Fluids for Track - Page 2 - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 02-26-2012, 01:23 PM   #21
MasterC17
My Ride: hates A/C & Sunroofs
Originally Posted by bigjae1976 View Post
IIRC, the guy said (I think) it floods the engine and something bad happens (can't remember what).
The S54 is a dry sump? Didn't know that.
Well, it is a Semi-Dry Sump system. In a true dry sump there is an external resevoir and hoses leading to it with the pumps in the reservoir. What BMW did with the S54 is take the dry sump and instead of locating it externally, they developed it into the bottom of the engine. In a wet-sump the oil is "picked-up". This is why in high-speed corners Non-M's have oil starvation because the oil goes to one side and the pump can't pick up oil, only air. In a dry sump the oil drain down into the pump and consequentely you don't get oil starvation unless if of course you flipped the car . So basically they took a dry sump and mounted it to the bottom of the engine instead of mounting it externally. The advantages a true dry sump would give you would be more oil in the system and better cooling and no "frothing" of the oil.
MasterC17 is offline   Reply With Quote
Old 02-26-2012, 04:36 PM   #22
Locutus09
My Ride: Something Slow
Thanks for all the help guys. I'll be doing the bleeding myself.
Looks like I'll end up getting the PFC RH665 to security. I doubt I'll push it that hard the first time out on HPDE, but I like the "better safe than sorry" technique.
Will OEM pads be decent enough to get me through my first time? I realize that dedicated pads will probably be considered if I catch the HPDE bug (which I know I will). But as of now, funds aren't there for pads (rather get good pads than cheap out).
I never had lifter-tick on last year for auto-x, and I was about 3/4 high in-between the levels.
Locutus09 is offline   Reply With Quote
Old 02-26-2012, 04:46 PM   #23
MasterC17
If you are going to use the stock pads I wouldn't even bother with the PFC RH665, ATE Type 200 would be fine. However, I suggest getting PFC "Z-Rated" Pads front and rear and getting the PFC Brake Fluid for FREE!
http://store.bimmerworld.com/introdu...uid-p1791.aspx
It will cost you around $200 as opposed to $55, but it is worth it. The Z-Rated will be great to start on and better than the stock pads and now it's only $150 more for the pads with the free fluid. Hurry though, you only have until the end of the month!
Old 02-26-2012, 04:50 PM   #24
bigjae1976
bigjae1976's Avatar
My Ride: 2011 E90 M3
Originally Posted by moranor View Post
ducting is a must it really helps alot... I just get very annoyed that alot of street cars run 19"+ rims just to fit a bbk because they "need" them and at the track they are hardly seen here sorry dont know why i felt i had to vent here
True. One thing I didn't bring up is the fact that my car is supercharged so I can generate a considerable amount of speed pretty quickly. That is the one HUGE tradeoff with a BBK...wheel clearance issues.
Awesome! I learned something today
While the OEM pads are pretty good, it depends on the track. Some, you can get away with it. Others, may not. At a minimum, I would make sure you have fresh pads. I would at least bring an extra set of pads to get you home just in case. Ideally, I'd just pony up the money for something that has a higher temp rating. Brakes are not something you want to skimp on.
2013 F30 328i - Melbourne Red
2004 E46 M3 - Imola red
Old 02-26-2012, 05:33 PM   #25
Locutus09
Roger that.
Those pads are cheaper than I thought. Looks like I may pull the trigger on those. The Z rated pads good for auto-x too? If I can find a happy medium for pads, that'll be awesome. Ill keep OEM pads for DD, then swap the pads come events
My first HPDE will be at Mid-Ohio. The part I'm concerned about brakes fading or fluid boiling would be going into China Beach. Watching E46 M's, they are topping out around 130-140 down that straight.
Sent from my DROID X2 using Bimmer App
Old 02-26-2012, 06:05 PM   #26
magnetic1
My Ride: MysticPair
Depends. I race on stock sized brakes w/ PFC01s with just the OEM ducting (if you want to call it that). No issues w/ brake fade. Car is around 3100#s with me in it. Obviously weight plays a factor too, but I think for a DE, proper pads will go a long way.
Skip the OEM pads and get PFC06s. You'll have a much better time.
Eric WONGer
2004 Mystic Blue #121 NASA GTS3 Racecar
2003.5 Mystic Blue Street Car
magnetic1 is offline   Reply With Quote
Old 02-26-2012, 06:15 PM   #27
MasterC17
Roger that.
Actually, the Z-Rated are probably the best compromise DD/Auto-X/Track pad you can get. They warm up a lot quicker than the PFC-01 or 06 (good for auto-x) but are also good for light track work and still work for DD.
Old 02-26-2012, 07:06 PM   #28
Locutus09
Okay, so swapping pads probably is overkill then.
Looks like I'll be placing an order.
Old 02-26-2012, 08:38 PM   #29
MasterC17
Well, if you were going with PFC-01 or PFC-06 I would swap pads. However, the Z-Rated should serve the DD, Auto-X, and HPDE's purposes well. Let's be honest - swapping pads every time before an Auto-X or HPDE would be a pain in the butt.
Old 02-26-2012, 09:03 PM   #30
Locutus09
Valid point. I gotta swap tires anyways, I figured throwing the extra 1-1.5 hours into the equation wasn't going to kill me. But that would be a pain after awhile
Old 02-26-2012, 11:45 PM   #31
bigjae1976
bigjae1976's Avatar
Might want to check the StopTech Street Performance pads. Supposed to be OK for light track use...they might be cheaper than the Z rated pads.
If you are going to do HPDEs on a regular basis (3-4+ a year) I would swap in some higher temp pads. It will save you money in the long run. For example, the PF01s will likely last you at least 3-4 weekends whereas you might go through an entire set of street pads in one weekend (very possible). I HATE missing sessions...so you have to factor that in if you cook a set of pads. How many sessions will you lose because you went home early with cooked brakes? I also HATE dicking with my car between sessions if I don't have to. There is lots to do. Check out other cars, talk to people, watch the action on the track, eat, get fuel, etc...
If you are just testing the waters to see if HPDEs are right for you, I'd stay with a FRESH set of decent brake pads...like the Z-rated.
Old 02-27-2012, 06:57 AM   #32
Feffman
My Ride: BMW M3 (Race Car)
I've been using Elf HTX brake fluid for several years from Performance Oil Store (www.PerformanceOilStore.com). The Elf is affordable and works very well. We run in conjunction Carbotech (www.CTBrakes.com) brake pads. Never any issues.
Feff
Feffman is offline   Reply With Quote
Old 02-27-2012, 09:26 AM   #33
Locutus09
Yea, I'm going to look around and get some sort of pad. I might just get a track rated pad, and only keep it for the track while using OEMs for auto-x.
As of now, I'm planning on doing 2 HPDEs this year. I'm going to start doing a volunteer program with NASA to where I can get free track days. So at least 1 HPDE there, and I might run at octoberfest as well
Old 04-04-2012, 01:19 AM   #34
bonjov66
My Ride: BMW
My M5
http://www.swotti.com/tmp/swotti/cac...gbmw%20m51.jpg
bonjov66 is offline   Reply With Quote
