Taking apart m54 throttle body? - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 04-22-2012, 08:09 AM   #1
darksideracer69
My Ride: 01 325ci
Has anyone done it? I know Dinan and maxxbore have to take them apart to bore them out and stuff. So how is it done?
Sent from my SGH-T959V using Bimmer App
IMAG02051
Old 04-22-2012, 09:37 AM   #2
WALKD U
My Ride: Just Fast!
To Complicated... Maxxbore wont even do it no more...
2005 AW/IR M3
MaximumPSI Stage4
993whp/651wtq SAE Corrected
2005 JB/BLK 330i ZHP
NA Bolt-ons
207whp/216wtq SAE Corrected
1996 BLU/BLK M3
NA Bolt-ons
235whp/225wtq SAE Corrected
1988 SETA 325I
NA Bolt-ons
165whp/160wtq SAE Corrected
Old 04-22-2012, 09:51 AM   #3
darksideracer69
My Ride: 01 325ci
Yea I know, but they did lol
IMAG02051
Old 04-22-2012, 11:41 AM   #4
Iceman00
Banned User
My Ride: E90 6MT
I have an extra one if anyone wants it, it's from a B25.
Old 04-22-2012, 11:43 AM   #5
darksideracer69
My Ride: 01 325ci
No answers
IMAG02051
Old 04-22-2012, 11:46 AM   #6
Iceman00
Banned User
My Ride: E90 6MT
There is no real gain from upsizing the TB, but have at it.
Old 04-22-2012, 12:21 PM   #7
aggieE46
Keep it clean
aggieE46's Avatar
My Ride: 03 Evo, 07 Passat
I tried to take apart my spare, I broke it.
I contacted Maxbore to see if they'd do one more for me for a favor. He said taking it apart was hell and putting it back together was double hell.
Old 04-22-2012, 05:12 PM   #8
Rob43
My Ride: 03 331Ci 5spd R1200R
I've got my spare M54B30 TB sitting on my coffee table in front of me, I look it over occasionally trying to figure how to disassemble it; of course the plastic cover is off exposing the gear set. What I believe you would need is some very specialized tools, some type of high quality three or four jaw puller. Banging or hammering on it will kill it quickly. If you go for it, paint (white droplet) the position/location of ALL the different teeth/gear sets, also take a few detailed pics before disassembly. If you get it back together you'll need the same alignment. Another easier way to go about getting a little more flow through it would be to remove the throttle plate & put it on a belt sander to make it half as thick or more. Next would be to remove a substantial amount of material from the throttle shaft & Allen head screws.
Question: Isn't a B30 TB bigger than a B25 TB, and if so why couldn't it be adapted ?
Good luck,
Rob.
SUMMIT POINT WV 1:24:229 SCCA
Old 04-22-2012, 05:17 PM   #9
darksideracer69
My Ride: 01 325ci
Yea, been looking at the gear set, and it looks like that gear on the blade shaft needs to be pulled with a very small puller. I emailed a couple of sources for info, hopefully get a reply tomorrow.
IMAG02051
Old 04-22-2012, 08:40 PM   #10
hoveringuy
My Ride: e30
I was making 220whp on a tiny little M50 TB on my M54b30, before I upgraded to stock size.
I didn't gain any power, but the response felt different. Throttle felt more sensitive off-idle.
hoveringuy is offline   Reply With Quote
Old 05-19-2012, 12:10 AM   #11
F1004fun
My Ride: '02 330Ci
Those throttle bodies have a little trick to taking them apart. After you take the plastic cover off, mark a spot where the two gears mesh so you can get it set back up correct. Undo the two screws for the throttle plate, then there is a little pin that goes into a ring land in the shaft that keeps it from sliding side to side. You can pound that pin into it's pocket a ways the break it in half and drive the rest of the pin through. It's just a locating pin so finding the same size roll pin would work as a replacement. Once you drive the pin out then the throttle shaft comes out, but be vewy vewy careful of the little fingers on the position sensor. Maxbore might do it again if YOU strip it down and send him just the raw parts, he said they are to labor intensive for him to do.
F1004fun is offline   Reply With Quote
Old 05-19-2012, 07:36 PM   #12
darksideracer69
My Ride: 01 325ci
Good info. Thanks
IMAG02051
