E46 Convertible
Thread Tools Search this Thread Rating: Thread Rating: 1 votes, 1.00 average. Display Modes
Old 04-13-2012, 11:24 AM   #1
illestminimike
My Ride: Project Drama
Valentine 1 Hardwire
How do you Hardwire a valentine one with a convertible? All the DIYs are for cars with sunroofs.
Old 04-13-2012, 02:26 PM   #2
jpk226
My Ride: 325cic
I believe there is a way to tap the power of the rear view mirrior but for me I have hardwired two radar detectors into my Convertible I used thishttp://www.amazon.com/gp/product/B00...00_i00_details and a direct wire kit. I did a 9500ix with the direct wire. The kits are avalible on ebay for around $10 you may also want to look into a concealed display and Savvy for the V1. Accessories that some users like to have with their V1.
jpk226 is offline   Reply With Quote
Old 04-13-2012, 05:21 PM   #3
illestminimike
I was thinking about getting the concealed display and putting it in the ashtray. But sometimes I use the ashtray.
Old 04-13-2012, 06:42 PM   #4
ej205gdb
My Ride: E36 M3 / E46 M3 / B8
i did mine like this
ej205gdb is offline   Reply With Quote
Old 04-14-2012, 01:10 PM   #5
BWOODM3
My Ride: 2002 M3 convertible
WOW...impressed. Good work
BWOODM3 is offline   Reply With Quote
Old 04-14-2012, 01:44 PM   #6
illestminimike
Mmmm not sure if I like it in between the rear headrest.
Old 04-18-2012, 11:21 PM   #7
illestminimike
Bump for more suggestions.
Old 04-19-2012, 12:10 PM   #8
fmzip
My Ride: '08 328xi / '01 530i
Pull out the over head light. With a multimeter, look for a 12volt source and ground, typically a brown wire with yellow stripe is power if my memory serves me correctly.
That's how I hardwired my V1
fmzip is offline   Reply With Quote
Old 04-19-2012, 03:26 PM   #9
illestminimike
And yours is mounted next to the mirror? I kind of prefer it to be at the bottom of the windshield.
Old 04-19-2012, 03:50 PM   #10
JJR4884
My Ride: BMW
from what i have read, middle of the windshield is perfect... looking at mine, the rear detector should have a clear view back, so not too high where the mirror is blocking it... about half way down will give you perfect clearance, and it isn't very obstructive on your view either... kinda blends in with the mirror for me
JJR4884 is offline   Reply With Quote
Old 04-19-2012, 06:47 PM   #11
fmzip
Mine is by the rear view mirror.
I don't see how you can get solid rear coverage if it's mounted low.........
Old 04-27-2012, 03:46 PM   #12
johnrando
My Ride: '06 330 CIC ZHP
Same with my wires by the interior lights. The V1 is on the right side of my rearview, as I use a StealthOne Module for viewing (alerts come on the Nav).
John '06 330 Cic ZHP
Southern California
ZHP, Cold Weather Pkg., Leather, Jet Black/Black/Black Cube, NAV
AA Tune, Sprint Booster, BMW Perf. Intake, Magnaflow Exhaust, Dinan STEP S/W & TB, TMS Pulleys, H&R Touring Cup Kit
BMW Perf. Strut Brace, Orion V2 Angel Eyes, No-holes License Plate, SMG Paddle Shift Mod, Besian VANOS, Gold DISA, Fan delete
Old 04-29-2012, 05:44 AM   #13
RGO325CiC
My Ride: '01 325Ci 'Vert
I ran a CAT-5 up the pillar and exited it at the side of the overhead light housing. I clip the detector to the visor when I use it. Have the remote mod velcro'd to the middle of the gauge cluster, with the CAT 5 coming up from behind the steering shaft cover. When I leave the car, I remove both, and have only about 2" of CAT 5 visible. Hard to see from the outside.
'01 325CiC
- Steel Grey Met; Tanin Red leather; Myrtle trim; etc.
RGO325CiC is offline   Reply With Quote
Old 04-29-2012, 10:29 AM   #14
M00P
Location: El Pueblo Nuestra Senora la Reina de los Angeles de Porciuncula
My Ride: e46 m3, e36 sedan
I bought the glovebox flashlight adapter from the dealer for $15. Plugged the cig adapter into that and tucked the one wire up the A pillar with a spoon (didn't remove it) and the other wire to the consealed display in the ash tray.
You just have to remember to turn the power off of the unit when you exit the vehicle. I use my radar detector about 20% of the time I drive so not much of an issue for me. Hearing all those beeps on the street when there is no way for me to speed is annoying.
M00P is offline   Reply With Quote
Old 04-29-2012, 07:27 PM   #15
McGary911
My Ride: 2004 M3 Convertible
I've wondered if anyone's ever mounted one in the passenger seat headrest. With our roll bar rear headrests, they won't go there (although there's a piece of plastic backing in there that might not be too hard to butcher. I was looking at that yesterday.
McGary911 is offline   Reply With Quote
Old 08-16-2012, 05:53 PM   #16
illestminimike
Bump. Still haven't done it. I hate plugging it in all the time. So would the map lights work?
Old 08-17-2012, 11:19 PM   #17
fmzip
Yes..............
Old 09-03-2012, 02:52 PM   #18
illestminimike
Yes..............
Last question, do you have to have the lights on for the V1 to turn on? And does the V1 turn on when the car is off or do you need to turn it on and off manually?
Old 09-03-2012, 02:57 PM   #19
Solidjake
Zero. Leaks.
Solidjake's Avatar
My Ride: '02 330i 6MT
Buy longer 4 wire telephone cable, run it down the a pillar into the shifter area. I have all of my gadgets wired there.
Old 09-05-2012, 10:01 PM   #20
illestminimike
Well I opened up the interior light and the only wires in there is for the harness for the map lights. I dont think I can tap that for it. I wish Jake was local and could just do it for me.
