Thread Tools Search this Thread Rating: Thread Rating: 7 votes, 5.00 average. Display Modes
Old 03-08-2012, 04:32 PM   #41
faelar
Big Pimpin'
My Ride: M3
Originally Posted by Jason@proefi View Post
Yes, I am, not because you need to, it's because it SEEMS that's what everyone wants. We are also taking control over the throttle as well.
I still think removing VANOS would allow more power because you could then run larger valves and increase the lift on the cam.
VAC Motorpsorts determined VANOS will not function properly if you modify the cams or valves.
What I never see mentioned in these forums but is something I've been taught since my earliest days.. is that power is made in the heads. The heads are the most important part of an engine (mechanically speaking) I was always taught.
As far as I know, I'm the only person with a turbo E46 M3 that pursued a built head.. sad thing is I never got to use it
Billet PT6765, ProEFI, SAAD Racing, 805 WHP 692 WTQ
Originally Posted by Saad@SaadRacing View Post
Chad's car is being taken care of and I can tell you when it comes back he and his car will be your worst f***ing nightmare.
faelar is offline   Reply With Quote
Old 03-08-2012, 04:35 PM   #42
MarcusLSB
My Ride: X5, CT200h, CLK63 BS
I want this.. for the same reason I wear Diesel boxer briefs instead of walmart whitey tighties.. noone sees them anyways, they both support my balls the same way .. I just feel alot better knowing I'm not wearing fruit of the loom whitey tighties.
Lets talk once my car is back together.. I really want this, and I know Trevor does as well on his Z4M.
Originally Posted by faelar View Post
Not really no, because I believe he was taking ques from Chris. Chris admitted as much to me when we had a discussion about forums.
I sat there a listened to an entire conversation between Chris and Derek one time. I have my opinions on this matter and it is my opinion that Chris does attempt to try and manipulate the conversation on these forums through surrogates.
Whether those surrogates are intellectually capable of realizing that however I do not know. I even found myself being persuaded to comment in regards to AMGETR.
I'm speaking strictly from a customer stand point.. being a customer of HPF I do not like being lumped into a group with others, and I know many others on here would prefer not to be associated with certain customers of HPF as well.. so generalizing about HPF's customers as being this that or the other thing is pretty unfair.. especially being they have 100+ and this forum only represents about 10% of them.
Edit: Same goes for ProEFI customers.. which I am also...
Old 03-08-2012, 04:36 PM   #43
SlideFox
My Ride: A Bucket w/ 4-Wheels
SlideFox is offline   Reply With Quote
Old 03-08-2012, 04:38 PM   #44
MachRc
E46Fanatic
MachRc's Avatar
My Ride: 2003 Technik S1 M3
Originally Posted by Bmwandreas View Post
Today i dynoed his M3 to 1046 whp at 30psi with the new Precision 8285R turbo 1.12 A/R H-cover. It would have put out some more with the GT42 cover and 1.28 A/R but there are no space for that
With some vanos tweaking it made 19 psi at 4800 rpm on third gear on the street so itīs not laggy at all
With stock vanos settings it had 19 psi at 5800 rpm
I also weighted it on my intercomp scales to 3740 lbs with driver. So the 4000 lbs was not on a correct scale.
9 sec runs this year?
Here are the dyno movie:
wow
looking foward to hearing about more on the wicked car, in this forum or others.
9 seconds would be, again raising the bar
"One thing we all adore. Something worth dying for..
Its been nothing but pain, stuck in this game. Searching for fortune and fame"
MachRc is offline   Reply With Quote
Old 03-08-2012, 05:32 PM   #45
TaZaM3
Psshhhht M3
My Ride: E46 M3
Good job Andreas, my old 76 made 940whp at 29psi (I run 34psi on the street sometimes) so were pretty close!
TaZaM3 is offline   Reply With Quote
Old 03-08-2012, 05:47 PM   #46
yellowssm
My Ride: 2005 M3
I thought you made 1100-1200 taza?
yellowssm is offline   Reply With Quote
Old 03-08-2012, 05:49 PM   #47
yellowssm
My Ride: 2005 M3
You better loose your attitude, don't think you will gain any more custumers with all this wiseguy talk.
I don't have to show you any proof. I have just tuned the worlds most powerful m3e46, ok?
If someone want some info you could write me a pm.
You kinda sound like you have a little attitude now also...
Attitude? Wise guy? Whatever...LOL
I can show you proof...why? Because I have done the testing to show it. Not only with BMW's but with SEVERAL other platforms.
It's really easy to make statements and not back them up with data, but that doesn't fly with me. You can get by with that with the people who don't do this stuff or do the testing to prove their statements, but not with me. My testing disagrees with yours. So, if you want to back up your statements, then post proof...I did, why shouldn't you have to?
I encourage EVERYONE to do the testing themselves...don't take my word for it either. You just have to know how to do the testing properly, you can't start upsetting the stock ecu by removing sensors and expect it to run the cams in an optimal position. The cams move based on volume of air. They use this to optimize airflow through the engine on power demand. They ALSO use cam movement to reduce power when things aren't what they want.
1040 hub hp....your making about 50 more hp with an 82mm turbo than I make on my car with an 67mm turbo. All I have to do to beat that number is push a button!
DOOOOOO IIIITTTTTTTTT!!!!!!!!!!!
Old 03-08-2012, 05:57 PM   #48
TaZaM3
Psshhhht M3
My Ride: E46 M3
On dyno it was 940whp at 29psi, I can go another 5psi or so.
Old 03-08-2012, 05:58 PM   #49
MSpired
My Ride: HPF Stage 2.5 e46 M3
Send a message via AIM to MSpired Send a message via MSN to MSpired Send a message via Yahoo to MSpired
You guys scared off a well known enthusiast that would only benefit us, not cool!
MSpired is offline   Reply With Quote
Old 03-08-2012, 06:03 PM   #50
lab rat
My Ride: '02 330iT
Nah, he must be used to some d*ck measuring contests when dealing with 1000hp cars.
It's great he joined the forum.
Because sleeper
Old 03-08-2012, 06:37 PM   #51
MarcusLSB
The biggest problem is there's a dick measuring contest going on but noone's decided where you get to start measuring from.
I personally only care about the following:
6 Speed Manual (original getrag)
Within 100lbs of OEM weight
Video should accompany run with time slip
Must disclose tire/wheel setup..
Must be S54.. what you've done to it doesn't matter (supercharger vs turbo, nos, e85 vs c16, vanos, no vanos, stroked, etc)
Must be fully capable of driving to the track and back .. when/if I do set any records my car will be driven to the track and back. Thats just a personal thing for me though. Trailering it makes more sense being you might brake something but theoretically you should have no issues driving the car on the street.
Must be original IRS (modifications for strengthening is totally fine..)
Maximum sectional width of tire should be 10.5"
Old 03-08-2012, 07:01 PM   #52
yellowssm
My Ride: 2005 M3
Welcome to race wars!!!
Old 03-08-2012, 07:05 PM   #53
faelar
Big Pimpin'
My Ride: M3
Just remember to have someone follow behind you with a trailer
If there is one thing I learned from drag racing.. you WILL break something. I got to where I could replace a U-joint in under 30 minutes lol!
Old 03-08-2012, 07:06 PM   #54
MarcusLSB
My track is a 3hr drive away so I'll definitely be required to bring a trailer.. its not even an option for me but i do plan on driving it there and back when possible.
Old 03-08-2012, 07:28 PM   #55
Forcefed M3
My Ride: HPF Stage 2.75
To convert to ft/lbs divide it with 1.356
SICK!!! well done
Forcefed M3 is offline   Reply With Quote
Old 03-08-2012, 07:32 PM   #56
Hobbit382
My Ride: 99-328i 00-323i
Post
Wow now who has the attitude?
Any time Jason post info he backs it up as you should.
Your the one with the wiseguy know it all attitude. "I don't have to prove anything, I just tuned the highest hp m3" wow. Besides I'm pretty sure there is more than 1 other s54 with higher hp then 1040.
Have a nice day.
Hobbit382 is offline   Reply With Quote
Old 03-08-2012, 07:34 PM   #57
MarcusLSB
Have a nice day.
That was provoked. Which Jason has apologized for. No more pot stirring.
Old 03-08-2012, 07:41 PM   #58
Hobbit382
Old 03-08-2012, 09:38 PM   #59
pianoprodigy
My Ride: 13 GTR, 11 CTT, BMW
I think that if I sold my BMWs, I would still come and check in on these threads for the drama lol.
pianoprodigy is offline   Reply With Quote
Old 03-09-2012, 10:45 AM   #60
mike@maximumpsi
My Ride: 02M3T
Hi Andreas,
Thanks for posting the vid. That power curve is nice for that large of a turbo. I can't wait to see some drag runs with the new setup.
-Mike
02 M3 - Maximum PSI S2 turbo kit - 9.74@145.99, stock motor, stock ECU, first in the 9's
97 M3 - Maximum PSI turbocharged - 8.94@164.33, stock ECU, first in the 9's, first in the 8's
16 M3 - Maximum PSI full bolt ons - 10.27@137, quickest in the US
BMW SOB's turbo E30 - 8.72@158.39
Maximum PSI - Home of the quickest BMW's in the US
Click here for E46Fanatics 1/4 mile standings
Follow us on Facebook and Instagram!
mike@maximumpsi is offline   Reply With Quote
