Gun Talk
Are you a gun fanatic as well? If so, you'll want to talk to other owners about what you own in this forum. |
#1 |
Master of his domain.
MY first carbine class
This was my first carbine class, and a friend of mine flew down from NJ to join me. I’ve never been in the military or had any other training of this type carbine. If any of you guys have specific questions, please feel free to ask.
Goals for the class Role of the repeating carbine/rifle in combat. Selection considerations and attributes of weapons and accessories Gun handling that works in a 360 degree environment Sling techniques, mounts and dismounts Load & Reload methods Transitioning to the handgun Precision engagement Multiple engagements Shooting on the move Field firing positions Snap shooting techniques Fire and movement drills ECQB with the carbine/rifle Gear BCM Lower with Sprinco Blue Buffer Spring and H2 Buffer Spikes Upper with Battle Comp 2.0 Eotech XPS2-0 MS3 Sling Glock 19 with Trijicon HD sights (orange) and Vickers extended mag release Brokos Battle Belt with HSGI Taco mag pouches and G-Code Holster My friend used a LWRC Tricon with an ACOG. Actual Round Count Over 600 rifle Federal XM193 Over 100 Federal 9mm Class time 10 hours Going in I was a bit worried that I wouldn’t perform to the best of my abilities. Last month I crashed on my mountain bike and sprained my shooting wrist and ended up with a herniated disk (L5/S1). I won’t bore everyone with a minute by minute synopsis; I’ll touch on the high and low points. We started the day with some simple pistol drills, so I was going to test the wrist out immediately. I was pleasantly surprised, as it held up fine and I shot well so I knew that I would be okay for the rest of the class. High Points - Using my gear the way it was intended to be used. - Understanding my gear placement and how to adjust it to better suit my needs. - I was able to practice techniques that I had only seen on video. - All of the different drills. - Three Little Kittens; this is a drill that was created by Kyle Lamb. The instructor takes three ARs and purposefully creates a malfunction in each one. They are placed down on the ground next to each other and the student must go to each one and fix the malfunction and then put two rounds down range before moving to the next. - By far my favorite drill was with working with a partner. We were ten yards apart, and about ten yards from the targets behind cover, with more cover about ten yards behind us. On command, we start firing and have to communicate with each other while moving forward and back, covering during the move and covering while the partner is reloading. When the rifle ran dry, we transitioned to pistol. This drill basically incorporated everything that we did throughout the day into one massive shoot. We did the drill several times, and had to take brakes because the guns were so hot we could not handle them anymore. Low Points - Both instructors were former military and I’m not. I’m not used to being instructed in the “forceful” manner that I found myself in. - Sometimes we received conflicting commands from the instructors. - There are usually several ways of getting the same result (tap/pull magazine, racking the charging handle, etc). I would have preferred a more open mind to different techniques. - About half way through the day my wrist started to tighten up on me. As a result, it was difficult to hold some of the positions. - I need to lose some weight from my AR. That ***** gets really heavy when holding it up for more than a minute. My takeaways - I need to figure out how to better manage my frustration when I don’t perform well or don’t perfect a technique immediately. This was very evident during the malfunction drills. - All of my gear worked flawlessly. - I have some adjustments to make on the Brokos belt. This is the current set up (although I had added a second pistol taco in the first molle strip after this pic was taken): ![]() - I would like to remove the two pistol tacos and move the second rifle taco up to that spot. I will then mount one pistol taco on each rifle taco. It was a bit difficult to reach back to the second taco where it is currently mounted. If a class calls for me to carry more mags, I would mount another rifle taco where the second one currently sits. If not, I would leave that space open. - I will move the dump pouch from the six o’clock to seven. It’s very uncomfortable when you are lying on your back or sitting in a chair. - It’s very important to stay hydrated. I was guzzling water all day long and only pissed once. - My friend’s LWRC performed well. During the partner drill where we had sustained shooting, his rail got so hot where the gas is expelled he had to switch to his forward grip. - Regardless of the temperature outside, I will always wear pants. I burned my calf twice from the BC while transitioning from primary to secondary weapon. - One of the instructors called me a ***** for lubing up my BCG prior to shooting for the day. He stated that he hadn’t cleaned or lubed his in months. His rifle stopped working half way through the class. ![]() - The Battle Comp was excellent at keeping me on target and mitigating muzzle rise. - The Trijicon HD sights on the Glock were money. Sooo much better than the stock sights. - The muzzle brake on my friend's LWRC was a *****. It really sucked shooting next to him. Overall, I was very pleased with the class. After ten hours, we were dreading the hour and a half ride home because we were both completely exhausted. I will definately take more classes in the future.
#2 |
What was the name of the course, and who put it on?
#3 |
Urban Carbine, lead instructor was Jim Clark.
I forgot to mention something else that the instructors did that was actually very helpful. They loaded up a bunch of our mags and randomly included dummy rounds. It was different from the ball and dummy drill that I've done before, in that we were in the middle of a different drill and had to problem solve.
#4 | |||||||||
Was it a beginner level, or advanced level?
I have some observations/questions. I have never taken this course, so I'm looking at this from the outside and making an outsider observation, so please excuse me if I go overboard. Quote:
#5 | |||||||||
![]() Last edited by Serbonze; 04-12-2012 at 12:52 PM. |
#6 |
The number one thing I hate is seeing people with 30 pounds of crap strapped onto their AR-15. Glad you learned the lesson that more is not better.
-Mike
** Removed ** Ask an Insurance Adjuster Anything Cup of Joe for a Joe! http://www.greenbeanscoffee.com/coj/ buy my car! |
#7 |
The only thing on it is the Eotech and my BUIS. If this is something that I continue on with, I'll start looking at each component individually to focus on weight reduction. As I said in my original post, I think the first thing to look at is the 12" rail that I'm currently using. I very much like the longer rail, since my arms are so long. However, it weighs 16.89oz. The Daniel Defense 12" Omega is 13.4oz, and I've also got my eye on the Troy TRX Extreme 13 rail 11.3oz. Obviously, it's a completley different rail type so I would want to try it out before I made any kind of switch.
#8 | |
-Mike
#9 |
Because I bought a complete upper and it came with a full rail.
![]() Last edited by Serbonze; 04-12-2012 at 04:07 PM. |
#10 |
gotcha
-Mike
#11 | |
Did they do a zero at the beginning? If so, what zero did they use?
As far as doing things different ways, that's going to happen with every course you take. Each instructor will have a different method. I personally prefer push-pull on the magazine, as I have seen slapping the base of a magazine cause double-feed when seating on an open bolt. I hit the ping-pong paddle to release the bolt, but some instructors believe in yanking the charging handle. Jeff Gonzales (former SEAL) of Trident Concepts is big on pulling the charging handle to release the bolt. He also indicates that you need to have a proper charging handle to do this, like a BCM or PRI. I am going to a TRICON class later this year, and while I don't like the charging handle technique, I'll do it while at class to give it a shot. Even something as little as immediate action drills varies by instructor. I'm a push-pull-rack-n-roll person. Some people teach tip-tap-rack. It's all about what works best for you for the most part. Some stuff works better, some does not. In reading the course description, it sounds like this is more of a "survey" or "Intro 100" type course. When you go into 2- and 3-day courses, you will get a much higher level of training (usually), since you can dedicate a lot more time to each individual skill. When you said this: Quote:
Don't beat yourself up over this. The fact that you came out of the course with an understanding of what you're capable is enough to indicate that you probably took away everything you could from the course.
#12 | |||
I'm interested to hear if Jeff runs the LWRC Tricon during the class, since he put it together, and that's what my friend was using. It ran well, with the only issue being the heat build-up around the top rail where the gas is vented. I guess it's a trade off, hot lower reciever or hot rail. He had a forward grip mounted as well so he switched to that (broom handle grip), where I never had to switch my grip at all. But I guess that's another discussion all together...
#13 |
Jeff does run the Tricon LWRC.
Does your friend ever have any issues with his piston return spring? Or does he regularly replace it?
