The Showroom
Old 03-18-2012, 03:06 PM   #21
Drew@Swift Motorworks
Past Site Sponsor
My Ride: Scooty Puff Jr
Drew@Swift Motorworks is offline   Reply With Quote
Old 04-01-2012, 08:38 PM   #22
briangl92
My Ride: VQ37VHR
Just an update...put in a metal water pump, brakes, tstat, and a bunch of other parts. Next upgrades will include a 330 front caliper swap and new front struts with lowering spring perches Should be fun
briangl92 is offline   Reply With Quote
Old 04-01-2012, 09:05 PM   #23
bostonsc4
My Ride: BMW 323i
Looking great man!!
bostonsc4 is offline   Reply With Quote
Old 05-31-2012, 01:46 PM   #24
briangl92
My Ride: VQ37VHR
Just an update for this lackluster build thread
I had my ET blow up on me about a month ago Got it towed and swapped in a new one that I already had waiting (thanks to Drewdown!)
Within the last week, I got ZHP shocks and struts, new strut mounts, Rogue Engineering rear shock and spring reinforcement plates, OEM front strut reinforcement plates, M3 RTABs and limiters, and a couple other miscellaneous bits. Thanks to Drewdown for all the hours of help
Old 05-31-2012, 01:51 PM   #25
briangl92
My Ride: VQ37VHR
Passenger side strut tower, slightly deformed on the inner-most post
Old 05-31-2012, 02:01 PM   #26
w0w
My Ride: '02 M3 Vert
amazing progress so far man! mind letting us know what resistor-less bulbs you used in your front turn signals? my chrome bulbs barely give off any light
daron
w0w is offline   Reply With Quote
Old 05-31-2012, 02:06 PM   #27
briangl92
My Ride: VQ37VHR
Here's the thread about them
http://forum.e46fanatics.com/showthread.php?t=838105
They would throw errors when it was cold out, so I had my cold bulb check programmed out. Good quality, otherwise, and bright. I contacted LEDautomotive about the problem and they sent out resistors for all the bulbs, no questions asked. I run one set in my front corners, and another set in my reverse lights.
Old 05-31-2012, 02:09 PM   #28
briangl92
My Ride: VQ37VHR
M3 RTABs and limiters. Review of the setup will come soon!
It's sitting a little higher than it used to. Might have to fix that
We reinstalled everything taking note of the old locations...went to get it aligned and everything was still in spec
Old 05-31-2012, 03:58 PM   #29
spencers
My Ride: 2006 330i
Great build thread. Keep up the good work!
spencers is offline   Reply With Quote
Old 05-31-2012, 04:06 PM   #30
jiggz
My Ride: E90 M3|E70 X5 50i
Looks really nice. Much improved despite no major changes - that's how you do it.
I would suggest clear front corners again, but this time to it correctly and get OEM so they don't melt. Silver-gray looks good w/ clears, and you've already got them installed on the sides and rear.
jiggz is offline   Reply With Quote
Old 05-31-2012, 04:55 PM   #31
briangl92
My Ride: VQ37VHR
Agreed! Thanks
I've considered getting OEM clears but if I did, I know I would want LED bulbs again. I don't know, I'm on the fence. I like the look of it both ways.
Old 06-01-2012, 03:52 PM   #32
ImSoFreaknWhite
My Ride: '06 M3 SMG VERT
Send a message via ICQ to ImSoFreaknWhite Send a message via AIM to ImSoFreaknWhite Send a message via Yahoo to ImSoFreaknWhite
Looks great man, you take good care of it.
Jordan
My Build Thread
l Status Gruppe One-Piece Lip l Anodized CCW Classics w/ Polished Lips l Black Grills/Gills & Emblems l Carbon Fiber Roundels
Status Rear Section l K&N 57 Series CA Intake l OEM JB Hardtop l TM Drilled/Slotted Rotors l D2 Coilovers w/Camber Plates l VIS CSL VERT Trunk
ImSoFreaknWhite is offline   Reply With Quote
Old 06-04-2012, 12:46 PM   #33
briangl92
My Ride: VQ37VHR
Some pictures of it at a local meet
Old 06-04-2012, 02:33 PM   #34
mkodama
mkodama's Avatar
Seriously needs a drop and wheels.
Old 06-04-2012, 02:50 PM   #35
briangl92
My Ride: VQ37VHR
Want:
Style 189
Front drop hats
Thinner rear spring pads
Old 06-04-2012, 02:51 PM   #36
mkodama
mkodama's Avatar
Originally Posted by briangl92 View Post
Want:
Style 189
Front drop hats
And once you do that, people like me will still say it needs wheels and a drop.
Old 06-04-2012, 02:59 PM   #37
briangl92
My Ride: VQ37VHR
Back when it was on collapsed shocks, people were asking me what suspension I was running
Old 06-04-2012, 03:06 PM   #38
tock172
My Ride: '12 135i DCT
Love the progress. Your car looks so clean and that M-Tech II bumper really brings it together. As far as the clear corners are concerned, I'm sort of indifferent. I run them on my Silver-Grey 330i, but I think the amber doesn't necessarily look too bad with our paint. However, considering the fact that you already have clear sides and tail lights, I think a set might not be a bad idea. Forget the LEDs. The only LEDs I will run on my 330i are for the license plate and I have enough trouble with those to begin with. Get chrome bulbs and you'll be set.
+1 You should really consider a mild set of lowering springs.
Past: 1999 Techno Violet Metallic M3
Present: 2012 135i DCT Dinan S2
Old 06-04-2012, 05:34 PM   #39
briangl92
My Ride: VQ37VHR
Thanks! Ya like I said I'm on the fence about it. I don't mind the ambers at all, but then again everything else is clear. I would rather take the money I would spend on the clears and put it towards something else.
I've considered but I'm not sure how my shocks and struts would react to it.
Old 06-04-2012, 05:46 PM   #40
tock172
I completely understand allocating the money towards something more important. And regarding the shocks, that's why I'm using my blown out original suspension as an excuse to replace it with H&R race springs and Bilstein sport shocks.
boring, briangletalkslikeacowboy, build thread, not much flavor, soldwhenwarrantyisup, sulev
