///M3 Forum
Old 04-11-2012, 12:32 AM   #1
MattEM3
My Ride: 2003 BMW M3 SMG
Cool Help me find my coolant leak...
I have an 03' M3 SMG transmission
I first noticed the leak after a trip of "spirited" driving. Originally, it looked as if the upper radiator hose was dripping coolant, I replaced the hose and still the leak persisted. Turns out that the coolant was seeping onto the belts and pulleys and shooting up onto the upper hose and dripping down from there
Something I noticed after doing some personal research that probably is relevant (but I don't want it to be) is that the radiator fan, connected to the water pump (obviously) is loose and a noise comes from the front of the car (most audibly at start up)
My question is, is there any where else that this leak can be coming from besides the water pump? Because I really don't want to spend $500 if I don't have to...
and if I do, does anybody have a DIY step by step for replacing the water pump?
Thanks guys
MattEM3 is offline   Reply With Quote
Old 04-11-2012, 10:35 PM   #2
MattEM3
Nobody has anything to say about this?
Old 04-11-2012, 10:46 PM   #3
bimmerfan08
My Ride: F
Its most likely your water pump. I had the same issue. Heres my DIY. Its meant to be an easy to read and follow along guide.
http://forum.e46fanatics.com/showthr...735&highlight=
"You are free to make choices. You are not free to escape the consequences."
bimmerfan08 is offline   Reply With Quote
Old 04-12-2012, 01:18 AM   #4
llcoolj0n
My Ride: M3
Bimmerfan08's DIY should answer your issue. Water pump, thermostat housing seal, or that pipe seal. That should be about it. Goodluck
llcoolj0n is offline   Reply With Quote
Old 04-12-2012, 01:25 AM   #5
MattEM3
Damn, I was hoping to not have to do it
But looks like I have little opinions left...
Should I replace the belts while I'm in there too?
and maybe even the fan?
Because I heard that even small chips off the blade can throw off the rotation of the water pump shaft and mess up the bearing
Old 04-12-2012, 02:06 AM   #6
llcoolj0n
My Ride: M3
I'd do the belts too. As far as the fan, they won't be chipping unless they are grinding/hitting something. If the fan looks ok, leave it alone.
Old 04-12-2012, 07:49 AM   #7
Ky///m3
My Ride: 1988 E30 M3
id do a sport fan clutch while u r in there too.....easy and cheap
so to do list:
water pump
belts
sport fan clutch
how many miles are on your car?
2006 E46 M3 HPF stg II SOLD
1988 E30 M3 Touring Class
1995 E36 M3 I-Prepared Class
Ky///m3 is offline   Reply With Quote
Old 04-12-2012, 12:00 PM   #8
MattEM3
My fan doesn't have any chuncks off of it
But it looks like it was scraping against the fan shroud
Nothing too serious
What are the advantages of the sport fan clutch?
It has 118k on it
Old 04-12-2012, 01:36 PM   #9
roadtrip1098
My Ride: 06 STi
Another thing to check is the coolant temp sensor bung on the lower radiator hose, it doesn't take much for those to wiggle loose. I'd recommend keeping a jug of coolant with you though because when the water pump decides to go there isn't much warning and it'll spew all of the coolant out fairly quickly.
roadtrip1098 is offline   Reply With Quote
Old 04-12-2012, 04:23 PM   #10
MattEM3
Yeahh... I've heard about the infamous O-rings for just about everything in this car
and I do
Im trying not to move her too much though while I wait for parts
Old 04-12-2012, 04:33 PM   #11
dmax
dmax's Avatar
My Ride: '99 328i 300K miles
If the wp blows apart, you have bigger issues than just being low on coolant.
Wobbly wp probably does mean the wp, but use an inspection mirror and good led flashlight to confirm this. Also, just because you find one leak, doesn't mean you only have one. Clean things off with water...spritzer bottle works good...and look for fresh signs of coolant.
Yes, this is a great time to do belts and all three pulleys...not sure what tensioners you have, but you can plug your PN into Dayco's website, get the dayco pulley number and order them from autozone or advanced...they're OE, believe it or not!
The temp sensor, if leaking, can be fixed with the IAT o-ring--I think jfoj has that PN in his sig and I assume it's the same part as on a non-M...confirm PNs at realoem.com
HTH
Upcoming comedy shows: May 20, Greenwich Village Comedy Club. 6 p.m. See Facebook for other shows and PM me if you can make one...love to see you there!
Facebook.com/DMAXstandup
Mangofy your E46!
Old 04-13-2012, 04:17 PM   #12
MBW
My Ride: '04 M3 Convertible
Take the fan off and then the water pump pulley that is held on by 4 bolts. Under the WP shaft there is a plug/ weep hole on the WP that leaks. When you take off that pulley it will will full of blue gunk from the leaking WP. Sure fire way to know for sure it is the WP. However, with your mileage, the WP is suspect.
MBW is offline   Reply With Quote
Old 04-13-2012, 09:18 PM   #13
MattEM3
Does the TMS power pulley kit go on the same way the OEM belts do?
Old 04-15-2012, 12:44 PM   #14
Taunto
My Ride: 05 CB M3 SMG
I'm really surprised no one has yet gave the sugestion of renting a cooling system pressure tester. I would be looking for one of these. Hook it up. Pump it up to 16-18 psi and watch to see where the coolant drips from. Hate to see you buy and install a part and turn out not fix the original cocern
Sent from my HTC-X710a using Bimmer App
Taunto is offline   Reply With Quote
Old 04-16-2012, 12:26 AM   #15
MattEM3
Just did that the other day
A friend of mine just opened up a shop and hooked it up for me so that was cool
It was the pump though, just waiting on parts now
Old 04-16-2012, 01:51 AM   #16
Taunto
Good to hear you got the problem fixed
