time to put in some new shocks - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
E46 Xi Forum
Old 02-21-2012, 09:14 PM   #1
john311tran
My Ride: awd + 5 doors
hey folks,
first time with bmw shocks.. in fact, first time changing a rear shock on any car. i've done front shocks on my gf's vw jetta before so i have an idea as what i'm doing but i'll find a few diy's on this forum.
my question.
i currently have a 325xiT wagon. i've seen countless threads on shock spring combo and yadda yadda.
the thing is, i'm not looking for a pimp ride. my wagon is my dd (until i can get my m3) and i spend a lot of time backpacking, snowboarding, lugging around 2-3 people and a dog. i don't need anything lower.
currently my car has ridden pretty harsh since i've gotten it. i suspect the shocks were on their way out and are now pretty much gone.
i'm debating a few things. do i go OEM or do i go aftermarket. if i do go OEM do i go with sports or the regular?
i'm assuming with the sport shocks i'll need to pick up the sport springs. will i be able to run rear sports with front regulars? if so what kind of ride will that give me? overall the sport shocks will give me a stiffer/firmer/more responsive ride than the regular shocks and ride a bit lower?
what about aftermarket. if i'm looking for a responsive ride but not have a serious drop to it (i'm ok with 1 or so inch drop from stock, but nothing more)
all information is appreciated.
bests,
john
john311tran is offline   Reply With Quote
Old 02-21-2012, 09:20 PM   #2
stevenluczynski
My Ride: Is Steel Blue
http://www.turnermotorsport.com/BMW-...-cup-kits.aspx
stevenluczynski is offline   Reply With Quote
Old 02-21-2012, 09:24 PM   #3
john311tran
i'm assuming that's for a set of 4. i only need the rears, but i guess i might as well do all 4. a lot more than i wanted to spend though :-(
Old 02-21-2012, 09:30 PM   #4
stevenluczynski
The cup kit is the best bang for the buck for keeping the Oem feel, Switching rear shocks without the fronts is never a good idea as well as mixing and matching, It can lead to undesirable handling effects
Old 02-21-2012, 09:31 PM   #5
john311tran
what about these:
http://www.autohausaz.com/search/pro...ock%20Absorber
seems like a significantly cheaper alternative?
john
Old 02-21-2012, 09:44 PM   #6
shadow 2
My Ride: 07 328i
Originally Posted by stevenluczynski View Post
None of these fit xi models.
shadow 2 is offline   Reply With Quote
Old 02-21-2012, 09:44 PM   #7
stevenluczynski
Originally Posted by john311tran View Post
what about these:
john
If you're not switching springs they seem like a good idea, but I would advise on switching all four shocks. I'm sure someone else will chime in on this
Old 02-21-2012, 09:46 PM   #8
shadow 2
My Ride: 07 328i
what about these:
john
They are OEM so they should work fine. Your rear springs are probably shot/rusted out too.
Old 02-21-2012, 09:47 PM   #9
stevenluczynski
Damn I missed the XI part sorry!
Old 02-21-2012, 09:51 PM   #10
john311tran
what about going from regular to sport shocks.. i'm assuming i will need sport springs as well right? i want to most likely stick with OEM. germans know what they were doing when they were building the 325xi.
john
Old 02-22-2012, 12:59 AM   #11
e46alfonso
My Ride: 330xi MT, mustang gt
what is this crap?
Old 02-22-2012, 09:15 AM   #12
SamDoe1
My Ride: 4cyl of fury
john
For the Xi, there is no difference between sport and non-sport in terms of OE suspension. It is all the same high riding soft suspension. The Germans definitely knew what they were doing, they were giving you extra ground clearance for "situations you may encounter due to ownership of AWD".
^ This.
Get Koni yellow adjustables and Eibach Pro-Kit springs. Buy both from Tire Rack. Also replace your upper strut mounts, upper shock mounts, the upper and lower rubber bits on the front struts, and any hardware removed during the install (upper strut bolts, pinch bolts, upper shock bolts, rear shock gasket, etc). You are also going to need an alignment done when you complete this job.
This is going to cost you ~$1k when you're all done.
Old 02-22-2012, 12:31 PM   #13
saltycdawg
My Ride: 02 325xi; 02 Duramax
Will an E39 M3 complete suspension fit on the E39 XI? So I kept reading, and hit the suspension thread; it pretty much says the only thing that works is the rear shocks.
The front suspension on our XI's will not interchange with a RWD car?
saltycdawg is offline   Reply With Quote
Old 02-22-2012, 04:35 PM   #14
Espeedy
My Ride: 2001 330Xi
This is going to cost you ~$1k when you're all done.[/QUOTE]
I'm in the same situation. 2001 330Xi with 61K miles but I already have the Eibach springs. Where do I get the "upper strut mounts, upper shock mounts, the upper and lower rubber bits on the front struts?" I'll take it to Brake Masters for the alignment.
Espeedy is offline   Reply With Quote
Old 02-22-2012, 07:04 PM   #15
Rickna
My Ride: '01 330xi - '09 IS-F
Does anyone know if the xit's have the same issue as xi's with broken rear springs?
2001 BMW 330xi
2009 Lexus IS-F
Rickna is offline   Reply With Quote
Old 02-23-2012, 07:23 AM   #16
john311tran
Originally Posted by e46alfonso View Post
what is this crap?
just trying to figure out what works with my car, that's all.
john
Old 02-23-2012, 08:48 AM   #17
SamDoe1
They use the same springs so probably? I have no idea though.
Dealership, pelican parts, getbmwparts, thebmwpartstore, ECS tuning...choices are endless.
Old 02-23-2012, 09:17 AM   #18
john311tran
what is so special about the koni adjustables... i'm assuming the ride height is adjustable?
as stated before, i've never dealt with this type of shock/strut. i've done repairs/fixes but they were always oem stuff, slap off, slap on, no alignment etc required.
john
Old 02-23-2012, 09:19 AM   #19
Dreamliner330
My Ride: 330xi
^softness/firmness adjustable, not height. In your position, I'd probably just go OEM.
See the link in my sig for a parts list.
Dreamliner330 is offline   Reply With Quote
Old 02-23-2012, 09:25 AM   #20
SamDoe1
^ Yup, this is the difference. Only advantage is that if you want to go to a "sport" style suspension while maintaining a daily driver feel, the Eibachs are really the only way to go. If the sport doesn't matter to you, then go OEM.
