Go Back   E46Fanatics > BMW Regional Forums > Regional Forums > California
California
Northern California Southern California
Thread Tools Search this Thread Rating: Thread Rating: 10 votes, 3.70 average.
Old 02-12-2012, 01:24 AM   #1961
issacsierra06
My Ride: bmw 325i
got to many cars, need to consolidate! LOL
Dont need much money but can't get much extra for car with extra mods so im slowly piecing parts off! been shipping out parts
READ BEFORE YOU BUY
issacsierra06 is offline   Reply With Quote
Old 02-12-2012, 04:54 AM   #1962
Richneerd
My Ride: Abarth
lol, nice! how many cars you own now?
Richneerd is offline   Reply With Quote
Old 02-12-2012, 01:16 PM   #1963
issacsierra06
My Ride: bmw 325i
Got 3! (ssbpDC2,e46,V6accord) thinking about buying a m3 down the road...... but not for a good time from now
READ BEFORE YOU BUY
Old 02-13-2012, 04:09 PM   #1964
DevilDoc87
My Ride: 328Ci 323Ci
Spotted a Black E46 M3 with a vented gtr hood csl trunk and dtm style exhaust tips by the roseville automall yesterday around 3pm ish.
-Justin-
DevilDoc87 is offline   Reply With Quote
Old 02-13-2012, 07:46 PM   #1965
ilee21
My Ride: 2004 M3
That was me! While I was there I also spotted a silver e46 m3 with a wing and I think iforged wheels.
ilee21 is offline   Reply With Quote
Old 02-13-2012, 08:19 PM   #1966
DevilDoc87
Nice I couldn't tell if the hood was vented at first but when you turned onto N. Sunrise I could see it better. I was driving my Ex gf's black 328ci nothing special so you wouldn't have noticed it.
-Justin-
Old 02-16-2012, 04:31 PM   #1967
Richneerd
My Ride: Abarth
Baller! btw contact me asap. I have someone interested in your car. Check your PM!
Old 02-16-2012, 09:04 PM   #1968
FireWater
My Ride: 04 330ci zhp
Saw a white 1M today in Sac tonight of all places. Such a clean car.
FireWater is offline   Reply With Quote
Old 02-17-2012, 01:27 AM   #1969
issacsierra06
My Ride: bmw 325i
saw a black 03 ///M5, car has some balls!
READ BEFORE YOU BUY
Old 02-20-2012, 01:09 PM   #1970
Richneerd
My Ride: Abarth
LOL glad you loved it. It's really comfortable isn't?
Old 02-21-2012, 02:28 AM   #1971
issacsierra06
My Ride: bmw 325i
rides smooth and fast!
READ BEFORE YOU BUY
Old 02-21-2012, 02:58 AM   #1972
ANREC330
My Ride: C6 Vette & M3
Spotted this in Manteca a couple days back.
ANREC330 is offline   Reply With Quote
Old 02-27-2012, 01:54 AM   #1973
Richneerd
My Ride: Abarth
Just bought a beater! finally the beast can sleep at home.
Old 02-28-2012, 12:48 PM   #1974
issacsierra06
My Ride: bmw 325i
nice any pics of the beater?
READ BEFORE YOU BUY
Old 03-01-2012, 12:46 AM   #1975
Richneerd
My Ride: Abarth
Just got a Mini Cooper S
Old 03-04-2012, 03:02 AM   #1976
Richneerd
My Ride: Abarth
Yeahhhhhhhhhh!, did inspection 1 and omg the car is totally different! Intel helped me change the Oil, Oil Filter, Cabin Filter, Transmission Fluids and programmed the lights to blink when you lock the car.
MINI Inspection I:
Undercarriage
Change oil and oil filter while engine is at operating temperature.
We recommend MINI Synthetic Motor Oil, p/n 07 51 0 143 829
Check transmission for leaks.
Change CVT (automatic) transmission fluid.
Half shafts: Check for leaks at flexible boots.
Visually check fuel tank, lines and connections for leaks.
Check condition, position, and mounting of exhaust system. Examine for leaks.
Check power steering system for leaks. Check p/s fluid level; add fluid if necessary.
Check overall thickness of front and rear disc brake pads (outer pads only) using special tool.
If replacement is necessary:
Examine brake disc surfaces. clean brake pad contact points in calipers. Grease wheel centering hubs.
Check thickness of parking brake linings only when replacing rear pads.
Check steering for absence of play, condition of suspension track rods, front axle joints, steering linkage and joint disc.
Check brake system connections and lines for leaks, damage, and incorrect positioning.
Check parking brake actuation. Adjust if necessary.
Check all tire pressures (including spare). Correct if necessary. Check condition of tires (outer surfaces [left/right]), tread wear and pattern; in case of uneven tread wear readjust wheel alignment if requested.*
Note:If requested rotate all four road wheels as instructed and rebalance.*
Inspect entire body according to terms of rust perforation limited warranty (must be performed at least every two years).
Engine Compartment
Read out diagnostic system.
Check engine cooling system/heater hose connections for leaks. Check coolant level and antifreeze protection level; add coolant if necessary.
Note:Coolant must be replaced every 4 years (time interval begins from vehicle's production date).
Check level of brake fluid in reservoir. Add fluid if required.
Replace brake fluid every 2 years (timing interval begins from vehicle's production date).* Will do this probably next year.***
Check windshield washer fluid level and antifreeze protection. Fill up and/or correct if necessary.
Check air conditioner operation.
Replace microfilter.
Note: reduce replacement interval in dusty operating conditions.
Reset Service Interval Indicator.
Body/Electrical Equipment
Check battery state-of-charge, and charge if required.*
Check lighting system, i.e., headlights, foglights, parking, back-up, license plate, interior, glove box, illuminated make-up mirrors, luggage area lights.
Check instrument panel and dashboard illumination.
Check all warning/indicator lights, check control.
Check turn signals, hazard warning flashers, brake lights, horns, headlight dimmer/flasher switch.
Check windshield and tailgate wipers and washer systems; wiper blades, washer jet positions.
Check condition and function of safety belts.
Check central locking system.
Check operation of all latches.
Check heater/air conditioner blower fan, rear window defogger.
Check rear view mirrors.
Visually examine the SRS airbag units for torn covers, obvious damage or attachment of decals, decorations or accessories.
Final Inspection
Road test with check of brakes, suspension, steering, automatic transmission.
Visually check shock absorbers for leaks.
Old 03-07-2012, 03:54 PM   #1977
Richneerd
My Ride: Abarth
Oh no! Man down! Intel has a bad leg, time to borrow his tools since he cant use them .
Old 03-07-2012, 11:29 PM   #1978
intelone
My Ride: e46 M3
Its my knee that hurts. VA doc says I should keep off of it for a while. Its either from running or basketball. Blame it on the Marine Corps, they emphasize too much on running. I should be completely fine after a month or so. Planning on finishing two marathon later on this year.
I placed a bid for climbing yosemite's half dome on september 9th, with an alternative choice on sept 23rd for six people. I got three other friends going with, so if the group get pick in the lottery system, then I would have room/ticket for two more people for the hike up. Anyone interested as well?
Summer is coming up, so there's plenty of runs, sports, hiking, obstacle courses, mud runs, biking, rafting, swimming and what not. Be active with the car, and active with the body. Just remember yosemite, kings canyon, and the sequoias are in our back yard.
Here's the 10 mile run precursor to the basketball game that probably hurt my knee. Nice pace, and a good distance.
intelone is offline   Reply With Quote
Old 03-10-2012, 02:28 AM   #1979
Richneerd
My Ride: Abarth
I could barely run half mile. Probably take me 10 minutes to do 1 mile. HAHAHA, I know I'm skinny as hell and have no strength.
Old 03-13-2012, 06:37 PM   #1980
intelone
My Ride: e46 M3
EuroSunday is coming up. Save the date.
DATE
Sunday, March 18th, 2012
TIME:
8:00 - 11:00am
RaceRoom Fresno @ River Park
80 El Camino
CA 93720 Fresno
Pic from last EuroSunday, e46s gotta represent. We're losing out to the older generations. Don't forget to register at eurosunday.net to get emails on upcoming events. Event location is not always the same, so email is how you get to be in the loop. There's plenty of gear heads that shows up; plus its great from a networking standpoint. Nuff Said.
Update: Knee still hurts. Just swapped out my fcab, passenger side felt a little wobbly when braking, so it was time to R&R it. Looking at the pics, the passenger fcab completely failed, and collapsed. Stupid bmw putting that fcab so close the the hot hot headers. Didn't want to go poly or powerflex, since I welcome the comfort and quietness of OEM. Plus I already did my rtabs with OEMs; might as well keep it all stock. Used the crowbar method to take off and put the fcab on the control arm. So simple. I'm out to ice the knee. Enjoy.
Rate This Thread
