: 196 whp / 201 ftlbs torque Dyno: mustang ![]() after my two pulls the guy observing the dyno said my engine was being starved fuel and that I needed a better tune. what do you think??? |
#231 |
ohhh yea heres the graph...
#232 | |
Burn your Krappy and Nasty intake with fire and buy something better. The two best (are both no longer made, you'll have to find a used one) are the Dinan CF long tube and the GruppeM. For new options, go with the aFe stage II EDIT: Your actually technically burning rich. Your numerical fuel to air ratio is below 13.0:1 up where you're making peak power. The ideal number is technically accepted to be 14.7:1, but that varies on some conditions including opinion. What can happen is your intake can create a strange vortex (or something) in your MAF. When the MAF sensor reads incorrectly, it will adjust the engine incorrectly. That may be what is happening to your car. Check out this link from Iceman's sig: http://forum.e46fanatics.com/showthr...498&highlight= Last edited by Andy2108; 02-09-2012 at 11:13 PM. |
#233 |
yea i actually JUST ordered a afe stage II, along wth schrick cams
![]() do you think ill need a minor tune for the dinan throttle body? I also heard mustand dyno's report low. is there any evidence to support this? |
#234 |
Very nice!!
Check out this thread: http://forum.e46fanatics.com/showthr...943&highlight= (Hint, page 38) He has cams and a bigger throttle body. I'm pretty sure the Shark has consistently been the best tune. Last edited by Andy2108; 02-09-2012 at 11:46 PM. |
#235 | |
#236 | |
The 330 uses a larger diameter intake tube and MAF, so an adapter of some sort would be required to run that intake on a 330. |
#237 |
Not a fan of the AFE, I would have went with the cosmo racing intake with a better filter: Cosmoracing.com or cosmoracing.ca?
#238 | |
My Ride: M3 & 323Ci (sold)
According to that dyno sheet your car is putting out more HP and TRQ than a M3 CSL Last edited by Alex323Ci; 02-24-2012 at 05:14 PM. |
#239 | |
Weird thing was that other cars were getting lower than expected numbers (a friend's ZHP registered at only 180hp or so). |
| Tags |
| dyno, dynoed |
