Best gear ratio? - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 02-28-2012, 05:48 PM   #1
matabamatt
My Ride: 2003 325
Best gear ratio?
2003 325i 5speed step right now wondering what would be better ratio
matabamatt is offline   Reply With Quote
Old 02-28-2012, 05:57 PM   #2
JJR4884
My Ride: BMW
Honestly dude just search.... ton of threads on diffs. I think for your car you have a 3.07 or a 3.23, not sure..... those are high enough, I wouldn't suggest anything higher like a 3.38 or 3.46 unless you have a 6 speed.
However that's your preference, some people don't mind cruising at 4000 rpms on the highway.... hell no for me.
Sent from my T-Mobile G2 using Bimmer App
JJR4884 is offline   Reply With Quote
Old 02-28-2012, 06:17 PM   #3
KickTheCAN
My Ride: United States
5speed steptronic?
Go 3.91 then.
6000k Angel Eyes, Morimoto Mini retrofitted, Active Autowerke Exhaust, Cooling system refresh, ST V1 coilovers, Electric fan swap, 95,000 miles
KickTheCAN is offline   Reply With Quote
Old 02-28-2012, 09:21 PM   #4
Steven747
My Ride: 05 330ci
3.46 diff in mine and at 80 I'm at 3200 rpm
Old 02-29-2012, 05:10 AM   #5
matabamatt
My Ride: 2003 325
Originally Posted by KickTheCAN View Post
5speed steptronic?
Go 3.91 then.
would this make my car a lttle quicker but still be good at highway speeds say about 80mph
Old 02-29-2012, 08:50 AM   #6
Drewfus2101
My Ride: N/A
Search.
First, you need to figure out what the options were for your car. It should be obvious as to what ratio is in your car.
Then you can use an online calculator to show what the RPM change will be if you want to change to something like a 3.91.
My '03 330i auto came with 3.38 rear end ratio. I wouldn't want to go up more than 0.30 or 0.40. Last time I used a calculator, that changed the RPMs at 70 up by about 400 or 500.
Drewfus2101 is offline   Reply With Quote
Old 02-29-2012, 08:54 AM   #7
Drewfus2101
My Ride: N/A
Real OEM say for a '03 325i you've got a 3.46 ratio. I don't know that I'd go any higher. If you can find something in the 3.6X range, it might be worth it, but past that you just have the 3.9X range, and thats a pretty good jump.
Old 02-29-2012, 09:26 AM   #8
KickTheCAN
http://forum.e46fanatics.com/showthr...965&highlight=
Old 03-01-2012, 05:16 AM   #9
matabamatt
My Ride: 2003 325
just by .30 higher can jump the rpm that high? i guess it wouldnt be that worth it unless the price was good
Old 03-01-2012, 05:19 AM   #10
matabamatt
My Ride: 2003 325
thanks for the link... you did the clutch fan swap to electric?? was it hard
Old 03-02-2012, 01:33 AM   #11
diablorojo
My Ride: Supercharged 330i
I put a 4.10 in my steptronic (before the conversion) it was loud cruising but I have header, exhaust, SC, etc...prob not so bad with no SC. I still have that gear in 6 speed and it still is loud...but the acceleration was ridiculous in my auto setup....
Started ESS...ended CUSTOM!
diablorojo is offline   Reply With Quote
Old 03-02-2012, 01:39 AM   #12
KickTheCAN
Not at all. I did it while I was swapping out the cooling system so the original fan had to come off anyways. The new electric fan is drag and drop. Just have to transfer an item from the old fan on the new one and plug it into the power source.
This, however, will render your pusher fan useless- the fan that's right in front of the radiator that sits right behind the front bumper. I havent removed that yet, but you should as it blocks airflow.
Makes the car real quiet and it works...made a four hour trip in hot weather the other day
Old 03-02-2012, 03:39 AM   #13
ICONIKE46
My Ride: Horse & Buggy
3.46 is the highest I'd go in a 325 5 spd. Anything higher than that and you'll be cruising at pretty high rpms.
3.63 is also doable but again the rpms are just going to keep going up while cruising.
Next time, please search. There are PLENTY of threads and plenty of info on the forums regarding gearing. gl with the project
ICONIKE46 is offline   Reply With Quote
