Thread Tools Search this Thread Rating: Thread Rating: 1 votes, 1.00 average. Display Modes
Old 03-22-2012, 02:04 AM   #21
cityjohn
My Ride: 2001 M3
Originally Posted by E30m3ochoa View Post
So this is an update, I tested the solenoid and it seems to be working. The rod extends when locked and retracts when unlocked. Any ideas as to what it could be?
It is your spring for sure! Buy part no. 51171888374 and clip it in -- your door will hold shut once again. It is one of the cheapest Genuine BMW parts you can buy at the dealer!
Highlighted your pic in yellow.
cityjohn is offline   Reply With Quote
Old 03-22-2012, 03:28 PM   #22
Shanealan
My Ride: 325i No heatbeat yet
Thanks cityjohn, I have the exact problem with my car!!!
Shanealan is offline   Reply With Quote
Old 03-22-2012, 06:50 PM   #23
E30m3ochoa
My Ride: E46 325ci
Thanks but how do i remove it?
E30m3ochoa is offline   Reply With Quote
Old 03-22-2012, 06:55 PM   #24
TX78666
My Ride: 330i ZHP, N55 135i
So I looked at the part you were talking about but I am not to sure what you are saying. I took some pics but I don't know if they will be good enough for you to see how it is.
How would you roll the filler gasket back?
Spray the part in these pics with graphite. That's what fixed it for me. Grease might be better, but graphite is what I had on hand. Be sure to have a paper towel or rag, to keep the spray from going everywhere. If it does, goof off gets it off.
Because... Grocery Getter.
TX78666 is offline   Reply With Quote
Old 03-22-2012, 07:04 PM   #25
cityjohn
My Ride: 2001 M3
Using needlenose pliers, pull the center of the spring out from the slot in the door. The loose spring can now be slid down, then up, out of the holes holding the ends.
When you put the new one in, do the ends first, then the middle just pushes into the door's slot until it's clipped in.
Old 03-24-2012, 12:55 PM   #26
E30m3ochoa
My Ride: E46 325ci
Thank you guys, I went yesterday to get the part and I was surprised to hear that it was going to cost me .54cents. By the way, I saw some pretty awesome cars
Going back to the topic here, so it turns out that the malfunction was being caused by a groove that was forming on the spring. I replaced it with the new one and it worked like a charm. Now I can be pleased to know that my tank door is secured and locked.
Thanks a lot guys for you help and I hope I wasn't to much bother. I appreciated the help.
On a side note, does anyone know where to get the harmon kardon stocked speakers?
Old 03-27-2012, 07:40 AM   #27
Shanealan
E30m3ochoa, I got you beat, .43 cents at my local stealership. And my fuel door works now like it should.
Old 09-06-2014, 03:53 AM   #28
glhx
My Ride: 2002 330ci
Just to update this as I was doing a search.
What jfoj was talking about is here in this picture.
This filler neck gasket is new
The rubber you see around the edges wraps back toward the body.
Goes back around the sheet metal lip. Being new this piece does not want to stay. I'll have to put some glue on the top to get it to stay until it breaks in. Or use a heat gun........right now the fuel door won't close. It stretches around the metal fine but unwinds itself and comes back to what you see here
The rubber boot that goes over the clicker device is not installed yet. It will have to come back out to be pug on
glhx is offline   Reply With Quote
