Go Back   E46Fanatics > Everything Else > The Off-Topic > Gun Talk
Gun Talk
Are you a gun fanatic as well? If so, you'll want to talk to other owners about what you own in this forum.
Old 04-07-2012, 03:04 PM   #1
Rush4theYehO
My Ride: XI fts(now)
A little glock help?
Picked up the 3.5lb connector for my G19. I've detailed stripped my glock before, so this isn't the first time I've had to do this. I've installed the flat trigger before. However - I ran into two small issues and not sure what to do.
#1. The second frame pin (the lower of the two on a Gen 3) will NOT budge. I'm applying a ton of force to it. How the heck can I loosen it up so I can get it out??
#2. The slide stop spring is in the way of the top frame hole and now I can't re-insert my first pin back through. If you hold the frame up against the light, you can see the end of the spring blocking the hole. Just push the spring aside with a pin and jam the freaking pin back home??
Rush4theYehO is offline   Reply With Quote
Old 04-07-2012, 05:43 PM   #2
Reedo302
Reedo302's Avatar
My Ride: F30 328i M Sport
The lower pin is the trigger pin. You have to use one hand to sort of push or pull the slide lock lever forward or back, as that is what is locking the pin in place. As you move it forward or back, push on the pin. Once you have that removed,pull the slide lock lever out, then you can reinstall the locking block pin and put the slide lock lever back in and reinstall the trigger pin.
DINAN3 F30 328i M Sport
DinanTronics Stage 1
Dinan Free Flow Black Tip Stainless Exhaust
Dinan Lowering Springs and Bumpstops
Dinan 20" Black Performance Wheels
Gunfighter Training Development and Evaluation
AR15/AR10 Armorer/Advanced Armorer
Glock Armorer
Gunfighter Training YouTube Channel
Reedo302 is offline   Reply With Quote
Old 04-07-2012, 08:13 PM   #3
Rush4theYehO
Now I think I bent the slide stop spring....when I install everything - it rests upwards at an angle.
Old 04-07-2012, 08:34 PM   #4
Reedo302
Reedo302's Avatar
Bend it back. You'll be fine.
Glock Armorer
Old 04-07-2012, 08:37 PM   #5
Rush4theYehO
Ok, everything is back in working order...thanks Reedo.
An aside - after I installed all the parts, etc....the slide is kind of difficult to rack. requires a significant amount of force to do so. What the hell??!?!
Old 04-07-2012, 08:57 PM   #6
Reedo302
Reedo302's Avatar
Check for any kind of obstruction or friction along the top of the frame. Also make sure the recoil spring is installed correct.
Might not be a bad idea to disassemble and reassemble the parts, if necessary.
Glock Armorer
Old 04-08-2012, 02:10 AM   #7
Rush4theYehO
Back in business - thanks again! Locking lug was just a little dry. A drop of oil took care of that. You've got a pitcher of brew on me if you ever find yourself in LA Reedo.
Old 04-08-2012, 10:02 PM   #8
kaput
My Ride: 2002 M3 SMG
Send a message via AIM to kaput
I know I am late... But:
2002 M3
kaput is offline   Reply With Quote
Old 04-09-2012, 07:32 PM   #9
XKxRome0ox
Black and Proud
My Ride: RIP e46/'16 328i
WWRD
what would reedo do?
2016 BMW 328i 6MT/M Sport Package/Track Handling Package/BMW M Performance Exhaust/Injen CAI
XKxRome0ox is online now   Reply With Quote
