Xenon front headlight failure - intermittent, both lights - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Thread Tools Search this Thread Rating: Thread Rating: 12 votes, 5.00 average. Display Modes
Old 12-05-2011, 12:46 PM   #1
Mad328Luv
My Ride: 328ci
I have a 2000 328ci with 130k on it with OEM Xenon headlights. Over the last two years, I have been experiencing intermittent outages while driving. Sometimes the left side, sometimes the right. Never any flickering as I have seen in other threads. I can turn the lights off while driving and turn them back on seconds later and the light comes back on. Sometimes it will stay on for an hour and sometimes it will go out within a minute. The problem has been getting progressively worse over the last few months. The lights rarely have difficulty coming back on.
I noticed in another thread that the suggestion is to disassemble the light following the DIY video and check for corroded or damaged components. Once that has been done, then I can consider checking the Light Control Module for an issue. From the threads that I've read, it does not sound like the igniter is the issue since the lights come without issue.
Does this sound like the right way to proceed? Have I left anything out? Thanks as always.
Mad328Luv is offline   Reply With Quote
Old 12-05-2011, 12:57 PM   #2
nk_zhp
My Ride: ZHP / E30 M3
It is likely that your bulbs are aging. As they age, the voltage needing to keep them lit increases until it reaches the upper limit of the ballast. Check the connections for sure but the bulb would be my 2nd guess.
'04 330i ZHP - OEM Clears - ///M Strut bar - CoolantSnitch
nk_zhp is offline   Reply With Quote
Old 12-05-2011, 02:15 PM   #3
217Bimmer
My Ride: Dodge Durango
i am having the same issue with my driver's side light. it gets progressively worse in cold weather. i swapped bulbs and the problem persists on the same side, so it is either the igniter or ballast. i've asked here whether someone can say which one it is more likely to be and have also searched through these threads, but cannot find a conclusive answer. i'd like to just replace the part without swapping igniters and ballasts.
** Political signature removed - Tim330i **
I always have to laugh when I see a thread described as "Not Work Safe." Is there anything on the OT forum that's really "work safe"? If I were your boss, I'd be mad if you spent any time on this forum at work at all. How is a picture of a naked girl any less work safe than, say, a picture of a matador getting gored in the *** by an angry bull? - VaderDave
217Bimmer is offline   Reply With Quote
Old 12-05-2011, 04:06 PM   #4
Geo31
Ironman
My Ride: 98 M-Z3, 01 325iT
I've got that issue as well and it initially improved when I redid the ground on the taillight, but it's back. I've just been dealing with it because work has been absolutely crazy, leaving me with little time to chase it down.
George Roffe
Swim: 2.4 Miles
Bike: 112 Miles
Run: 26.2 Miles
Brag: For the rest of your life
Geo31 is offline   Reply With Quote
Old 12-05-2011, 04:16 PM   #5
HyeWarrior
My Ride: '03 325i --> '13 GTI
Also interested in an answer. My headlights have gotten worse in the cold weather. 90% of the time, only one side fires up when I flip the switch, and it's a ridiculous process to get the other one to turn on. Either I have to flip the switch back and forth, or I just drive regularly for a few minutes and it'll turn on by itself. It alternates sides, so I know both have the same issue. Not sure if its the ballast or igniter
Wow
So Amaze
Much Torque Steer
Such FWDoge
HyeWarrior is offline   Reply With Quote
Old 12-05-2011, 04:25 PM   #6
eneka
My Ride: 2003 325i
my passenger side xenon has a hard time firing up as well...some times when they do ignite together, it's about half a second slower that the driver's side, other times I just have to wait about a minute after starting the engine and it'll ignite.. I've changed the bulbs and the ballast so I'm pretty sure it's the ignitor on mine..
eneka is offline   Reply With Quote
Old 12-06-2011, 10:27 AM   #7
Mad328Luv
My Ride: 328ci
Wow. i had no idea this was such an issue. There are hardly any threads that i could find on this. I'll start digging in and see what i find.
Old 12-06-2011, 02:36 PM   #8
naeem002000
My Ride: E46 99 328i
got the same thing here
but it rarely happens -once in 2 weeks-
i like to think they are the bulbs because the right side is less bright then the left side
naeem002000 is offline   Reply With Quote
Old 12-06-2011, 02:40 PM   #9
MercForHire
My Ride: M235i 6MT
I didn't know they had Xenons back in 1999.
Old 12-06-2011, 04:27 PM   #10
venceslau
My Ride: 2002 325xi B/B
Mine does the same thing...I basically gave up...lol.
325xi 2002 B/B
venceslau is offline   Reply With Quote
Old 12-11-2011, 08:49 PM   #11
Mad328Luv
My Ride: 328ci
I found out that in 2003 they switched manufacturers. They went from Osram to Phillips. I found the Osram bulbs on Pelican parts for about $70 each. Oem part was ridiculously expensive. S I ordered two bulbs ans we'll see how it goes. My bulbs were original so after 12 years, I guess it's time to replace e hubs.
Old 12-23-2011, 05:14 AM   #12
Yayo330
My Ride: AW330ci
My drivers side went out and I got a bulb from pelican parts...didn't seem to work, idk if it was the bulb that was the problem
Does anyone know what could be other things that cause this?
If you like Deep House check out my SoundCloud
Here is my Flickr
Yayo330 is offline   Reply With Quote
Old 12-23-2011, 07:59 AM   #13
Mad328Luv
My Ride: 328ci
We'll see how the bulb holds up. This is the original OEM part. I just replaced the bulbs and they are a little brighter than the aging ones and I have had no more issues with the lights going out.
Old 01-01-2012, 01:52 AM   #14
officer140
My Ride: 01 330xi, 99 TLR
I've had this issue for a very long time now. I narrowed it down to a ground issue. I tried grounding the tail lights and it didn't solve my problem. I finally decided to check my LCM/LKM and noticed that there was a lot of corrosion on the circuit board. I had an old LCM/LKM laying around from when I did the upgrade for rear fogs. I popped that in and problem solved! Now I just have to go to the dealer and have it programmed to match my car. If not, the tamper dot is on along w/ the indicator that my rear & front lights are out. Dealer charges $140/hr. Indy shop said they would charge me $150. I'd rather pay the dealer.
officer140 is offline   Reply With Quote
Old 01-01-2012, 11:14 AM   #15
jlaroc1990
My Ride: 13 WRX Hatch
my passenger side headlight is doing the same thing. It comes on fine sometimes and other times i have to switch it on then off a bunch or just drive for a bit and it will come on..... so subscribed hoping for a solution....i think its probably the ignitor but I'm hoping not
jlaroc1990 is offline   Reply With Quote
Old 02-05-2012, 07:12 PM   #16
jlaroc1990
well i found my problem so if anyone has the same problem ^.....it is the ignitor.
Old 02-05-2012, 07:24 PM   #17
Ineil
My Ride: 2001 M3
It's either the igniters or the ballasts, most likely the igniters. BMW sells them for $369.00 each. Be careful buying non OEM at the auto parts stores, the ones they says fit do not have the correct connectors, most have 3 pin rather then the 2 pin needed, at least that was for my 2001 M3.
M3 sold
New Car
2012 Roush Stage 3 Mustang
Ineil is offline   Reply With Quote
Old 02-06-2012, 01:13 PM   #18
Mad328Luv
My Ride: 328ci
Since i replaced the headlights about 6 weeks ago and I have not had one single issue.
Old 02-26-2012, 09:40 PM   #19
jose325i
My Ride: 08 BMW 135i
I had issues with my driver side headlight not working intermittently, but it slowly got worse until it stopped working altogether. First, I swapped bulbs, problem did not change sides. Then I replaced the ballast with known good one. It worked for a day, then stopped working again. Today I just finished swapping the igniter (huge PITA) and ballast. Works great except self-leveling is messed up now. I need to take it all apart again
jose325i is offline   Reply With Quote
Old 02-26-2012, 09:50 PM   #20
HyeWarrior
Sucks man
What was so hard about installing the new igniter? I ask because I'll be ordering replacements for mine soon
Wow
So Amaze
Much Torque Steer
Such FWDoge
failure, headlight, intermittent, xenon
