Old 06-05-2012, 07:08 AM   #41
Feffman
My Ride: BMW M3 (Race Car)
Great build thread. I think you should have dropped the balast plates, installing a seat for "the mascot" and use him as balast.
Feff
Feffman is offline   Reply With Quote
Old 06-05-2012, 10:52 AM   #42
Rosspbig
My Ride: STI
Send a message via AIM to Rosspbig Send a message via Yahoo to Rosspbig
Feff
Haha great idea!!
Originally Posted by The Gorilla View Post
Hi,
Could not see any works to the rear subframe
location fixing/ points during the Cage Install ?
Once you start increasing the load paths
with greater Mechanical grip and the lateral
G forces rise due to Type R or Slick rubber
then you will be ripping out the rear subframe
on a Caged car.
Its a lot easier to strengthen than repair.
Believe me.
Regards,
The Gorilla.
If you look closely at the picture of the trunk area you can see that we installed the subframe reinforcement kit. I chose not to tie the cage into the subframe because A) I have a feeling the subframe reinforcement kit is going to be enough. B) If its not enough, and the plates begin to stress and crack, It is easy to run a couple of reinforcement bars down from the cage.
E46 M3 GTS3 Race Car
Sponsors:
Bimmerworld
SCR Performance
Hanksville Hotrods
Rosspbig is offline   Reply With Quote
Old 06-05-2012, 06:21 PM   #43
ImSoFreaknWhite
My Ride: '06 M3 SMG VERT
Send a message via ICQ to ImSoFreaknWhite Send a message via AIM to ImSoFreaknWhite Send a message via Yahoo to ImSoFreaknWhite
Wow subscribed for sure
Jordan
My Build Thread
l Status Gruppe One-Piece Lip l Anodized CCW Classics w/ Polished Lips l Black Grills/Gills & Emblems l Carbon Fiber Roundels
Status Rear Section l K&N 57 Series CA Intake l OEM JB Hardtop l TM Drilled/Slotted Rotors l D2 Coilovers w/Camber Plates l VIS CSL VERT Trunk
ImSoFreaknWhite is offline   Reply With Quote
Old 06-06-2012, 04:33 AM   #44
The Gorilla
My Ride: E46 M3
Hi,
The Floor Reinforcement Kit is good
for a Road car, but a Caged Track / Race Car
pulling higher lateral G will start a 'sawing' motion
around the bushes and causing 'tears' in a very
short time.
You will more and likely see tears as you have
strengthned the locating bush pick ups.
Its the Torque steer from the diff that causes
diff cradle / rear subframe, to pull/push on the bushes.
Several fully Caged Track cars here in the UK have
all suffered with this issue.
Just trying to help.
Regards,
The Gorilla.
The Gorilla is offline   Reply With Quote
Old 06-10-2012, 11:21 AM   #45
Tarmac_E46_M3
My Ride: 2003 M3
You're saying all this, but not really giving the fix for it.
Sent from my ADR6400L using Bimmer App
2012 MINI Countryman All4
A Compilation of Modifications
Previous: 1969 Mustang, 2006 STI, 2009 STI, 1995 M3, 2003 M3.
Tarmac_E46_M3 is offline   Reply With Quote
Old 06-11-2012, 04:02 PM   #46
The Gorilla
My Ride: E46 M3
Hi,
Quote '' You're saying all this, but not really giving the fix for it.''
I have already stated that it should be tied into
the Roll Cage, ie] the roll Cage needs to pick up
the rear subframe Mounts from above.
Just like all BMW built Race cars with Weld in
Cages from the E30 onwards.
How you fabricate that is up to you or your fabricator,
but std Cars are ripping the rear subframe out
the boot floor due to the honey combe construction.
Epoxy injection is assisting on Road Cars in that
it fills the ''void'' but its not really a suitable
fix for a Track Car with full Cage.
Regards,
The Gorilla.
Old 02-09-2013, 01:46 PM   #47
dxi_3
My Ride: 325xi
Just stumbled on this thread. Great build! No more updates?
dxi_3 is offline   Reply With Quote
Old 02-12-2013, 07:02 AM   #48
Ecko
My Ride: 2003 M3
^Agreed!
Ecko is offline   Reply With Quote
Old 03-04-2013, 07:44 AM   #49
steve bettencourt
My Ride: 2003 m3
Hi nice build ,was your car stock if not are you going to sell the parts you removed
steve bettencourt is offline   Reply With Quote
Old 04-14-2013, 08:56 PM   #50
bssofro
My Ride: M3
Great build.
What shifter is that?
Also you cleaned up the wiring very nicely.
Any pointers on how to do that?
Thx
bssofro is offline   Reply With Quote
