E46 Convertible
Old 02-02-2012, 03:10 PM   #21
jeagolf
My Ride: 04 330Ci Vert
Has anyone tried to "push" this thing open after it stopped? If so I can tell you how I fixed mine with the same problem.
jeagolf is offline   Reply With Quote
Old 02-02-2012, 04:01 PM   #22
savage33
My Ride: 2001 330 CIC
More info the better. Tell us how you fixed it?
savage33 is offline   Reply With Quote
Old 02-02-2012, 07:00 PM   #23
jeagolf
The aircraft cables under the manual override were bent and would stop at the same point, or open only to the same point.
Old 02-03-2012, 03:27 PM   #24
savage33
So by unbending them you corrected the problem? was that all?
Old 02-03-2012, 04:28 PM   #25
jeagolf
Yep!! Got 3500 off the price of the car because the dealer thought it was an electric vert top and that the shafts and motors needed to be replaced.
Old 02-23-2012, 09:45 PM   #26
dsmer323
My Ride: e46 m3
finally narrowed it down. it appears too be a wire but now my front lock mechanism broke when putting the soft top down manually looking at $800 or more.
dsmer323 is offline   Reply With Quote
Old 02-23-2012, 09:47 PM   #27
dsmer323
My Ride: e46 m3
the passenger side front lock on the soft top stopped working and now its not closing properly
Old 02-24-2012, 09:03 AM   #28
savage33
Can you let me know what wire it was? where it's located?
Sucks that it broke
Old 02-28-2012, 08:23 AM   #29
fmzip
My Ride: '08 328xi / '01 530i
Read post #18
http://forum.e46fanatics.com/showpos...4&postcount=18
fmzip is offline   Reply With Quote
Old 03-03-2012, 12:20 AM   #30
dsmer323
My Ride: e46 m3
The wire was a green and black also the. Brown wires were stripped. The wires are located on the driver side front soft top. Ill try to snap some pictures of where the wires are located..
Old 03-06-2012, 09:16 AM   #31
savage33
Thanks guys i appreciate all the help.
The car comes out of storage in a couple weeks and would love to fix it immediately.
Yes storage, not wise to drive these cars in Canadian winters.
Old 04-03-2012, 08:45 AM   #32
savage33
So i removed the harness yesterday and the brown and yellow wire had snapped in half.
repaired with old wire laying around the house and walla. everything work perfectly.
Old 04-03-2012, 07:21 PM   #33
jfoj
My Ride: 330CiC, M5, X5, E93
Where were the wires broken? In the area of the fold over a window.
Old 04-05-2012, 09:53 AM   #34
dsmer323
My Ride: e46 m3
Mine were broken on the first fold of front driver side soft top. I would post a picture only if I knew how to.
Old 04-05-2012, 02:03 PM   #35
fmzip
I assume its the same area that I originally told you to look???
MOD's, please sticky this, seems to be alot of threads being started about top issues
http://forum.e46fanatics.com/showthread.php?t=790169
Old 04-05-2012, 02:49 PM   #36
dsmer323
My Ride: e46 m3
Smile
[QUOTE=fmzip;14263287]I assume its the same area that I originally told you to look???
Correct,its where you had told me, thnx bro.
Old 04-05-2012, 08:07 PM   #37
fmzip
^^^ Awesome!
Old 01-27-2013, 07:21 PM   #38
Maxun
My Ride: 330ci convertible
Thanks, for the tips.
thanks so much for the pictures, the whole thread is fantastic.
_nr_
Maxun is offline   Reply With Quote
Old 02-02-2013, 07:51 PM   #39
dkuchta
My Ride: 325cic
Nice post!!
Did this fix your top problems? did you have a rear defroster problem too?
Also what were your symptoms when is stopped working?
I must say, I had the exact same issues. I checked everything... and this was it... I would say, cut the wire lume(sp) and see if any wires are broken or very bent.
dkuchta is offline   Reply With Quote
Old 02-03-2013, 10:57 PM   #40
fmzip
Glad the pics helped!
