Go Back   E46Fanatics > Everything Else > The Off-Topic > Gun Talk
Gun Talk
Are you a gun fanatic as well? If so, you'll want to talk to other owners about what you own in this forum.
Old 03-22-2012, 03:46 PM   #21
Rob43
Rob43's Avatar
My Ride: 03 331Ci 5spd R1200R
I've owned a Remington 870 for over 10 years, great shotgun, I highly recommend it.
Good luck in your decision.
SUMMIT POINT WV 1:24:229 SCCA
Old 03-23-2012, 04:28 PM   #22
dan03833
My Ride: 2001 330xi
I just went thru the same purchasing decision myself. It came down to the Remington 870 and the Mossberg 500 for me. In the end, I chose the Mossberg 500; from what I found, it's a Ford Vs Chevy argument. But, here's what the Mossberg has that the Remmington didn't; the Mossberg is predrilled & tapped for a scope. I opted for the Field/Security Combo, this gives you an 18.5" barrel & a 28" barrel, rifle stock & pistol grip and 3 choke tubes. I was out the door with the whole thing for $441.23.
dan03833 is offline   Reply With Quote
Old 03-23-2012, 06:42 PM   #23
Locutus09
My Ride: Something Slow
You buy local?
The scope thing is no big deal...IMO
Locutus09 is offline   Reply With Quote
Old 03-23-2012, 07:38 PM   #24
david05111
My Ride: drei hundert dreißig
Sounds like a pretty awesome deal to me!
"You'll Never Walk Alone"
"Psycho Murican" -- beeemerdude of Canada
david05111 is offline   Reply With Quote
Old 03-24-2012, 06:11 AM   #25
Joey325Ci
My Ride: Black Fred
I went through the same thing, one day I went to the range with a buddy of mine and played a few games of trap and I was instantly hooked!
I went with the Benelli Nova H2o, It comes with an 18 inch barrel and I added a factory +2 extension and a full receiver length rail, I keep it like this for HD, I then bought a factory 26 inch field barrel for for trap/skeet and added a choke tube set. Its take 5 minutes to switch barrels. I have put a couple hundred rounds through mine and not a hicup, I am very satisfied with its performance.
That being said, if you are into modding your gun I would go with a Mossberg or Remington as it is far easier to find aftermarket parts and accesories for it, I found this out after purchasing my gun. There is really nothing else that can be done to mines, while you have endless options and vendors with the others.
In my opinion, you cant go wrong with either of these brands, Mossberg, Remington and Benelli all make great guns that last forever, good luck with your search and keep breakin them birds!
Joey325Ci is offline   Reply With Quote
Old 03-26-2012, 12:39 PM   #26
dan03833
My Ride: 2001 330xi
Originally Posted by Locutus09 View Post
You buy local?
Yes, bought local.
Old 03-26-2012, 11:08 PM   #27
bimmerfan08
My Ride: F
Remington has a combo package similar in price.
"You are free to make choices. You are not free to escape the consequences."
bimmerfan08 is offline   Reply With Quote
Old 03-26-2012, 11:10 PM   #28
bimmerfan08
My Ride: F
Originally Posted by daedalus34r View Post
how much would a new or used 870 go for?
what would you guys consider as a nice step-up from the 870? A shotgun that's more expensive but a worthwhile look if im interested in spending a bit more.
I got my 870 for $270 new if I can remember correctly and that was with taxes. It was on sale either at Bass Pro or Wal-Mart. Used you can probably pick one up between $200-$250.
Old 03-27-2012, 10:26 AM   #29
speedcrazy1532
My Ride: is over
that's an average deal. You can most often piece together packages for much less. I understand some people like the convenience of the packages though, and to each their own.
-Phil
speedcrazy1532 is offline   Reply With Quote
Old 04-01-2012, 04:16 PM   #30
Locutus09
Bumping this back up.
Bought a Remington Wingmaster 870 for $300. Picking it up next week.
Anything I should look out for when checking it out?
Old 04-01-2012, 05:26 PM   #31
Reedo302
Reedo302's Avatar
My Ride: F30 328i M Sport
If it has removable chokes, take the choke tube out of the muzzle to make sure it's not seized. If it's a fixed choke, inspect the barrel for any cracking. Then check normal functioning and operation. Get a couple full-size snap caps and run them through the gun to make sure everything functions okay.
DINAN3 F30 328i M Sport
DinanTronics Stage 1
Dinan Free Flow Black Tip Stainless Exhaust
Dinan Lowering Springs and Bumpstops
Dinan 20" Black Performance Wheels
Gunfighter Training Development and Evaluation
AR15/AR10 Armorer/Advanced Armorer
Glock Armorer
Gunfighter Training YouTube Channel
Reedo302 is offline   Reply With Quote
Old 04-01-2012, 06:31 PM   #32
Locutus09
I'm almost certain that it's a fixed choke, it says full on the barrel.
I'll pick up some 2 3/4 snap caps to run through.
Old 04-02-2012, 12:20 AM   #33
david05111
I'm actually now entering the market for an 870 Wingmaster 12 gauge, 28 inches. I'm on the lookout
Old 04-28-2012, 09:10 PM   #34
BMW_Matt
My Ride: 135
Sounds about right. The new 28" barrel's will probably come with a modified choke for the most part, but they're interchangeable with the key they give you. It's about $25 for a different choke, and you can get them anywhere. I have a 26" barrel because I was too impatient to find one with a 28", but it still works great.
BMW_Matt is offline   Reply With Quote
Old 04-29-2012, 01:37 AM   #35
david05111
Ended up grabbing one used in pretty good shape, though it didn't come with a choke wrench.
Old 04-29-2012, 11:13 AM   #36
BMW_Matt
My Ride: 135
Have any pictures?
Old 04-29-2012, 01:02 PM   #37
david05111
Have any pictures?
Just this one for the moment
