///M3 Forum
Old 05-17-2012, 09:19 PM   #1
Zenocchio
My Ride: M3 vert e46 SMG
another SMG light thread :facepalm:
I am sorry to bother the forum with another SMG light thread, but here are the facts:
this morning I was driving in A3 and the SMG light came up on my dash.
I got the car just 3 weeks ago, and nothing came out during the PPI related to the transmission.
Bottom line, I tried to reset it today unsuccessfully performing the following:
1 - Disconnected the battery for 2 hours, the only thing that I manage to do is resetting the clock
2 - Resetting the SMG by going in N and pulling both flaps for more than 5s in a speed >80km/h, nothing happened, but now it shifts less harsher
3 - I invested 20$ and bought a new pink relay, nothing happened.
I must say that the car drives fine, if it wasn't for the light on that bothers me I would never feel any trouble.
On a side note, since I disconnected the battery my front windows only roll up with their own independent switch, but all 4 windows go down by pressing the common switch.
I just spent thousands to buy it, and I'm feeling pretty bad right now...
Zenocchio is offline   Reply With Quote
Old 05-17-2012, 10:12 PM   #2
BWOODM3
My Ride: 2002 M3 convertible
So the light is currently on but still drives? Does the gear selector on the dash blink?
BWOODM3 is online now   Reply With Quote
Old 05-17-2012, 10:30 PM   #3
Zenocchio
No blinking, light on and the car just drives fine
Old 05-18-2012, 11:53 AM   #4
mooninite
My Ride: M3, 325i
Get your codes read.
/thread
OBD2 readers may not tell you anything. Find someone in your area with the INPA or DIS BMW software. Or pay your dealer an hour labor for them to read it.
mooninite is offline   Reply With Quote
Old 05-21-2012, 07:14 PM   #5
Zenocchio
Could it be a worn clutch?
what are the signs of a worn clutch on an SMG transmission?
Old 05-21-2012, 07:29 PM   #6
e46built
My Ride: 325ci
It might be one of the pumps because mine did the samething
e46built is offline   Reply With Quote
Old 05-22-2012, 02:39 PM   #7
Zenocchio
One of the pumps? Why do you think so?
Old 05-22-2012, 03:47 PM   #8
e46built
My Ride: 325ci
Because mine did the same the light turned off but would drive normal and i took it to get it checked at the dealer and they told me it was one of the pumps
Old 05-30-2012, 08:15 PM   #9
Zenocchio
Problem solved, or at least postponed.
today I invested 40$ and got my code read by a shop and the fault code was (021) 15 Hydraulic Pump Relay, Activation. Apparently this error is stored 41 times in the cpu.
I don't know what to think, as soon as they erase the code, the light went off and so far hasn't turn on yet.
Before changing the relay I did a SMG reset by pulling the two flaps and disconnected the battery. Probably then the errors stored were erased?
I then changed the relay but the light was still on. I probably should have disconnected the battery again then.
any suggestion?
Old 05-30-2012, 08:32 PM   #10
Mallee
My Ride: 2002 E46 M3
I don't believe that pulling the battery will reset codes.. (I've never heard of it being that easy with an air bag code.)
And I'm not sure exactly what you did with the "SMG reset" but it sounds like the one that is supposed to be done at 40kph.. and that does not reset any codes, it just get is to reset it's shifting data to default.
Mallee is offline   Reply With Quote
Old 12-01-2012, 06:33 PM   #11
mcmcgnns
My Ride: 2004 325i
Follow Up
Did the relay ultimately solve your issue? I have precisely the same occurrence and swapped the relay and cleared the code. I am hopeful that your equivalent symptoms were resolved with the relay replacement.
mcmcgnns is offline   Reply With Quote
Old 12-02-2012, 11:27 AM   #12
roadtrip1098
My Ride: 04 M3 SMG LSB
Make sure your battery is fully charged. That can cause a bunch of codes for the SMG yet the car will drive fine. It can also fry that new $20 relay you bought. Odds are the car's never had a new battery and it's getting to be that time.
Other things to check - SMG Hyd. Fluid lever (covers near the intake manifold). Check to make sure all doors, trunk and hood are completely closed. Drive in S3-S6 and see if you notice any weird delays in shifting. Most problems don't really present in drivability issues unless you are in S5 or S6. As another member said, get your codes read and report back. We'll be able to tell more from there.
roadtrip1098 is offline   Reply With Quote
Old 12-02-2012, 11:28 AM   #13
roadtrip1098
Airbags, because we like cars to be a PITA, run on a separate module so they don't reset with the rest of the codes.
Old 12-02-2012, 02:53 PM   #14
Zenocchio
Once swapped the relay and cleared the code I haven't had any problem.
Old 12-02-2012, 06:38 PM   #15
mcmcgnns
My Ride: 2004 325i
Good to hear - to above, battery is behaving appropriately both (via MM readings) with and without a load. The error was precisely as above computer shows error 15 SMG relay implausible value or some such gibberish. To the OP the windows can be reindexed by going from top position to bottom and back up (relearning position) - once indexed the universal switch should behave properly. I assume you figured this out given the age of the thread but I noticed the question wasn't addressed.
Thanks again - I think I am in good shape.
