Old 04-12-2012, 12:58 AM   #1
e46dub
My Ride: 2000 328i
m50 intake, m3 camshaft in 328i??
I've done some searching and this seems to be the only way to really make some real horsepower/tq on the e46 328s.
With tuning like a shark, and these mods... what would the hp/tq be estimated around vs stock?
the m50 swap sounds good for me to do. It doesnt seem a tune is necessary for it from what I've read?
e46dub is offline   Reply With Quote
Old 04-12-2012, 01:03 AM   #2
e46dub
My Ride: 2000 328i
i saw this dyno and it was the stock cam for the 328 vs the m3 cams
http://www.eurosporthighperformance....2_vs_Stock.pdf
Old 04-12-2012, 12:19 PM   #3
Hornung418
My Ride: '04 MB ZHP
None of those things are possible on the M52TU engine.
M54B30 Manifold, ZHP or Schrick camshafts, headers and a tune and you'll be making some decent power...that's just bolt ons though.
Hornung418 is offline   Reply With Quote
Old 04-12-2012, 03:40 PM   #4
e46dub
My Ride: 2000 328i
are you sure the m50 intake manifold wont work with the 00 328i?
Old 04-13-2012, 08:55 PM   #5
F1004fun
My Ride: '02 330Ci
If you pull out 2 studs the manifold will bolt up but I don't think that there is enough meat in the head to port large enough to match the M50 intake.
I am thinking about the M52 intake instead with schrick cams in a ported M54 head. I really wonder if the M54 head can flow enough to honestly use the M50 intake?
F1004fun is offline   Reply With Quote
Old 04-13-2012, 11:14 PM   #6
Blocked Out
My Ride: Imola 330i M-Sport
The dyno graph you showed is of an E36 engine . You have an E46 and its a DIFFERENT engine.
S50/s52 cams wont fit into an M52TU, nor would S54
Original BMW Teile ///
IMG_1725
Old 04-14-2012, 11:22 PM   #7
e46dub
My Ride: 2000 328i
well that's disappointing. now where do i go from here
Old 04-15-2012, 08:24 AM   #8
aggieE46
Keep it clean
aggieE46's Avatar
My Ride: 03 Evo, 07 Passat
Parts made for your car.
Old 04-16-2012, 08:31 PM   #9
polishracing95
My Ride: 2000 323
polishracing95 is offline   Reply With Quote
Old 04-16-2012, 10:41 PM   #10
Hornung418
My Ride: '04 MB ZHP
I really don't understand how daft some people are...Post #3...what more do you want? Myself and several others, including Iceman00, have swapped manifolds.
Old 04-16-2012, 10:41 PM   #11
Hornung418
My Ride: '04 MB ZHP
Double post...
Old 04-16-2012, 10:42 PM   #12
e46dub
My Ride: 2000 328i
I have found no dyno sheets of what you've posted.
Old 04-16-2012, 10:45 PM   #13
Hornung418
My Ride: '04 MB ZHP
Then be the first? It's not that hard. And M50 manifolds will not fit on an M52tub28...Just in case you missed that part...
Old 04-17-2012, 03:42 PM   #14
e46dub
My Ride: 2000 328i
not worth wasting the time and effort for a better throttle response.
id rather see numbers not "you could gain power"
Old 05-25-2014, 10:42 AM   #15
Nordskov
My Ride: E46 328i
Hello from denmark, dont know if it doesnt matter by now.. but i tuned my 328i proberply with the following:
M54b30 intake manifold with disavalve from the 330i aswell + kn cone filter
Ebay headers, mountet with stock cats, with 2.5 inch catback to supersprint muffler
OBD chipped with 7k rpm limiter
3.23 differential
Electrical fan
and thats about it, it produce 235hp from the crank. vs the stock 193.
in other words.. ZHP power
Nordskov is offline   Reply With Quote
Old 05-25-2014, 10:52 AM   #16
Rob43
Rob43's Avatar
My Ride: 03 331Ci 5spd R1200R
3.23 differential
Electrical fan
First: ..... Welcome to E46Fanatics !
Congrats on your HP.
Rob43
SUMMIT POINT WV 1:24:229 SCCA
Old 05-25-2014, 07:11 PM   #17
BartenderPlease
My Ride: '03 540i/6 M-Sport
All of those things are possible you naysayer.
Edit. in all seriousness, e36 M3 camshafts will work with minor modification with hand tools. Solo//M has successfully installed an m50 manifold and made decent gains with it, and still has more room to go.
.............................................@jb540i6
'02 JR/Naturbraun 330i M-Tech I | M-Tech II Fr. | Supersprint Headers | Remus Sport |
.....| SM Flywheel Conv. | 18" CH'ish reps | Short Shift | Orion V2.5 | RCR LED Tail |
'03 JB/Schwarz 540i M-Sport 337 | Decatted | Short Shift | Carbon Trim | JL Audio | V1
BartenderPlease is offline   Reply With Quote
Old 05-27-2014, 04:42 AM   #18
e46dub
My Ride: 2000 328i
to the people that say it wont work and have no knowledge or just want to join the bandwagon and flame can just stay out this thread. This is for people that have actually done it... moving on..
since my 328i is obd2, what would I use for tuning? Will a shark injector really work for an aftermaket camshaft and be good?
What kind of modification will I need to do to the camshaft to get it to work
Old 05-27-2014, 05:02 AM   #19
SoloII///M
My Ride: Many
The M50 is a great upgrade, but it's not a bolt-on. You'll need to do some fairly minor (but still invasive) port matching to use it. And you will lose your OBD-II compliance, if that matters to you. If you have to pass an OBD-II emissions check, the M50 manifold is not for you. You'll also lose your DBW throttle, and you'll have to come up with a solution for the air/oil separator, which no longer fits where it used to.
In terms of cams, a set of Schrick cams would be a better investment.
John V
'02 330Ci - Megasquirt 3 tuned by PFTuning.com
SoloII///M is offline   Reply With Quote
Old 05-27-2014, 05:18 AM   #20
e46dub
My Ride: 2000 328i
I dont have emisson checks
Im not 100% but I think I'm drive by cable. Its a 2000 328i.
for daily driver(and weekend tracking circuit&drag), which do you think would be the better setup. schrick cams and b30 manifold, or schrick cams and m50. I'm not worried about port matching as my neighbor used to do that for his drag cars (and still does).
