Old 04-17-2012, 10:15 AM   #1
stevyrae95
My Ride: 2004 325ci
When to get software
So is a software tune such as the conforti more a "top off" tune so to speak? Meaning should it be the last mod to do after your done with all else like exhaust, headers, and intake? I am almost ready to pull the trigger on the conforti but if I'm not quite done with bolt-ons and such, should I wait? Thanks guys!!
P.S. Couldn't forcing the engine to rev to 7,000 rpms eventually burn the engine? For some reason that never seemed safe to me.
stevyrae95 is offline   Reply With Quote
Old 04-17-2012, 02:08 PM   #2
aggieE46
Keep it clean
aggieE46's Avatar
My Ride: 03 Evo, 07 Passat
Shark was my first mod. It will adapt as you mod more.
I hit 7k daily and have done so for 120k on the car. It has 162k on it.
No need to hit it if you aren't making power there, though.
Old 04-17-2012, 03:02 PM   #3
stevyrae95
My Ride: 2004 325ci
Oh I see. Thanks for you input, so do you feel that 'extra 7hp' and is your throttle more responsive? I am just making sure all the benefits are legitamate for $350+.
Old 04-17-2012, 04:34 PM   #4
Rob43
Rob43's Avatar
My Ride: 03 331Ci 5spd R1200R
It's legit, buy it, you won't be sorry.
1) Quicker Throttle Response
2) Top Speed Limiter Revoved
3) New 7000 RPM Redline
4) More WHP & WTQ
5) User Installed & Removed At Anytime
In About 20 Minutes.
Good luck,
Rob
SUMMIT POINT WV 1:24:229 SCCA
Old 04-18-2012, 09:33 AM   #5
hassmaschine
My Ride: '91 325ix
tunes don't really "adapt" - the closed loop O2 operation will bring your fuel back to the lambda targets, but ignition timing is really what gets optimized for power on an OBDII engine and that will remain fixed no matter the mods.
but, they're mostly all canned tunes anyway, so it really won't make a difference if you do it first or last. me, I'd do it first.
hassmaschine is offline   Reply With Quote
Old 04-18-2012, 11:42 AM   #6
hoveringuy
My Ride: e30
When are the harmonics really an issue? You make it sound like transients in the 7k range aren't a concern. Are the pumps only breaking in track use, when rpms are held in that range? Has anyone had a pump break from street use?
hoveringuy is offline   Reply With Quote
Old 04-18-2012, 11:55 AM   #7
aggieE46
Keep it clean
aggieE46's Avatar
Yep. Problems are from holding the revs, not just hitting them. I believe someone has posted that anything above 6k will cause issues if you hold it.
