#1 |
Im looking for a steel single mass flywheel for my 330Ci 5spd. Im looking for to get as close to oem weight as possible since im trying to avoid chatter and idle dip/stall issues associated with light weight flywheels. I was going to order the rogue engineering performance clutch/ steel flywheel kit but the flywheel is on backorder and I need a new clutch asap. My car is stage II supercharged so oem is not an option. Please chime in if you know of any other manufactureres who offer a steel flywheel for 5spd.
Something comparable to this would be ideal, slightly lighter than stock but steel. http://www.rogueengineering.com/rogue/LTWF/PCS.html |
#2 |
My Ride: 08/2000 330Cic x2
Well they now have steel at your link. !!
#3 |
UUC doesn't have what you want?
And how about Turner? |
#4 |
Here's a good steel flywheel from JB Racing.
http://www.turnermotorsport.com/p-10...pe-z4-30i.aspx
Original Owner 2003 330Ci ZSP, 3145 lbs, 5-spd, leather, Alcantara wheel, staggered 19" BBS, ZHP FCAs/diff cover/weighted knob, M3 eng + trans mounts/outer RCABs/RCABs with Turner limiters, Group N inner RCABs, Bilstein Sports (E36 M3 rears), H&R Red springs/Sport bars, BMW Performance Rotors, Turner caliper bushings, StopTech lines, Borla, RE pullies/RSM, Stewart WP, M-Technic Trunk Spoiler, Mason pedal/strut bar/end links, B&M shifter, UUC DSSR
#5 |
Turner installed a UUC steel flywheel and M5 OEM clutch in my 330ci. This flywheel is lighter than OEM but the whole package is only minimally lighter. I do have some gear clatter in neutral with the clutch released but only on hot days. I'm Ok with it! You might want to check out UUC's new dual clutch setup?
#6 | |
And for those who may be wondering, I've been running a stock clutch and flywheel with the ESS TS2+ SC'er for 4 years and 60k+ miles now. FI doesn't automatically mean that you need a clutch/flywheel upgrade.
| Tags |
| clutch, flywheel, noise, swap, transmission |
