Forced Induction Forum Sponsored by Active Autowerke
Discuss supercharging, turbocharging and even nitrous and water injection here. Sponsored by Active Autowerke |
Rating:
Display Modes |
#41 |
tripp you gunna get a upgraded high flow inline fuel pump and upgraded oil pump from vac? they would probably help deliver the fuel better on top of injectors that josh has worked out that combo would be what you need for that hp
#42 |
:straightpimpin:
#43 |
My Ride: ZHP Custom Stage 3.5
Since, I am about to boost and thinking about keeping the GM Step Transmission.
I am planning on installing IPT Manual Valve Body. Also, thinking about getting a Performance Torque Converter as well. The New Converter stall speed will need to be at least 500 RPM higher than the beginning of the powerband of your camshaft. Anyone knows the PowerBand of the ZHP Cams? Would the PowerBand be the same when I Boost? -Trip
..::|TrippinBimmer's Boost Build with Cool Parts|::.. 4**whp/3**tq SAE Corrected |
#44 |
Here's a dyno of a zhp
AA Stage 2 330 |
#45 | |
#46 |
What are u talking about? Makes no sense...
#47 |
My Ride: 2004 330ci ZHP 6MT
As do 90% of his posts
![]() 1995 325i 5mt ArcticGrey/Dove - SOLD 2004 330ci ZHP 6MT SilberGrau/Black - SOLD 2001 330i M-Sport 5MT StaulGrau/Grey - SOLD 1992 Accord LX Sedan 275k miles all original - DAILY 2002 Chevy Suburban LT Autoride - TOY HAULER 2005 GMC Sierra 2500HD SLT - RACE TRUCK! |
#48 |
Andy - Thanks for the Graphs. Will forward it to IPT.
Here is my update for the day: Sanding Down the Snail for a Smoother Finish ![]() Plugged, Taped and Primed off Parts of the Charger ![]() ![]() Painted Semi-Gloss Black (High Temp Paint) ![]() Removed Tape ![]() ![]() Snail is Painted as well (I Primed it but didnt take pics :* ) ![]() ![]() Tapped Removed ![]() Test Fitment and Color Scheme ![]() ![]() Edit: Finished Pictures ![]() ![]() ![]() -Trip
..::|TrippinBimmer's Boost Build with Cool Parts|::.. 4**whp/3**tq SAE Corrected Last edited by TrippinBimmer; 02-29-2012 at 06:18 PM. |
#49 |
Sorry spell check and I didn't notice I would slap some shrick or ess fi cams in there if you have headers those would be at least 30 whp extra maybe more with aggressive cams and solid tune.. Zhp cams I would imagine would be between 4800-6000
#50 |
Come on man your just jealous that you work for BMW and still don't get the price I get for oil
already hooked up another member with the guy he's picking up 7 quarts of tws for 50 bucks
#51 |
Not hardly. Our guys don't get "extra oil". 7 quarts is overkill enough when most of them only take 6.9 quarts when none dry. Which most aren't. Your friends dealership must be n00bs. Lol jk
#52 |
Looking good! Can't wait to see it installed.
![]() Thanks to: www.getbmwparts.com www.aatuning.com www.toyotires.com Eurowerkz Mid-Atlantic Regional Director Join the Eurowerkz Facebook Fan Site : Click Here Need your car coded with Euro Options? (Remote Windows up, Corner delete, DRL off, etc.) PM Me |
#53 |
Nice!
So Stage 2.5 uses ZHP cams? Can't you upgrade to some FI cams, run even more boost and get more power? |
#54 | |
-Trip
#55 |
Look forward to results, I think 400+ whp is possible with what you have planned without too much trouble - the limiting factors that you will run into are injectors and increased belt slip / wear with smaller pulleys.
I covered around 7k on my level 2 setup and made 365whp, (standard level 2 pulley and Fi cams) I never had any issues and it was a beast. |
#56 |
Sorry for the slow updates. Mid-terms been kicking my a$$ lately. Been studying alot.
Picked up the m3 rear end Tuesday at the Hub Station. ![]() Here is some T-Bar Clamps. I bought to replace those wimpy worm gear clamps. ![]() Also, waiting on Viral to get me some quotes on some parts I wanted. So I can get this Project Started. Looks like I might not make it to MFest. but we will see...-Trip
..::|TrippinBimmer's Boost Build with Cool Parts|::.. 4**whp/3**tq SAE Corrected Last edited by TrippinBimmer; 03-09-2012 at 03:40 PM. |
#57 | |
These would be much easier than fussing lining up a flat head screwdriver with the slot. I could just blast them off with my air wratchet. Last edited by bigjae1976; 03-09-2012 at 05:55 PM. |
#58 | |
Parts are Arriving and I am starting to remove parts this Tuesday ![]() -Trip
#59 | |
#60 |
Hello! i tried to contact with IPT, but they keep silence. Could you ask them something for me, when you will contact them again?
Im going to put AA stage 2.5 into my 330 2002. And it has ZF transmission. So i wonder, what a need to buy to make it works right and do they have this parts for sale? Thank you very much! PS: your private is full.. |
