First Aid Box DIY (with pics) - Page 2 - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Thread Tools Search this Thread Rating: Thread Rating: 7 votes, 5.00 average. Display Modes
Old 02-28-2010, 07:10 AM   #21
Rickna
My Ride: '01 330xi - '09 IS-F
Did this under the driver's seat on my 330xi. Great for "odds & ends".
2001 BMW 330xi
2009 Lexus IS-F
Rickna is offline   Reply With Quote
Old 02-28-2010, 04:53 PM   #22
sparker92
My Ride: 1999 323i
Send a message via AIM to sparker92
I bought a short euro-tray and I am using the first aid box as a storage place for the cup holders (just incase).
sparker92 is offline   Reply With Quote
Old 03-04-2010, 08:11 AM   #23
JapanRed
My Ride: 325CI
In case someone needs the part numbers Actual First Aid box 52107044958 and Bracket 52107045018.
http://www.realoem.com/bmw/showparts...2&fg=25&hl=113
JapanRed is offline   Reply With Quote
Old 03-04-2010, 01:25 PM   #24
JapanRed
My Ride: 325CI
If any of you have sport seats and want to do this. 12 3/4" sheet metal screws won't work as they are too long and will stop the cushion from coming out. I couldn't find any shorter then that I used a spacer ( you can use a nut as well) and worked fine.
Old 04-05-2011, 03:47 PM   #25
JetBlackE46
Modded
My Ride: E36/E46 M3 E46 323
nice DIY, I will be attempting this soon.
JetBlackE46 is offline   Reply With Quote
Old 04-06-2011, 12:00 AM   #26
delmarco
My Ride: 335xi Deep Sea Blue
Send a message via ICQ to delmarco Send a message via Yahoo to delmarco
Great DIY from a GREAT guy!
(@ Sparker92 back then i didn't even know this was you)
delmarco is offline   Reply With Quote
Old 04-06-2011, 12:24 AM   #27
fgin
My Ride: e46 facelift
I have 2 on either seat. The one on the passenger seat came with the car and has the first aid kit. The driver's seat comes with all the holes pre-drilled so installed another one so I have extra storage space within reach.
fgin is offline   Reply With Quote
Old 04-26-2011, 03:23 PM   #28
Danoff
My Ride: '04 330i ZSP
Looks like I have pre-drilled holes under my seats. Does anyone know the screws that fit the pre-drilled holes? Otherwise I'll just end up trying a bunch.
Danoff is offline   Reply With Quote
Old 04-26-2011, 06:19 PM   #29
JetBlackE46
Modded
According to the OP it's a #10 sheet metal screw. See pic in first post.
As mentioned, the holes are not threaded...which is why you have to use self taping screws.
Old 04-26-2011, 07:53 PM   #30
Danoff
I see, stupid question then. I didn't realize that the OP had pre-drilled holes, but I see now that the distinction is the lack of thread.
Old 06-05-2011, 06:18 PM   #31
Danoff
I now have first aid boxes on both seats. Thanks to everyone who has contributed to this thread.
#10 didn't work, just slid all the way through the hole. #12 didn't work, slide almost all the way through the hole - wouldn't thread with spacers. Had to go to 1/4", I think that's #14. Once I got it in though, as JapanRed pointed out, the 3/4" length screw stops the sport seat cushion from adjusting. Furthermore, I found that if I put enough washers on (5) to allow the seat cushion to adjust, I couldn't get the screw to properly thread. If I put few enough washers to get the screw to thread (4), I had to leave the screw loose to get the seat cushion to adjust - therefore the bracket was loose.
Here was the procedure I eventually adopted with the 1/4" hex head 3/4" self-tapping screw.
- Screw straight into the hole first using a ratchet and extender (don't bother with the mounting bracket yet).
- Back the screw out.
- Cut the tip off of the screw so that only threads and head are left (I used a Dremel).
- Attach the mounting bracket with the modified screw and 3 washers, tightening fully.
Old 06-09-2011, 10:52 AM   #32
Danoff
My first aid box.
Old 06-09-2011, 11:00 AM   #33
Rickna
I was able to run a tap through the holes, and used metric bolts.
2001 BMW 330xi
2009 Lexus IS-F
Old 02-07-2012, 04:47 PM   #34
Stinger9
My Ride: '04 330Ci
I checked out your site to find you have one of the most beautiful colors BMW ever put on a car. See my garage for my MGG coupe which I special ordered back in '04.
Still have your car?
Old 02-07-2012, 05:12 PM   #35
Rickna
Wow, I appreciate your compliments. When I bought it the salesman said I'll either love it or hate it (the color). Love the color, hate the salesman...LOL Oh yeah, I still have it, I plan on keeping for a long time (wife loves it too).
2001 BMW 330xi
2009 Lexus IS-F
Old 03-02-2012, 11:15 AM   #36
yappering
My Ride: 323i
After trying many screws this is what you need for the sport seats with that adjustable thing in the front.
Size 14 - 1/2 inch long sheet metal screws. These are thick enough to actually screw into the holes and not too long to interfere with the seat adjustmant.
I hope this helps.
yappering is offline   Reply With Quote
Old 03-03-2012, 03:09 PM   #37
John in VA
My Ride: 328i/325xi
I hope this helps.
If you did it the way BMW wanted you to you'd tap the holes under the sport seat to accept the proper "bolt." Self-tapping will work, as you found out.
Screw - part # 07 14 9 169 302. M6X12 T30 You need two min for the front (there are 3 holes).
John in VA
'13 328i xDrive
'06 330ci ZHP
'03 530i
'02 325xi
'00 328i
'86 535i
'85 535i
'85 325e - RIP
'74 2002tii
John in VA is offline   Reply With Quote
Old 03-14-2012, 03:40 PM   #38
Ivanhoe
My Ride: BMW 330 xi 2005
Very nice, this will be my next thing to do.
Ivanhoe is offline   Reply With Quote
Old 05-31-2012, 11:11 AM   #39
Goughie
My Ride: 330d Sport Touring
Thanks for the write up fellas. My replacement 330d Tourer just arrived and the cover for the first aid box is broken. Simple enough to slide out and replace with new one - I may even put one under the drivers seat, too!
http://i38.tinypic.com/oif03r.png
Sig is a BlownE30M3 production!
"The protection of views purely on religious grounds cannot be justified. It is not only an irrational idea, but it is also divisive, capricious and arbitrary" - Lord Justice Laws, UK 29/04/2010
Goughie is offline   Reply With Quote
Old 05-31-2012, 11:22 AM   #40
Elsamo
My Ride: 2004 325 Ci
If I try to unscrew the self tapping screws and replace with the correct size (so i can get my seat adjustments back) will that strip the hole?
Elsamo is offline   Reply With Quote
box, diy, first aid, mounting
