Old 06-04-2012, 07:47 PM   #1
hueyhy
My Ride: E46 330i
EU2 tuning with stock set up?
I know that EU2 works without catalyst converter and SAP, but how about if I just re-flash the ECU to EU2 but don't do the hardware mods?
will there be any significant improvement or not?
will I run into problems?
thanks!
hueyhy is offline   Reply With Quote
Old 06-04-2012, 07:49 PM   #2
j_block
My Ride: 2003 325i
thanks!
Why
Sent from my SPH-D700 using Bimmer App
j_block is offline   Reply With Quote
Old 06-04-2012, 07:56 PM   #3
Hornung418
My Ride: '04 MB ZHP
I don't believe that MS43 DMEs have a EU2 option...only EU3. I deleted my SAP and will be utilizing some of BimmerBrakes Headers as soon as he gets back with a good report for the Gen3 reps. I'm running MS42 EU2 and have zero issues. I haven't had to pass emissions or anything yet so it's no big deal for me until March 2013.
Hornung418 is offline   Reply With Quote
Old 06-04-2012, 08:00 PM   #4
hueyhy
My Ride: E46 330i
there's no emission inspection in FL either.
so you are running with stock header and EU2 without any issue? sounds great.
How about the performance? Does it really give some improvements you can feel?
Old 06-04-2012, 08:14 PM   #5
hueyhy
My Ride: E46 330i
http://bmwfans.info/parts/catalog/E4...me_programmed/
here, it shows a EU2 there.
BTW: is that "12 14 7 545 671" the thing am looking for? (my car is a 2002 330i, production date is Jan 2002.)
Old 06-04-2012, 08:47 PM   #6
hueyhy
My Ride: E46 330i
Confused after reading through some threads. Some say EU2 is mainly to delete the CEL lights for aftermarket headers. If don't have the mods, the EU spec tunings are not really making much different.
I think I will try to be safe and don't brick my DME
Old 06-04-2012, 09:18 PM   #7
Iceman00
Banned User
My Ride: E90 6MT
Shark it.
Old 06-05-2012, 04:30 AM   #8
daniel_f.
My Ride: 330iC
Take winkfp and use zsb nummer "7 545 671", flash it, remove secondary air pump (or remove connector) and change part14 to part 13.
http://bmwfans.info/parts/catalog/E4...ttached_parts/
Or even better, use EU2 from Z3 3.0
Old 06-05-2012, 04:31 PM   #9
JDUTHIE
My Ride: 2003 325xi
doesnt the SAP help not burn up the cats by leaning out the exhaust on startup? So on a stock setup, this may/may not be a good thing?
JDUTHIE is offline   Reply With Quote
Old 06-05-2012, 08:53 PM   #10
fastjasonbmw
My Ride: 330Xi
Where can we get the EU2 software?
Does this have it?
http://www.amazon.com/gp/aw/d/B0055BD4SO
fastjasonbmw is offline   Reply With Quote
Old 06-05-2012, 09:07 PM   #11
E46_330i_Stud
My Ride: 2004 330ci ZHP 6MT
Most people delete the sap because they have deleted the cats as well. No need for it anymore. I BELIEVE the SAP actually helps warm the cats up to lower emissions on cold starts BECAUSE the engine is running lean. Could be wrong.
1995 325i 5mt ArcticGrey/Dove - SOLD
2004 330ci ZHP 6MT SilberGrau/Black - SOLD
2001 330i M-Sport 5MT StaulGrau/Grey - SOLD
1992 Accord LX Sedan 275k miles all original - DAILY
2002 Chevy Suburban LT Autoride - TOY HAULER
2005 GMC Sierra 2500HD SLT - RACE TRUCK!
E46_330i_Stud is offline   Reply With Quote
Old 06-06-2012, 08:23 AM   #12
daniel_f.
My Ride: 330iC
Does this have it?
You need WinKFP and a usable obd interface.
Old 06-06-2012, 08:06 PM   #13
fastjasonbmw
My Ride: 330Xi
Old 06-07-2012, 09:34 AM   #14
sunnyjay
My Ride: 01 330i
Engines run rich when they are cold to protect the engine. The sap purpose is to warm up the cat quickly to reduce tailpipe emissions.
On a side note, I had the eu2 tune on my 330ci. It ran perfectly fine on a completely stock m54b30. The reason being is because my sap fail.
Sent from my SGH-I897 using Bimmer App
sunnyjay is offline   Reply With Quote
Old 06-07-2012, 04:33 PM   #15
JDUTHIE
My Ride: 2003 325xi
cool^ thanks for the info
Old 08-04-2012, 09:28 AM   #16
sunnyjay
My Ride: 01 330i
what does part 14 and 13 do?
Old 08-04-2012, 09:34 AM   #17
daniel_f.
My Ride: 330iC
it separates cylinder 1-3 and 4-6 from each other.
Old 08-04-2012, 09:38 AM   #18
sunnyjay
My Ride: 01 330i
is this a requirement to run eu2 tunes?
Old 08-04-2012, 02:02 PM   #19
daniel_f.
My Ride: 330iC
well, as its supposed to be used and used in stock eu2 setup... i would go for it
Old 08-04-2012, 03:03 PM   #20
sunnyjay
My Ride: 01 330i
sounds good, do you know if this bolt is a hex head or a regular bolt? also is it above the exhaust ports or below? Thanks
