Old 05-25-2012, 08:16 AM   #1
h3kt1c
My Ride: 2004 Bmw 325i
E46 overheat
So far on my 2004 325i, i have replaced the overflow tank, the plastic piece that sits right behind the radiator that the overflow attaches onto, (forgot the name) the tranny cooler, thermostat. All the antifreeze is in there. Sometimes when i drive, and let it sit for a little bit, it starts over heating ( I have not filled up my A/c yet if that matters) but as soon as i start driving, it goes back down to normal. ALSO when i drive, sometimes when im just slowly accelerating at 55+, the car jerks a little bit.
h3kt1c is offline   Reply With Quote
Old 05-25-2012, 08:21 AM   #2
jasonbimmer
My Ride: 2001 BMW 330xi
is your car manual?
check your radiator fan functionality. I think its not cooling the engine when you are sitting.
2009 Mazda RX-8 R3
2013 Toyota FJ Cruiser
2008 YAMAHA YZF-R6
Old 05-25-2012, 08:28 AM   #3
h3kt1c
Originally Posted by jasonbimmer View Post
is your car manual?
Nope, Auto, and that baby is always on when the car is idling, i can hear it lol
Old 05-25-2012, 08:29 AM   #4
jasonbimmer
well then the fan clutch is shot. which means its constantly slipping at slow speed and wont pick up when engine is getting warm.
when I have my AC on, every time I pull away from a red light, the fan was so loud I could hear it with windows up. then it quietens down as I pick up some speed.
2009 Mazda RX-8 R3
2008 YAMAHA YZF-R6
Old 05-25-2012, 09:42 AM   #5
Platinum Plus Quality
My Ride: M54B30
Your car overheated for one simple reason: you did not follow my thread.
See sig. Do it. THANKS!!!!!!
Cooling | Maintenance | Vacuum | Suspension | Costs
"Be a yardstick of quality. Some people aren't used to an environment where excellence is expected." -Steve Jobs
Old 05-25-2012, 10:32 AM   #6
Brinkley
My Ride: 99 328i, 02 325ic
Fan clutch as jasonbimmer suggested is the most likely culprit, also bleeding the system correctly is a huge part. There are numerous threads on the correct procedure.
Brinkley is offline   Reply With Quote
Old 05-25-2012, 10:40 AM   #7
FenderGuy05
My Ride: 2002 BMW 325i
Like jason said, sounds like the fan clutch since the car gets down to temp when your moving, look into it.
I'd still recommend checking out Mango's thread on the cooling system regardless, sounds like you didn't replace the water pump, which is needed given it could go at any second.
FenderGuy05 is online now   Reply With Quote
Old 05-25-2012, 10:48 AM   #8
My Ride: M54B30
Yes and make sure any bleeding procedure you follow doesn't tell you to warm up the engine or run it.
Old 05-25-2012, 02:51 PM   #9
h3kt1c
I only have 59k miles though.. shouldn't my water pump be fine?
antifreeze, e46, jerk, overheat, problem
