Old 02-22-2012, 07:15 PM   #1
Chaos1187
My Ride: 01' 325i M54 BMW
Hooked up Scanner (Results)
Section One:
# ERRORS DETAILS - DTC(hex)/PARAM(hex)
DME -> A8/F1 - Thermostat mechanical defect, jammed open
E4/B1 - Oxygen sensor controller, bank 2, deviation too great, deviation rich
E3/B1 - Oxygen sensor controller, bank 1, deviation too great, deviation rich
8F/B1 - Tank leak diagnosis with DMTL, major leak
Shadow-memory:
5A/12 - Exhaust temperature before catalyst, bank 1, signal line, short circuit to negative
5C/12 - Exhaust temperature after catalyst, bank 1, signal line, short circuit to negative
5B/12 - Exhaust temperature before catalyst, bank 2, signal line, short circuit to negative
5D/12 - Exhaust temperature after catalyst, bank 2, signal line, short circuit to negative
Errors after clear:
no errorsShadow-memory:
Section Two:
IKE -> CE/E1 - Outside-temperature sensor
F5/88 - No CAN message (ASC1)
Errors after clear:
CE/41 - Outside-temperature sensor
If you could let me know whats up here guys it would be great!
Chaos1187 is offline   Reply With Quote
Old 02-22-2012, 08:37 PM   #2
jared_wiesner
My Ride: 1999 328i (M54b30)
Coolant temp sensor or Intake temp sensor issues throwing the computer right off it sounds like. See this all the time on Toyotas at work.
Not 100% when it comes to BMW though, just a common weak point on older Toyotas.
jared_wiesner is offline   Reply With Quote
Old 02-22-2012, 09:04 PM   #3
Chaos1187
This is what I was thinking as well when I saw it. When had the comp checked out a while back at an autozone the code came up as the coolant temp sensor I dunno which one I should go with. Thanks for the input man
Old 02-23-2012, 12:23 AM   #4
LivesNearCostco
My Ride: 2003 ZHP 6MT
Are you missing your outside air temp sensor?
Lowering my car's resale value one track day at a time...
LivesNearCostco is offline   Reply With Quote
Old 02-23-2012, 09:03 AM   #5
Drewfus2101
My Ride: N/A
So you can trim it down to these important ones:
I would start with fixing the thermostat. The car is telling you that it's stuck open. Replace it.
Not sure why you are running rich. Most of the time these cars have a problem, it's running lean because of vacuum leaks. The rich condition could just be because the car is running too cold. Who knows. Could be the O2 sensors. Never hurts to replace the pre-cat O2 sensors (except the pocket book).
Tank leak is most likely a old gas cap.
Does the instrument cluster show the outside temp? The car says that it isn't working. Check and see if it's plugged in or even there. This shouldn't affect how the car runs though, so unless you really care, theres no need to fix this one.
Drewfus2101 is offline   Reply With Quote
Old 02-23-2012, 10:26 AM   #6
jared_wiesner
The rich running is likely due to the temp sensor issue. It perceives the car as cold and runs it rich like they always run at start up. I see this all the time.
As far as I understood, he had cleared the codes and only the outside temp sensor code remained. This likely means everything else was past history stored and not necessarily all a problem still (could have had a loose gas cap at some point.) The stuck thermostat code could also be related to the temp sensor code as it perceives the car as running too cold for the thermosat to be functioning properly.
Old 02-23-2012, 10:35 AM   #7
Chaos1187
I am not sure. I need to look into that, I literally just got this scanner and posted all the info up that was relevant soon as I got back inside
To the instrument cluster when I bought the car had been changed out, as for temp outside I have never seen a display for it at all. The only codes that remained on after I cleared memory were..
..thats as far as the engine goes. Either way I will be looking through all of the posts I get including yours and checking every detail. As it is all gold to me need this car in tip top shape!
Will def look into the functionality of this sensor..or lack their of haha. The engine light did stay off after this but I also only drove it around the block. It had a tendency to turn on when I would push it a little hard on the freeway.
Old 02-23-2012, 03:15 PM   #8
SL Blak Soldier
My Ride: 3 Pedal SG S54B32
Send a message via AIM to SL Blak Soldier
the short circuit to the o2 sensors are because of a burnt fuse (i think)
On the drivers side in the engine bay pop off the cover to the harness box. inside there will be a fuse block closest to the fender. check the the fuses. i'm sure one of them is burnt.
i got a code for all four sensor heater wires, and it turned out to be that that fuse was blown. If it isn't that find out if there are any other fuse to be blown
SL Blak Soldier is offline   Reply With Quote
Old 02-23-2012, 08:40 PM   #9
modular93fox
My Ride: 1987 R10
this aint a toyota. coolant temp sensor or intake temp sensor... there wasnt even a fault for either. replace the map thermostat, replace your outside temp sensor and clear faults, and test drive.
E46 323 swaped 2.8l
E39 LS v8 swap - in progress - motor/trans installed
modular93fox is offline   Reply With Quote
Old 02-24-2012, 12:29 AM   #10
trj
My Ride: 325Ci
Anybody got inputs on the shadow codes OP is having?
I got the same:
DME ->
BC/B8 - Insufficient heat output, oxygen sensor before catalyst, bank 1, sensor heater faulty
Shadow-memory:
34/02 - Solenoid valve, exhaust flap, short circuit to negative or open circuit
Will check the fuses tomorrow.
Old 02-24-2012, 10:34 AM   #11
Chaos1187
I got the same:
DME ->
Shadow-memory:
Let me know about these man, if it fixes it. Ill be working on a friends car (brake booster) so I wont be able to get to this today. I am still checking in getting updates from everyone of course. That way when I jump right in Ill know what to check.
Old 05-31-2012, 03:06 AM   #12
BM3R 330
My Ride: 2002 330i
Bump for sam problem/codes...
I have 3 out of these 4 codes that keep reappearing
I have a small signature
BM3R 330 is offline   Reply With Quote
Old 07-04-2013, 12:34 PM   #13
michaltt
My Ride: bmw e46 325i
Old thread but bumping...have same problems.
michaltt is offline   Reply With Quote
Old 07-17-2013, 04:47 PM   #14
Chaos1187
Re: Hooked up Scanner (Results)
Hey guys OP here to be honest things I went through were ridiculous to get her running. In the end my problem wasmajor vacuum leaks and a bad MAF. I don't even remember messing with the O2s those codes kind of just went away....I will be putting more thought into it myself just to review all that I had done.
Sent from my EVO using BimmerApp mobile app
