Thread Tools Search this Thread Rating: Thread Rating: 21 votes, 4.05 average. Display Modes
Old 05-23-2012, 04:02 PM   #1
Platinum Plus Quality
My Ride: M54B30
Exclamation Just bought your non-M E46? Bare essentials maintenance checklist (part #s included)
Just bought your E46?
You just bought your non-M E46 (323/328, 325/330) and you are probably wondering: What do I do now?
Lets start with the basics, shall we?
Battery
Right off the bat, the first thing I did when I bought my E46 was throw away whatever battery is in the trunk. Unless you have receipts proving the battery is newer than 5 years old, replace it. A weak battery is known to cause many problems with the electrical systems in the form of cluster lighting up with warning lights to the car randomly doing other electrical-related things.
Voltage regulator:
The voltage regulator is located on the back of the alternator. It regulates voltage to ensure proper operation of the electrical system. Basically by around 6-10 years, they start to fail. This will kill a new battery. Replace it.This one is a bit tricky because you'll have to pull your alternator out to know which kind you need. There's a rounded D-shaped connector and squared off rectangle connector. Pray you have the squared off rectangle connector because it's cheaper. The D-shape connector is found by searching under the BMW Z4.
Final stage resistor:
This must be replaced. It can drain your battery (killing it permanently no matter how new or old it is) and cause your blower to blow inconsistently or not at all. Replace it. Part#64116923204
Autozone 49DL
Engine oil
Change your engine oil and filter anywhere between 7,500 and 12,000 miles. You can likely go up to 15,000 miles without any problems as our cars hold 7 quarts, however for peace of mind, follow the 7,500-12,000 guideline.
Per the BMW owner's manual, you should check the oil level 5 minutes after a hot engine has been shut down. The dipstick is calibrated to read accurately after 5 minutes has passed.
Note: If you track your car, love to drive in a spirited matter, and/or experience lifter tick noise, it is common practice to overfill by one quart for a total of eight quarts.
You should be using oil with a specification ACEA B3/B4 (extended drain/high performance criteria) and/or LL-01. The following oils are the most readily available proper oil for your car:
Genuine BMW 5W-30
Castrol European Formula 0W-30
Mobil 1 European Formula 0W-40
Pennzoil Ultra 5W-40 European Formula
Oil Filters
You can use any OE-spec parts store filter in a pinch, but I recommend using Mahle or Mann OE-quality/OEM filters.
Mahle supplies filters to BMWs for their ///M cars. Mann supplies for non-M. Both are fine but I prefer Mahle--the quality seems more robust/high-end. Part number: 11427512300
Spark plugs
Replace every 60,000 miles (BMW says 100,000) NGK BKR6EQUP (6)
Fuel filter
OEM Mahle. If your upper intake boot has an "F" connector with a vacuum line attached, your car has the integrated fuel pressure regulator. Most E46s come with this. I believe the M56 SULEV 325 cars use the plain in/out filter. Do this every 50,000 miles. Part number: 13327512019
Differential oil
Synthetic 75W-90 gear oil such as Mobil 1 75W-90. Your non-LSD diff holds approximately 1 quart. Do this every 50,000 miles
Transmission oil
Automatic:
You should change your automatic transmission fluid and filter with OE or OE-spec'd high-quality fluid every 50-75k miles. The type and amount of fluid will depend on your year/make/model. I will list the various types of automatic transmissions and their corresponding fluid:
323i/iS/iC 7/98-3/00, 328i/iS 6/98+ - GM 5L40 (A5S 360R) Texaco ETL 7045E, supercedes ETL 7045, BMW part number: 83220026922
323i/Ci 3/00-8/00, 325i/Ci/Cic 8/00+, 325iT 3/01+, 330i/Ci/Cic 6/00+ - ZF 5HP19 (A5S 325Z), Esso ATF LT 71141, BMW part number: 83229407807
325xi/xiT 8/00+, 325iT 8/00+, 330xi 8/00+ - GM GM5 (A5S 390R), Texaco ETL 8072B, BMW part number: 83220024359
Manual:
BMW MTF-LT-2[/URL], equivalent Pentosin MTF2, or other equivalent. I use Redline D4 ATF. You can also use Redline MT-90.
Air filters
These should be replaced at roughly every 15,000 miles. Use Genuine/OEM Mann. Part number: 13721744869
Cabin air filter
These should be replaced at roughly every 15,000 miles. Part number: 64319071935
Clean idle control valve
http://www.bmw-planet.com/2009/01/10...-cleaning-e46/ Clean every 50,000 miles. If needs replacing, part number: 13411744713.
You might want to replace the rubber boot which seals it to the intake manifold. Part number: 11611437453.
Clean throttle body
Couldn't find a DIY, but personally I recommend cleaning it. From the outside (front) mine appeared to be spotless.
The backside was a VERY different story. Use throttle body cleaner. Requires removal of the airbox, upper and lower intake boots, and electrcial wire junction box. Four bolts hold it on. Replace the rubber throttle body gasket. Throttle body gasket for 323/325/328 part number: 11611716174, for the 330 it is: 13547504729
DISA
This part can also cause vacuum leaks. It works by altering the volume of the intake manifold depending on engine operation/speed. Remove and inspect yours to ensure the flap is not loose.
You should feel resistance as you manually operate the flap. There should be no excessive noises or rattling. Part number if you'd like to replace: (courtesy of JFOJ)
325/2.5L engines currently use BMW Part #11617544806, which appears to have superseded an earlier BMW Part #11617502269
330/3.0L engines currently use BMW Part #11617544805, this appears to have superseded an earlier BMW Part #11617502275
323/328 - 2.3L & 2.8L engines appear to currently use BMW Part # 11611440049
Reseal or repair using: http://germanautosolutions.com/DISA_...epair_Kit.html
Brake fluid
You should completely replace and bleed your brake system every two years or 25,000 miles or more frequently if you see track use or have overheated your brakes/fluid. I recommend ATE Super Blue (or amber if you had blue last) :
http://www.ecstuning.com/BMW-E46-330...d/A/ATE/ES111/
Valve cover gasket
Major source of leaks. If the front or passenger side (right side) of your engine is covered in oil, then your valve cover gasket is leaking. By 60,000 miles, these are hard, dry, and brittle. Use Permatex Ultra Black at half moon areas and vanos seams. LESS IS MORE. Use very little sealant. Don't forget the 15 rubber grommets: part number: 11121437395. Up to 9/02, part number 11129070990 and 9/02+: 11120030496. If you experience repeated leaking, your valve cover could be damaged or warped.
Oil filter housing gasket
Major source of MAJOR leaks. The left side of the block will be wet and you'll have puddles in your driveway. Replace when leaking. Part number: 11421719855
Vanos line
Do this when you replace the oil filter housing gasket. Part number: 11361705532
Also replace four 14x20 copper sealing gaskets, part number: 32411093596
Power steering
Use ATF Dexron III only. Replace reservoir as it has integrated filter. Part number: 32411097164
Also trim and re-clamp (using new universal clamps) the power steering lines to the bottom of the reservoir and to the return line at the pump. The BMW clamps get loose over time and oil leaks/seeps out.
Exterior/interior
Of course, clean the exterior/interior and engine compartment. There's nothing worse than a dirty car with an engine compartment full of leaves, debris, oil, spiders, and dead rats. Cleaning also can help reveal problem areas or parts that are leaking. A clean engine is also more satisfying to work on.
I use the Wagner 915 steamer for my interior, engine compartment, and certain exterior items as well. I can't even begin to tell you how well this works! Great for home too. No need for chemicals (Saves $$!!) I bought mine on Amazon: Wagner 915 1,500 watt on-demand steamer
And of course, last but not least, the cooling system.
http://forum.e46fanatics.com/showthread.php?t=914109
These are the absolute bare essentials. There's still the suspension, drivetrain items, bushings, etc. But the above list should be the first things you do.
If there's any inaccuracies, things left out, etc. feel free to add. I'll then put this in my sig and link it to anyone who is interested.
BONUS:
Suspension Refresh Guide
If this guide has helped you, let me know in the comments.
Cooling | Maintenance | Vacuum | Suspension | Costs
"Be a yardstick of quality. Some people aren't used to an environment where excellence is expected." -Steve Jobs
Old 05-23-2012, 04:06 PM   #2
dmax
Stay stock my friends!
dmax's Avatar
My Ride: '99 328i 1.03809 mu
Mango,
I've got to register a complaint with your comment "it's fine to put in 8 qts."
I've always said here, based on what I've read (a lot) that it's better to be a quart low than over a 1/4 quart high...which is the top of the top notch.
The capacity is 6.9 quarts, so 7 is fine. 7.9 is capacity for an Xi I believe, so 8 qts. is fine there.
But 6.9 qts. or 6.5 L is capacity for most e46s and I think if you're going to recommend a proper amount, you should just do so. Don't make someone reading think the capacities are just suggestions.
If you edit, let me know and I'll turn this post into a glowing review!
This huge woman, like 400 pounds comes up to me and says, "Doug, I would rock your world." I replied, "but I need to breathe."
The girl in my sig:http://forum.e46fanatics.com/showthr...highlight=dmax
Old 05-23-2012, 04:07 PM   #3
Zell
Wears carbon fiber boxers
Zell's Avatar
My Ride: 330Ci ZHP 6sp
Power steering can use Dexron VI. You probably can't find Dexron III in stores anymore, that's just what was around at the time. Higher-number Dexron numbers are compatible with lower number ones.
The rule is:
Lower number Dexron components are compatible with higher-number Dexron fluid.
Higher number Dexron components are not compatible with lower-number Dexron fluid.
Zell is online now   Reply With Quote
Old 05-23-2012, 04:09 PM   #4
My Ride: M54B30
@D: jokester, you. I'm sure I forgot stuff so feel free to add to the list. Keep in mind, basics only. We all know theres tons of stuff to replace but these are the things that should get immediate attention. Relatively cheap or vital items (like the cooling system or automatic transmission fluid)
Old 05-23-2012, 04:11 PM   #5
VALMONT
The De46vil's Army
My Ride: 325Ci, Passat
Send a message via AIM to VALMONT Send a message via MSN to VALMONT
front control arm bushings, what do they last 50k?
Garage Queen
VALMONT is offline   Reply With Quote
Old 05-23-2012, 04:11 PM   #6
My Ride: M54B30
The rule is:
OK. as long as you are sure. Cause I thought I read the other day that Dexron IV is not good for our power steering systems. I just make sure the bottle says either Dexron III or Dexron III compatible. If it happens to be III and IV compatible, I use it. I forgot what I'm using. I'll look into this.
Old 05-23-2012, 04:12 PM   #7
Pedi
My Ride: 330ci
Pedi is offline   Reply With Quote
Old 05-23-2012, 04:12 PM   #8
My Ride: M54B30
I suppose I could add that. It's a little advanced for a first-timer but I guess so is automatic transmission service. I'll have to look for part numbers for 60/66mm bushings and years. that's going to be fun. unless somebody can do it for me
Old 05-23-2012, 04:14 PM   #9
Trashcan
My Ride: 2002 330ci
Good write up
Trashcan is online now   Reply With Quote
Old 05-23-2012, 04:16 PM   #10
zander271
My Ride: 2003 ZHP 330i 6sp
Good write-up mango!
Old 05-23-2012, 04:18 PM   #11
My Ride: M54B30
Thanks. I think I'll also link JFOJ's in this guide as kind of a supplement in case anyone has vacuum leaks. (If that's cool with JFOJ)
Old 05-23-2012, 04:19 PM   #12
325inthe510
My Ride: 152ci of madness
I know what I'm doing once all the parts come in
325inthe510 is online now   Reply With Quote
Old 05-23-2012, 04:27 PM   #13
dmax
dmax's Avatar
I know what you're doing too. You should be ashamed of yourself!
I find Dex III in the stores...and as I still can, I'd just say take the conservative route. Use the fluid BMW tells you to use. It knows more than us. Nothing personal, anyone, but as soon as a discussion goes, "well I heard that such and such is okay too," I remember I'm on the Internet, where facts can get created very easily. Not that it isn't worth researching if you're interested, but it's a lot of work you don't need to do.
Dex III for PS AFAIK is still the recommended fluid.
Also, didn't read this yet, but just want to add: OE,OE,OE
Old 05-23-2012, 04:28 PM   #14
eneka
My Ride: 2003 325i
iirc, there is no cheap way in preventative maintenance for the fuel system in the m56, even the fuel filter.
also mine came with BMW branded Bosch FGR-7-DQP spark plugs.
great writeup!
eneka is offline   Reply With Quote
Old 05-23-2012, 04:30 PM   #15
VALMONT
The De46vil's Army
great writeup!
is that the SULEV variant of the m54?
Garage Queen
Old 05-23-2012, 04:34 PM   #16
My Ride: M54B30
yes, sir
Old 05-23-2012, 04:38 PM   #17
liquiddawn
My Ride: 2001 BMW 330i
Awesome write up!!! I also second that you can use Dexron VI as a replacement to Dexron III for the power steering fluid. Dexron III isn't available anymore(or really hard to find) and Dexron VI is compatible with Dexron III.
liquiddawn is offline   Reply With Quote
Old 05-23-2012, 04:43 PM   #18
KSims1868
My Ride: 2001 BMW 325i
Great write up.
Question - is there an externally visable way to tell if the VANOS seals have been changed on a used engine? I'm guessing "no"...and I need to look through the maintenance records to see if this has been addressed on my car.
I know it just had oil changed (but the dash still flashes that oil change warning on start-up), air filter, tires, and fuel pump/filter. Tonight I'm getting into the corners/tails to clean any corossion and apply di-electric grease to get that dang blinker warning light off my dash. Then later this month I'm finally going to get around to those dang A & C pillars...stupid headliner just won't stay glued here in Texas. Gotta get stronger glue and material. Last year the cooling system was done, so I'm good there. I know the auto trans has NOT been serviced, so that's on my "to do" list this year at some point.
Next things I'm doing is to run the seafoam through it, change the plugs, and I might take a look at those bushings. I wonder if I can tell if they're OEM or have been replaced? I know the car feels much tighter than other models I've driven, but there's prob no way to know.
KSims1868 is offline   Reply With Quote
Old 05-23-2012, 04:44 PM   #19
lmr2wil
My Ride: '00 328Ci
Nicely done.
One question: you mention that most cars use the fuel filter with integrated FPR, I though this was a switch made with the change to the M54?
As I haven't pulled my filter yet (but plan to soon), I am not sure which type I have. I guess I will double check before ordering. Thanks!
Luke
lmr2wil is offline   Reply With Quote
Old 05-23-2012, 04:47 PM   #20
liquiddawn
Originally Posted by lmr2wil View Post
Nicely done.
Luke
Yes, you're correct! Your car has it's Fuel pressure regulator as a separate part as opposed to it being integrated into the fuel filter.
