Thread Tools Search this Thread Rating: Thread Rating: 1998 votes, 4.91 average.
Old 06-05-2012, 08:32 AM   #9881
ngillan
My Ride: Is in a salvage yard
Originally Posted by phoenix31 View Post
Just recently picked up a m3 and so far I've bought oem m3 floor mats, black and white carbon fiber bmw kit, metal m3 license plate, cleaned the hell out of the engine compartment, and tomorrow I have a guy coming over for a quote on a new paint job. I am thinking of adding a turbo, but don't know where to start. I also want to dye the seats.
If you want to dye the seats, check out the "color bond guinea pig" thread. Its quite lengthy by now but definately worth the read.
'07 328i - Montego Blue
ngillan is offline   Reply With Quote
Old 06-05-2012, 08:41 AM   #9882
330xIce
My Ride: 2005 330xi
Send a message via AIM to 330xIce
Originally Posted by SH330CI View Post
An 05 with that many problems? Jeez
i know
Originally Posted by Ophidian_PR1M3 View Post
I keep getting those same lights but my car is running fine aside from the lean code I have and can't find a solution to. Let me know what you find that sets off the lights tho please
After jumping the car and driving, the lights went off after a few seconds car still wont start though.
Originally Posted by ac_2007 View Post
Sounds like a simple alternator/voltage regulator problem.
Replace with an OE Bosch 120a after correctly diagnosing this is the problem.
I'm taking it to the dealer today. Well see what's wrong with it. Thanks for the help.
Sent a long time ago in a galaxy far far away
Follow Me On Instagram: JamesMarshall_E46
///My Progress Thread - How To Set a Signature - Black Sedans FTMFW
-James-
330xIce is offline   Reply With Quote
Old 06-05-2012, 10:42 AM   #9883
Crestwood1001
My Ride: 2001 325xi
Guys I need help quick, took a short drive and smelled burning oil and saw smoke, pulled in the driveway and it's coming from where I'm pointing in the pic, took the plastic cover off to see better and removed the oil fill cap and get smoke outta there to.... Not good.... Valve cover gasket?
Crestwood1001 is offline   Reply With Quote
Old 06-05-2012, 10:46 AM   #9884
Guest021715
Account closed.
Ehh, could be. That's also the side your headers are at.
It is possible some sort of fluid spilt onto the hot surface and started burning away. Check the surface of the exhaust manifold heat shields first.
Did the car's sound change at all? You could also have burned through the engine-block to manifold gasket, developing an exhaust leak.
Old 06-05-2012, 10:46 AM   #9885
E46Moonlight
My Ride: 2000 323i
Sounds about right
This too, could be a number of things
E46Moonlight is offline   Reply With Quote
Old 06-05-2012, 10:59 AM   #9886
Crestwood1001
My Ride: 2001 325xi
There's something I'm assuming oil on the heat sheild above the header, assuming its tht burning off, I'm letting it run not and watching it. Let me try and get a better pic
Old 06-05-2012, 11:02 AM   #9887
Crestwood1001
My Ride: 2001 325xi
There's a good pic, that was the source of the smoke as far as I can tell, very good sign I need a valve cover gasket. I have a warranty for a bit longer, should I DIY or let them look at it?
Old 06-05-2012, 11:23 AM   #9888
boostedisbetter
boostedisbetter's Avatar
My Ride: 2008 S2000, 2009 CBR
ya just looks like VC gasket. If it's covered under warranty, let them do it!
Originally Posted by Green_Shine View Post
(2/14/2017)Trump, by definition is a nitwit. He has every opportunity to make sound decisions, and he is incapable. I can't see this guy lasting 4 years without resigning or being impeached.
boostedisbetter is offline   Reply With Quote
Old 06-05-2012, 11:24 AM   #9889
Crestwood1001
My Ride: 2001 325xi
Update, warmed it back up and am watching it, looks to be comin from the underside of the header?
Old 06-05-2012, 11:26 AM   #9890
Crestwood1001
My Ride: 2001 325xi
Update, warmed it back up and am watching it, looks to be comin from the underside of the header? It's not a constant smoke it's like bursts of smoke and it's not super heavy it's like wisps of it
Old 06-05-2012, 11:27 AM   #9891
boostedisbetter
UNDER the header???? ummm So are you sure it's not leaking from the VC, and just running between the runners, then burning off lower? I can't think of any reason oil would be leaking BELOW the header (besides serious issues with HG, but let's not go that far yet)
Old 06-05-2012, 12:15 PM   #9892
Crestwood1001
My Ride: 2001 325xi
Could be running down, could also be something else burning off, it stopped now but I'm replacing the gasket
Old 06-05-2012, 12:43 PM   #9893
boostedisbetter
I say this because I have the same issue ONLY sometimes, I will see just a hint of smoke, and its just a drip of oil from the VC. Got my VC gasket, spark gaskets, and VANOS seals in my room ready to be replaced, just need to find the time :|
Old 06-05-2012, 04:48 PM   #9894
COBYATCH
My Ride: 03 325i
finally installed my d2 coilovers. will post pics in my build thread in a little bit.
COBYATCH is offline   Reply With Quote
Old 06-05-2012, 04:59 PM   #9895
Crestwood1001
My Ride: 2001 325xi
I can't find the source, it has not done it again after I cleaned it up, I'll have to try an find a mirror to look under there
Old 06-05-2012, 05:10 PM   #9896
tool2510
My Ride: 2001 330ci
Discovered the radiator is weeping. Ordered a replacement. Now I sit and wait.
tool2510 is offline   Reply With Quote
Old 06-05-2012, 05:10 PM   #9897
tool2510
My Ride: 2001 330ci
Holy crap! How do I make the picture smaller.?
Old 06-05-2012, 05:54 PM   #9898
Crestwood1001
My Ride: 2001 325xi
Picking up the valve cover gasket tomorrow and tearing into it asap
Old 06-05-2012, 06:30 PM   #9899
Tex323GripIsKey
My Ride: 2000 323i Green
Gave her a Mann and some Mobil 1 0w40 Euro Spec =]
She gave me a ride
Originally Posted by Sweetness View Post
I used to drive fast and cowboy around, but then I realized that I can't even afford bumping into someone, so now it's slow and classy, with occasional spurts of speed. Fanatics might pick on each other from time to time, but we are all one great big family that looks out for each other in the end.
I pull up to meets, lean to one side, shakin my finger at all da playahaterz. Then I get back into my car and flash mah beamz.
323i brakes & rotors
Tex323GripIsKey is offline   Reply With Quote
Old 06-05-2012, 06:49 PM   #9900
VALMONT
The De46vil's Army
VALMONT's Avatar
My Ride: 325Ci, Passat
Send a message via AIM to VALMONT Send a message via MSN to VALMONT
She gave me a ride
DID YOU PUT YOUR FOOT IN IT?
DID YOU RIDE IT HARD?
DID YOU GRADUATE JUNIOR HIGH?
VALMONT is offline   Reply With Quote
Rate This Thread
