E46 Xi Forum
Old 03-14-2012, 11:14 AM   #1
brianc617
My Ride: 2003 325Xi
Transmission Problems?
Ok I just purchased a 2003 325xi it has 105,000mi first thing i noticed was that when in drive the rear end pulls down the when put into neutral the car will rise back up, Second after about thirty miles on the highway at speeds about 65 it started to vibrate and loose power i could tap on the gas petal and the issuse wold stop for about thirty more miles. This is my first BMW and would like see if anyone had a thought on this. Thank you
brianc617 is offline   Reply With Quote
Old 03-14-2012, 04:44 PM   #2
Gus330vrum
My Ride: 330ci
Make a video, post here! Use YouTube!!!!
Free diagnostic by forum lol
GL. Manual or auto?
Gus330vrum is offline   Reply With Quote
Old 03-14-2012, 04:50 PM   #3
SamDoe1
My Ride: 4cyl of fury
GL. Manual or auto?
Judging by the fact that he puts it into drive...I'm going to go out on a limb and say auto...
Old 03-14-2012, 04:56 PM   #4
deadwood83
My Ride: has an iron lung
Send a message via MSN to deadwood83
Detailed maintenance history? Mine does the same thing (the drop is minimal) and what you're experiencing is your rear suspension being tired and soft. I parked next to an E46 xi and my suspension was about .25" lower because mine has 83.7k miles on rough roads and not a single suspension component has been changed from the factory (control arms excepted).
When you put it in 'D' there is suddenly a torque being transferred through your drivetrain. This torque applies a 'preload' of sorts that is transferred through your suspension geometry. It's the same principle as when people floor it their rear end sinks a bit.
AA Stg2+ 325xiA? Are you stupid? Maybe a little.
I can program cars fo' freeee near Salt Lake City. PM for details.
deadwood83 is offline   Reply With Quote
Old 03-14-2012, 06:05 PM   #5
Gus330vrum
My Ride: 330ci
Hehehe! Sorry, I don't know what's into drive.. Cuz me have a manual.
Old 03-14-2012, 06:28 PM   #6
Ryan@GF-Performance
Past Site Sponsor
The car bobbing down when going from N to D is normal. In neutral there isn't any power reaching the wheels, when in D you are in gear and the car is trying to move. The car is just pre-loading the suspension because it is trying to move, that's all. I have a feeling your loss of power issue is not transmission related.
Ryan@GF-Performance is offline   Reply With Quote
Old 03-14-2012, 07:13 PM   #7
brianc617
My Ride: 2003 325Xi
Thank you for the help the car was my brothers it was well maintained the rear springs were changed last year. The only thing I did not see being done was the fuel filter so I am hoping when I change that will help with the power loss one the highway. So far after sea foaming the engine I have already noticed a big improvement. Planning on changing all fluids soon any other recommendations?
Old 03-14-2012, 07:21 PM   #8
deadwood83
Vibration at above 65 is a classic CV boot symptom. You might still be able to save the axles if they're torn. Not sure about the loss of power bit though. Sea foaming is... well not my cup of tea. There are roughly 1.5 billion fluid threads so do a search. The xi subsection of the forum will be your ally in drivetrain maintenance.
Old 03-14-2012, 08:14 PM   #9
brianc617
My Ride: 2003 325Xi
I was thinking axel but it is very random I did check the boots they are in good shape I can go over 65 without vibration on short trips it felt like It was miss firing the problem would increase when going up hill. Is the awd not equal front and rear and I'm guessing the vibration in D means engine mount? Sorry for all the questions and thanks for the help
Old 03-15-2012, 10:39 AM   #10
Hogan773
My Ride: 2002 325xi
If the vibration comes only when accelerating (when you say up hills that was a tip off) then its likely an axle going bad.
Hogan773 is offline   Reply With Quote
